查看: 4074|回复: 0
海信LED39K310X3D(RSAG7.820.4779)(166928)正常开机打印信息
发表于: 2015-7-6 23:59:01
2015-7-6, 12:26:27
COM4, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(1 ~ 96), Size=96, Mid=48, Set=48.
Byte 1 : Gating(1 ~ 96), Size=96, Mid=48, Set=48.
HW Byte 0 : DQS(21 ~ 53), Size 33, Set 37, HW_Set 40.
HW Byte 1 : DQS(22 ~ 50), Size 29, Set 36, HW_Set 37.
DRAM A Size = 256 Mbytes.
Boot
Start Pmain
0x0000a000
Nand boot
NID=0x9580f12c
LZHS addr:0x00100040
LZHS size:0x00096150
LZHS checksum:0x0000000f
Boot
Start Lmain
MT5389 Boot Loader v0.9
Boot reason: A/C power on!!
Load HDMI internal EDID.................
CEC Physical offset 153
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0xaf
HDMI2 PA 0x20
HDMI2 checksum 0x9f
HDMI3 PA 0x30
HDMI3 checksum 0x8f
HDMI4 PA 0x40
HDMI4 checksum 0x7f
SIF_Master0: new design
SIF_Master1: old design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  d784e0, size: 24576)success!!
T8032 FW version: 75
LDR_FlashCopy 0xf010 0x4c580 0x80
Detect NAND flash ID: 0x9580F12C
Detect MT29F1G08AAC/ABADA NAND flash(SLC): 128MB
NAND_BDM_Mount: Partid=0, offset=0x0, size=0x200000
NAND_BDM_Mount: Partid: 0, Total Block Count: 16, Bad Block Count: 0
Do USB upgrade
USB: Vbus turn up time = 212 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x34 Flags:0x34
海信LED39K310X3D(RSAG7.820.4779)(166928)正常开机打印信息.rar
9.09 KB, 下载次数: 1563, 下载积分: 金钱 -10
GMT+8, 2024-12-26 14:52 , Processed in 0.055628 sec., 12 queries .
