查看: 9957|回复: 2
创维42E750不开机升级的打印信息
发表于: 2015-5-7 14:52:55
哪位大师帮忙看一下这个机器的打印信息,是什么问题。
机器原来是不开机,绿灯电源正常,主板上各电源电压也是正常的。下面是打印信息
0x00007beb
0x011000ff
Sep 29 201211:11:32PHY trainning Result=0x00000000
Training result:
        RSLR0=00000249
        RDGR0=00000055
        DLLCR0=00000000
        DLLCR1=00000000
        DLLCR2=00000000
        DLLCR3=00000000
        DQTR0=ffffffff
        DQTR1=ffffffff
        DQTR2=ffffffff
        DQTR3=ffffffff
        DQSTR=000006db
        DQSNTR=000006db
Stage 00 Result 00000000
Stage 01 Result 00000000
Stage 02 Result 00000000
M2C Systemp Started
Embedding cold heart...
__TEXT_BASE: 0x8f800000
0xea000012
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0x8f000100
0x8f000160
0x8f0001c0
0x8f000220
0x8f000280
0x8f0002e0
0x8f000340
0x12345678
ucl decompress
kR预(*戟)S摟?   Sz捠z拏姃B歎羴捠拏姃j妸見娨偮JjぴH垟U↗:5R﨨AND:  Amlogic nand flash uboot driver for m2, Version 1.0 (c) 2010 Amlogic Inc.
mtd->info: NAND 512MiB 3,3V 8-bit
nand0 initialized ok
oob size is not enough for selected bch mode: NAND_BCH16_MODE force bch to mode: NAND_BCH8_MODE
multi plane error for selected plane mode: NAND_TWO_PLANE_MODE force plane to : NAND_SINGLE_PLANE_MODE
nand1 initialized ok
MMC:   SDIO Port A: 0
spi_flash_probe........:
SF: Got idcode ef 40 15
SF: Detected W25Q16 with page size 4096, total 2097152 bytes
SPI NOR Flash have write protect!!!
In:    serial
Out:   serial
Err:   serial
ready
suspend = off
cold_heart_status = 0xa497c97e
Net:   select eth clk-0,source=400000000,out=50000000
Apollo EMAC
Dcache status 1
Icache status 1
---data value = AIO-11:11/09/29/2012----
reboot_mode_current=d0cdefcc
AMLOGIC_CHARGING_REBOOT...
Hit any key to stop autoboot:  1
******WTD disable******
0
M2C_SOCKET#
M2C_SOCKET# run recoverynand
NAND read: device 1 offset 0x1000000, size 0x800000
8388608 bytes read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
## Error: "recovery" not defined
M2C_SOCKET# run recoveryspi
2048 KiB W25Q16 at 0:2 is now current device
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-2.6.34
   Image Type:   ARM Linux Kernel Image (lzma compressed)
   Data Size:    1794373 Bytes = 1.7 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Using machid 0xb8e from environment
Starting kernel ...
Linux version 2.6.34 (yz@lcd1server) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #2 Wed Aug 8 15:35:48 CST 2012
CPU: ARMv7 Processor [411fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: AMLOGIC MESON-M2 7366M REFE06
Ignoring unrecognised tag 0x00000000
Memory policy: ECC disabled, Data cache writeback
BUG: mapping for 0x84000000 at 0xc4000000 overlaps vmalloc space
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 204544
Kernel command line: mem=1024M recoverymode=0 console=ttyS0,115200n8 clk81=187500k lvds=port_reverse a9_clk=600M
other pll setting to crystal_req=24,out_freq=750,n=4,m=125,od=0
LVDS boot args: port_reverse
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 64MB 567MB 176MB = 807MB total
Memory: 814232k/814232k available, 12136k reserved, 180224K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xf5100000 - 0xfd000000   ( 127 MB)
    lowmem  : 0xc0000000 - 0xf5000000   ( 848 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc017d000   (1492 kB)
      .text : 0xc017d000 - 0xc0448024   (2861 kB)
      .data : 0xc045e000 - 0xc047d260   ( 125 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is enabled.
