查看: 10830|回复: 9
请懂的师傅看看这个打印信息
发表于: 2015-6-8 19:20:30
2015-6-8, 18:22:25
COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
INNT
55
[3456789ABC][3456789ABC]
0077
BOOTR2AP
Hello Janus:A0000000
## heap size is 203K under 300K!!
=> Time: 13:45:27
g_u16Miu0_Dqs0~~~~~________-0x=1FF8
g_u16Miu0_Dqs1~~~~~_________0x=1FF8
USB_Init_ConfigureUSB port 0 enter power save done
USB port 1 enter power save done
USB_Init_Configure done...
Flash is detected (0x0904, 0x1C, 0x30, 0x16)
[msKeypad_Init]: Allocated channel number > 1 !!!
sar input test...
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Getkey data is 0
Data is is 0
Panelsel is 0
E2PROM OK! ----  MApi_XC_Sys_Init
g_PNL_TypeSel is 1
AMP Mute
AMP resetOn !!!!![PHOTO] JPEG, Baseline, (1366x768, 1366(1368)x768), size: 4147200, thumbnail: 0
[PHOTO] Orient: 1, Date Time: NO
[PHOTO] total time: 80, progress: 1000
MApp_DMP_InitDMPStat
@@Enter MApp_InputSource_IHCSetting[GE] Wait Idle: 0 : 10
AMP resetOff !!!!!DSP code loaded successfully
ATVProInitialize
InputSourceType is 7
Set audio standard
AMP Mute
AMP Init DevI2s !!!!!5707 desktop mode
BTL 2.0 init tas5707 end!
easpect is 0
============ CUS04_MM_S7J ============
DVB-T Software Version: 0.234585
[Board]: BD_MST216A_JNS_10A_9463_TCL
[Panel]: LTA400HA12
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[effect OPEN]:0
kate EN_EXE_SHOW_SOURCE_BANNER
u8Enable=0
set CVBS mute4 3
CVBS Mute is 0
电视故障是有伴音无图像
发表于: 2015-6-8 21:02:29
反正我也是看不懂,等待高人分析。
发表于: 2015-6-9 09:16:17
打印信息貌似没什么异常,有声无像会不会是背光问题?
 楼主| 发表于: 2015-6-9 10:54:17
谢谢大师的支持,背光是亮的,逻辑板上的12V;14V;27V;—10V都正常,按键也可以操作,就是有伴音无图像(开机LOGO也没有),请大师帮忙分析一下故障原因,先谢过了!
发表于: 2015-6-9 12:33:58
都有伴音了,机器开了,测VCOM电压是多少V
 楼主| 发表于: 2015-6-9 15:34:17
哦 这个电压我没找到。
发表于: 2015-7-3 21:40:31
把屏线跟逻辑板先分开一半看一下屏坏了没有啊。
发表于: 2015-11-20 21:38:18
发表于: 2015-11-20 21:48:59
应该屏有问题,请认真检查
发表于: 2015-12-1 12:09:20
主芯片到逻辑板的信号是不是有   从打印信息看不出来的
GMT+8, 2024-12-19 20:45 , Processed in 0.054789 sec., 9 queries .
