查看: 5408|回复: 0
康佳LED55X1200AF(6A818D平台)正常开机打印信息
发表于: 2015-7-7 00:34:58
2015-7-6, 19:45:6
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
[AT][MB][start sb][0]
AC_ON
AutoDQS0-[456789ABCDE][456789ABCD][3456789ABC][3456789ABC]-[0x7789]
AutoDQS1-[456789ABCDE][456789ABCDE][23456789ABCDE][23456789ABCD]-[0x7899]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][346]
U-Boot 2011.06-svn3177 (Apr 04 2014 - 18:04:24)
CPU  : Nike
Board: BD_MST049B_10AQV_NIKEC
Hello U-Boot
DRAM:  458 MiB
SPI:  Flash is detected (0x0B01, 0xC8, 0x40, 0x15)
spi_init: cfg_env_offset: 0x1e0000, at 560
uboot held at [3b6ddf60~3ca00000]
Now running in RAM - U-Boot at: 3bb00000
MMC:        eMMC 3775MB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x0: 0x1a: 0x34: 0xec:0x4: 0x24
It's the last cmd
msIR_Initialize
Wait for PM51 standby DRAM ...........PM51 run ok...........============= set bootargs ===============
Unknown command 'if_51OnRam_set' - try 'help'
Hit any key to stop autoboot:  1  0
fore uup IRKey [0xff]
mingwu_mboot----------get_boot_mode_from_env
mingwu_mboot------------>get_boot_mode_from_env-->ulComplete == 0
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
[_MDrv_PNL_Init_LPLL][300]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][302]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][345]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][347]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
p_str =261
u32PWMDuty =261
Init PWM1Init PWM2[ERROR] No Support PWM Clock Unit Divider in Nike Platform[AutoTest][MBoot][JPD Decode]
[GOP0, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0002, ChangeList: 00000340
[AutoTest][MBoot][Show Logo][2108]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    3798460 Bytes = 3.6 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 3612448 Bytes = 3.4 MiB
      Image 1: 186000 Bytes = 181.6 KiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
## Flattened Device Tree from multi component Image at 25000000
康佳LED55X1200AF(6A818D平台)正常开机打印信息.rar
9.53 KB, 下载次数: 1241, 下载积分: 金钱 -10
GMT+8, 2024-12-26 15:16 , Processed in 0.057899 sec., 12 queries .