NR_IRQS:128
Console: colour dummy device 80x30
console [ttyS0] enabled
Calibrating delay loop... 1196.03 BogoMIPS (lpj=5980160)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Internal error: Oops - undefined instruction: 0 [#1]
last sysfs file:
Modules linked in:
CPU: 0    Not tainted  (2.6.34 #2)
PC is at __initramfs_start+0xdd0/0x15ae00
LR is at bus_create_file+0x38/0x40
pc : [<c001fdd0>]    lr : [<c0288dbc>]    psr: 60000013
sp : f4c39fe8  ip : 00000011  fp : 00000000
r10: 00000000  r9 : 00000000  r8 : 00000000
r7 : 00000000  r6 : 00000000  r5 : 00000000  r4 : c017c388
r3 : 00000000  r2 : 00000000  r1 : c025b0a8  r0 : 00000000
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7f  Table: 80004059  DAC: 00000017
PC: 0xc001fd50:
fd50  6c6e6f5f 61735f79 313d6174 54230a0a 45462056 52555441 6f720a45 2e76742e
fd70  726f6873 74756374 3d79656b 76740a33 6f6c672e 736c6162 70757465 6f68735f
fd90  74735f77 73757461 6c61663d 740a6573 76742e76 72617473 74735f74 73757461
fdb0  6c61663d 740a6573 68732e76 6374726f 656b7475 68735f79 663d776f 65736c61
fdd0  2e6f720a 732e7674 6372756f 65725f65 7265626d 6c61663d 740a6573 6f702e76
fdf0  6d726577 67616e61 6e2e7265 72657665 656d6974 3d74756f 65757274 2e6f720a
fe10  612e7674 6f696475 6e616863 2e6c656e 72616f62 30323d64 2e6f720a 612e7674
fe30  6f696475 6e6f632e 3d676966 2c302c30 0a312c30 742e6f72 73732e76 65642e6d
LR: 0xc0288d3c:
8d3c  ebffffe4 e5943030 e5930030 ebff48b7 e5943030 e5930034 ebff48b4 e59f1020
8d5c  e1a00004 ebffffce e5940030 ebff48af e5940030 ebfd6c4c e3a03000 e5843030
8d7c  e8bd8038 c0470878 e92d4038 e1a05001 e1a04000 ebfffdd7 e3500000 03e05015
8d9c  0a000006 e5940030 e1a01005 e2800008 ebfe6ea9 e1a05000 e1a00004 ebfffd9b
8dbc  e1a00005 e8bd8038 e92d41f0 e30810d0 e1a04000 e59f01e8 ebfd6bed e2506000
8ddc  03e0500b 0a00006e e59f71d8 e2868008 e586406c e2860058 e59f11cc e2872004
8dfc  e5846030 ebff5498 e3a03000 e1a00008 e5863064 e59f11b4 e5942000 ebff49b8
8e1c  e2505000 1a00005c e5973000 e1a00006 e59f719c e5863018 e5d63068 e586701c
SP: 0xf4c39f68:
9f68  00000006 c0224e00 f4c39fa0 f4c182d0 f4c39fa0 f4c181e0 f4c39fa0 00000010
9f88  f4c39fa0 00000000 c04623c4 f4c39fd4 f4c38050 c017db64 00000000 c025b0a8
9fa8  00000000 00000000 c017c388 00000000 00000000 00000000 00000000 00000000
9fc8  00000000 00000000 00000011 f4c39fe8 c0288dbc c001fdd0 60000013 ffffffff
9fe8  c017c388 c00083e0 00000000 c017e950 ffffffff ffffffff 00000001 00000001
a008  f4c3a008 f4c3a008 f4c36000 f4c3a014 f4c3a014 00000000 00000000 00000000
a028  00000000 00000000 00000000 00000000 f4c3a038 f4c3a038 00000000 00000000
a048  00000000 00000000 00000000 00000000 00000000 00000000 c0196af8 c0467998
R1: 0xc025b028:
b028  c025b0a8 e3500000 012fff1e e2800008 eaffffe5 e5903010 e3530000 012fff1e
b048  e5902008 e2803004 e5901004 e5812004 e5821000 e5803008 e5803004 e5900010
b068  e2800008 eaffffd8 e92d4010 e2504000 08bd8010 ebff2984 e5d43020 e1a00004
b088  e7c1309f e5c43020 ebffffe9 e594000c ebffffcd e3a03000 e584300c e8bd8010
b0a8  e92d4070 e240401c e5106008 e5d43020 e510501c e203300c e3530004 1a000002
b0c8  e1a00004 e3a01001 eb0002e0 e5d43020 e3130002 0a000001 e1a00004 ebffffe1
