查看: 3518|回复: 0
索尼KLV-40BX420(BF-CN3 1P-010BJ05-4011)正常开机打印信息
发表于: 2015-7-3 21:42:09
COM4, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
INNT
77
[3456789AB][3456789AB]
0077
BOOT-ACR2AP
Hello Janus:A0000000
## heap size is 195K under 300K!!
IIC init fail SDA:0 SCL:1
Main-1 0
Flash is detected (0x0503, 0xC2, 0x20, 0x17)
sar input test...
[SWUpdate]Jump to PowerOn Seq
g_PNL_TypeSel=11
Load Factory Gamma Table
input source must be disabled before set frame buffer address. Ex:when video play, you can't use this function.
LiveColor=9,E_GRULE_LIVE_COLOR_6_40
Use Bank Color Temp.!
DSP code loaded successfully
[MAPI DMX][001192]Exit before initialization
Load FHD PC Video Setting...
Enter While 5518
PQSrcType=23(AV_PAL_BGHI)
Force Download I.P.
**AC Low**
EEPROM Keep Original!
** AC PW NG **
索尼KLV-40BX420(BF-CN3 1P-010BJ05-4011).rar
827 Bytes, 下载次数: 1081, 下载积分: 金钱 -10
GMT+8, 2024-12-26 15:05 , Processed in 0.055858 sec., 12 queries .
