查看: 5746|回复: 12
求三星UA46D5000PR 主板BN41-01747A 待机MCU WT61P805程序
发表于: 2015-5-29 09:49:55
求三星UA46D5000PR 主板BN41-01747A 待机MCU WT61P805程序搜索
复制
发表于: 2015-5-30 18:58:10
关注了没有哦 对吧不起了
发表于: 2015-6-5 09:52:04
我也路过关注了,没有,对不起咯!
发表于: 2016-4-18 15:03:45
楼主,三星UA46D5000PR 主板BN41-01747A 待机MCU WT61P805程序找到了吗?能分享一下吗?
发表于: 2016-6-1 22:25:30
同求,不知哪位大侠可以分享一下
发表于: 2017-8-28 04:56:55
Hi
Try this same model. The chassis number is different. I hope it will help you. I copied the firmware after replacing the back lights and the TV was now fully working.
发表于: 2017-9-27 19:53:30
Thanks for sharing
发表于: 2017-10-23 15:29:49
thank for electronics !
发表于: 2018-7-8 14:12:26
Thanks for sharing
GMT+8, 2024-11-26 05:40 , Processed in 0.057840 sec., 12 queries .