b0e8  e3560000 0a000004 e5963000 e3530000 0a000001 e1a00004 e12fff33 e3550000
b108  08bd8070 e1a00005 e8bd4070 eafe2363 e92d4010 e2504000 0a000001 e284001c
这是一部分信息下面还有
 楼主| 发表于: 2015-5-7 14:55:08
R4: 0xc017c308:
c308  00000000 00000000 00000000 00000030 00000031 00000032 00000033 00000034
c328  00000035 00000036 00000037 00000038 00000039 0000003a 00000000 c001d4a0
c348  00000000 00000000 00000001 c001d540 00000000 00000000 c001d6a0 00000000
c368  00000000 c001d76c 00000000 00000014 00000000 00027060 00031f00 00000000
c388  6e696472 003d7469 74696e69 6f6c003d 76656c67 71006c65 74656975 62656400
c3a8  72006775 74657365 7665645f 73656369 6f6f7200 6c656474 003d7961 746f6f72
c3c8  79747366 003d6570 746f6f72 67616c66 72003d73 77746f6f 00746961 746f6f72
c3e8  7772003d 006f7200 64616f6c 6d61725f 6b736964 6172003d 7369646d 74735f6b
Process swapper (pid: 1, stack limit = 0xf4c382e8)
Stack: (0xf4c39fe8 to 0xf4c3a000)
9fe0:                   c017c388 c00083e0 00000000 c017e950 ffffffff ffffffff
Code: 656b7475 68735f79 663d776f 65736c61 (2e6f720a)
---[ end trace 1b75b31a2719ed1c ]---
Kernel panic - not syncing: Attempted to kill init!
[<c0182a8c>] (unwind_backtrace+0x0/0xe4) from [<c0361658>] (panic+0x3c/0xb8)
[<c0361658>] (panic+0x3c/0xb8) from [<c0195e38>] (do_exit+0x68/0x5cc)
[<c0195e38>] (do_exit+0x68/0x5cc) from [<c01817b8>] (die+0x2dc/0x318)
[<c01817b8>] (die+0x2dc/0x318) from [<c017518c>] (__initramfs_start+0x15618c/0x15ae00)
Internal error: Oops - undefined instruction: 0 [#2]
last sysfs file:
Modules linked in:
CPU: 0    Tainted: G      D     (2.6.34 #2)
PC is at 0xc24c5e54
LR is at vfp_single_multiply_accumulate+0xdc/0x154
pc : [<c24c5e54>]    lr : [<c018abe8>]    psr: 40000013
sp : f4c39e28  ip : f4c39e38  fp : f4c39e44
r10: c001fdd4  r9 : 00000000  r8 : 00000001
r7 : 00000000  r6 : c04678f0  r5 : c04678f0  r4 : c01817b8
r3 : 00000000  r2 : 00000000  r1 : f4c39e30  r0 : c04678f0
Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
PC: 0xc24c5dd4:
5dd4  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5df4  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5e14  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5e34  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5e54  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5e74  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5e94  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
5eb4  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
LR: 0xc018ab68:
ab68  e28d0008 ebfffcf2 e1a03487 e7e72bd7 e35200ff 13520000 e2077102 e1a03123
ab88  e1cd20b0 13833101 e3520000 e1a07827 e58d3004 e1cd70b2 1a000003 e3530000
aba8  0a000001 e1a0000d ebfffce1 e1a0200d e1a03004 e28d1008 e28d0010 ebfffc0a
abc8  e3150001 159f3088 11dd21b2 e1a07000 e1a00006 10223003 11cd31b2 ebfffab8
abe8  e28d1008 e7e73bd0 e3500000 e1a00480 e1cd30b8 b3a02902 a3a02000 e1a00120
ac08  e35300ff 13530000 13800101 e3150002 e28d5018 e1cd20ba 159f3034 e58d000c
ac28  e1a00005 10222003 e1a03004 11cd20ba e28d2010 ebffff3c e1a01005 e1a02004
ac48  e1803007 e1a00006 ebfffda2 e28dd024 e8bd80f0 ffff8000 e92d4007 e3a0c003
SP: 0xf4c39da8:
