查看: 5462|回复: 8
TCL L32E5390A-3D 主板40-1MS801-MAE2HG 强制升级包
发表于: 2015-10-4 20:45:19
求助TCL  L32E5390A-3D 主板40-1MS801-MAE2HG 主板标签 V8-MS80104.LF1V052 屏LVW320AUTM E7 V1强制升级数据包
发表于: 2015-10-17 19:27:10
请看下我发的Ms801升级操作指南,PDF格式的!
 楼主| 发表于: 2015-10-5 09:06:55
找了个强制升级文件强制升级不了,不知是文件不对还是U盘问题,换了两个U盘,其中一个U盘在康佳电视上升级非常顺利.还是我操作方法不对:我操作强制升级方法,按住电源开机键,220V交流上电。不管按多长时间电视都没有反应.我按的是电视上的待机建。
 楼主| 发表于: 2015-10-5 16:57:09
德胜华音 发表于 2015-10-5 13:01
用升级小盒子升级效果比较好.
什么样的升级小盒子能不能说详细点
 楼主| 发表于: 2015-10-12 09:08:29
附上该机打印信息高手分析什么原因
2015-10-12, 8:56:21
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
夿IST OK
BIST OK
ALL BIST OK!!
[23456789A][3456789AB][3456789A][456789AB] 6767
[0123456789ABCDEF][0123456789ABCDEF][3456789AB][3456789ABC] 7777
HAL_MIU_INIT2
Hello PM51...
Hello Main
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
HAL_MB_Unmask_Cpu3_2_Cpu0
UART_115200__D
U-Boot 2011.06-svn8764 (Nov 22 2012 - 19:44:45)
CPU  : AMBER3
Board: BD_MS801_MAA2XG
DRAM:  256 MiB
SPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)
MDrv_SERFLASH_GetInfo()
u32AccessWidth = 1
u32TotalSize   = 2097152
u32SecNum      = 32
u32SecSize     = 65536
spi_init: cfg_env_offset: 0x1e0000, at 552
MMC:   mstar-emmc: 0, 0 blocks
u32AccessWidth = 1
u32SecNum      = 32
u32SecSize     = 65536
read_spi_dbtable success...>>>
read table >>>
logo  offset[0x00180028] size[0x0001c2e1] end[0x0019c309]
music offset[0x0019c309] size[0x00000000] end[0x0019c309]
panel offset[0x0019c309] size[0x0000005c] end[0x0019c365]
ursa  offset[0x0019c365] size[0x00000000] end[0x0019c365]
keypad  offset[0x0019c365] size[0x00005000] end[0x001a1365]
db_checksum =:0x1d21afe6
save db_checksum =:0x1d21afe6
============Doyle===================== msKeypad_Init
db_table.keypad_offset =:0x19c365...db_table.keypad_size=:0x4008
Read_PanelParaFromSpiflash success...>>>
UART BUS OFF!!_MApi_PM_ProcessPmInit >> MDrv_PM_Init
avlink_init done
power down
enable WDT
HAL_PM_WakeupFromZero
Run code in SPI.......
狮ˇ?韒碜嬠浗秒m愈嵜
 楼主| 发表于: 2015-10-12 09:10:27
BIST OK
ALL BIST OK!!
[23456789A][3456789ABC][3456789A][456789A] 6767
HAL_MIU_INIT2
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
bring up MIPS over
UART_115200__D
CPU  : AMBER3
DRAM:  256 MiB
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
read table >>>
UART BUS OFF!!
 楼主| 发表于: 2015-10-12 09:12:33
打印信息
发表于: 2015-10-12 09:24:36
那就先升级引导程序再升主程序
 楼主| 发表于: 2015-10-13 08:10:36
四川平板 发表于 2015-10-12 09:24
那就先升级引导程序再升主程序
引导程序应该没有问题,我升级过引导程序故障依旧
GMT+8, 2024-11-19 12:19 , Processed in 0.055629 sec., 10 queries .
