楼主 |
发表于: 2015-10-3 16:44:37
显示全部楼层
2015-10-3, 13:7:30
COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
[3456789A]
[56789ABC]-68
_U
Hello U-Boot
U-Boot 1.1.6 (Oct 13 2011 - 14:58:32)
Board: MSTAR AMBER1 (CPU Speed 504 MHz)
DRAM: 256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO OSD ENV=SERIAL
Flash is detected (0x0707, 0xEF, 0x40, 0x14)
MDrv_SERFLASH_GetInfo()
u32AccessWidth = 1
u32TotalSize = 1048576
u32SecNum = 16
u32SecSize = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0xEC, ID = 0xDA
NAND: 256 MBytes
In: serial
Out: serial
Err: serial
Net: MSVC00B000100100421604TH0000000T
EnvFlag =:128.....CONFIG_ENV_ADDR=:E0000
cbuffer[0] =:0xFF...cbuffer[1] =:0xFF...cbuffer[11] =:0xFF
Check USB port[0]:
Check USB port[1]:
keypad_pressed_1 is:0
[0]adc_val =:0xFF
keypad_pressed_2 is:0
--> ac boot <--
UART BUS OFF! |
