用户名  找回密码
楼主: admin
RT809系列编程器软件发布专用链接
发表于: 2013-6-8 21:24:33
admin 发表于 2013-3-24 08:45
Dear Daniel :
Now,you may download the firmware and reprogramming on your external programmer.Goo ...
s19a300b monitor died after firmware updatehttp://org.downloadcenter.samsun ... r_1.1.07_120227.exe) question the process of program with external w25x40 programmer with the file: W25X40 SAMSUNG_S19A300B LTM185AT05.BIN this whole process would not micro SE1059 program? no eeprom 24c08 program?. I have 10 monitor with this fault.
http://www.ifix.net.cn/en/forum. ... mp;tid=4&extra=
举报
 楼主| 发表于: 2013-6-8 21:39:00
mj15015 发表于 2013-6-8 21:24
s19a300b monitor died after firmware updatehttp://org.downloadcenter.samsung.com/downloadfile/Co ...
You can fill the data buffer with 'FF',and program the '24C08' EEPROM.
举报
发表于: 2013-6-8 21:56:40
Hi Daniel,
Can i help you? Can you let me know what's your samsung lcd monitor problem? Actually the SE1059 chipset not included firmware inside, all firmware was store in the W25X40 flash memory. The 24C08 eeprom is using to save customer and OSD Menu setting data only. If you suspect the 24C08 have something wrong, you can using the programmer save their original data first, and then erase it until the 24C08 empty. If your programmer can't erase it, then you can try to fill all the section as "FF". Hope this helps!
Kent
举报
发表于: 2013-6-8 22:36:40
ptkent 发表于 2013-6-8 21:56
Hi Daniel,
Can i help you? Can you let me know what's your samsung lcd monitor problem? Actuall ...
Hi, thank for reply, I try to use these tools to program the flash w25x40 spipgmw.exe DOS ( http://rayer.g6.cz/elektro/spipgm.htm) , monitor failure is corrupted the flash only
举报
发表于: 2013-6-9 12:26:58
d
mj15015 发表于 2013-6-8 22:36
Hi, thank for reply, I try to use these tools to program the flash w25x40 spipgmw.exe DOS ( http:/ ...
Hi Daniel,
I had replied your post here:
http://www.ifix.net.cn/en/thread-4-1-1.html
举报
 楼主| 发表于: 2014-1-18 12:43:16
奇妙电子 发表于 2014-1-18 08:53
用英文回复的人都是有学问的----------------------------------------------吗?
很多国外用户的,除了南极洲,其他各大洲都有。
举报
发表于: 2014-5-29 00:19:53
请问从你们这里买RT809F的话,能够支持我从RTD2483RD里读取和写入数据?请赐教,如果行的话从你们这里购置一台。
举报
 楼主| 发表于: 2014-5-29 08:19:18
夏天的冰 发表于 2014-5-29 00:19
请问从你们这里买RT809F的话,能够支持我从RTD2483RD里读取和写入数据?请赐教,如果行的话从你们这里购置一 ...
RTD2483RD内部没有程序,程序保存在外接的25系列SPI闪存里面,可以在线读写。
举报
发表于: 2014-10-21 11:12:28
季总20141010版的在线读25的可以写入校验不了用20140818的就可以校验成功
举报
 楼主| 发表于: 2014-10-21 12:15:33
你重新下载20141010版本再安装,肯定OK.
举报
GMT+8, 2025-4-16 01:14 , Processed in 0.060871 sec., 12 queries .