9da8  c0466434 00000017 f4c39e28 c0182838 c01940bc f4c39e68 f4c39e68 00000000
9dc8  f4c36000 f4c39fa0 ffffffff f4c39e14 f4c38050 c017db64 c04678f0 f4c39e30
9de8  00000000 00000000 c01817b8 c04678f0 c04678f0 00000000 00000001 00000000
9e08  c001fdd4 f4c39e44 f4c39e38 f4c39e28 c018abe8 c24c5e54 40000013 ffffffff
9e28  0000ffea 40000000 c017518e 00000000 c01750fb 00000000 00000017 c0369658
9e48  c03fce48 f4c39e5c f4c36000 c0195e38 c03fce48 00000000 f4c39e48 f4c3e000
9e68  f4c39e68 f4c39e68 00000000 f4c39fa0 f4c30000 c001fdd2 00000001 f4c39ecc
9e88  00000000 c001fdd4 00000017 c01817b8 f4c382e8 0000000b 00000000 00008000
IP: 0xf4c39db8:
9db8  c01940bc f4c39e68 f4c39e68 00000000 f4c36000 f4c39fa0 ffffffff f4c39e14
9dd8  f4c38050 c017db64 c04678f0 f4c39e30 00000000 00000000 c01817b8 c04678f0
9df8  c04678f0 00000000 00000001 00000000 c001fdd4 f4c39e44 f4c39e38 f4c39e28
9e18  c018abe8 c24c5e54 40000013 ffffffff 0000ffea 40000000 c017518e 00000000
9e38  c01750fb 00000000 00000017 c0369658 c03fce48 f4c39e5c f4c36000 c0195e38
9e58  c03fce48 00000000 f4c39e48 f4c3e000 f4c39e68 f4c39e68 00000000 f4c39fa0
9e78  f4c30000 c001fdd2 00000001 f4c39ecc 00000000 c001fdd4 00000017 c01817b8
9e98  f4c382e8 0000000b 00000000 00008000 62363536 35373437 37383620 37663533
FP: 0xf4c39dc4:
9dc4  00000000 f4c36000 f4c39fa0 ffffffff f4c39e14 f4c38050 c017db64 c04678f0
9de4  f4c39e30 00000000 00000000 c01817b8 c04678f0 c04678f0 00000000 00000001
9e04  00000000 c001fdd4 f4c39e44 f4c39e38 f4c39e28 c018abe8 c24c5e54 40000013
9e24  ffffffff 0000ffea 40000000 c017518e 00000000 c01750fb 00000000 00000017
9e44  c0369658 c03fce48 f4c39e5c f4c36000 c0195e38 c03fce48 00000000 f4c39e48
9e64  f4c3e000 f4c39e68 f4c39e68 00000000 f4c39fa0 f4c30000 c001fdd2 00000001
9e84  f4c39ecc 00000000 c001fdd4 00000017 c01817b8 f4c382e8 0000000b 00000000
9ea4  00008000 62363536 35373437 37383620 37663533 36362039 37376433 36206636
R0: 0xc0467870:
7870  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
7890  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
78b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
78d0  00000000 c03f8f4e c03f8f55 c03feec1 00000000 f4c005a4 f4c005a4 0000000c
78f0  00000002 00007ffa f4c10000 00000005 f4c36000 c0460318 00000000 00000000
7910  f4c05400 00000000 00008000 00000001 00000000 c04617b0 f4c36ebc f4c36ec8
7930  00000000 00000000 00000000 c04678f0 00000000 00000000 0000012d 00008000
7950  00000001 c0467954 c0467954 00000000 c0366804 00000000 c0467968 c0467968
R1: 0xf4c39db0:
9db0  f4c39e28 c0182838 c01940bc f4c39e68 f4c39e68 00000000 f4c36000 f4c39fa0
9dd0  ffffffff f4c39e14 f4c38050 c017db64 c04678f0 f4c39e30 00000000 00000000
9df0  c01817b8 c04678f0 c04678f0 00000000 00000001 00000000 c001fdd4 f4c39e44
9e10  f4c39e38 f4c39e28 c018abe8 c24c5e54 40000013 ffffffff 0000ffea 40000000
9e30  c017518e 00000000 c01750fb 00000000 00000017 c0369658 c03fce48 f4c39e5c
9e50  f4c36000 c0195e38 c03fce48 00000000 f4c39e48 f4c3e000 f4c39e68 f4c39e68
9e70  00000000 f4c39fa0 f4c30000 c001fdd2 00000001 f4c39ecc 00000000 c001fdd4
9e90  00000017 c01817b8 f4c382e8 0000000b 00000000 00008000 62363536 35373437
R5: 0xc0467870:
R6: 0xc0467870:
R10: 0xc001fd54:
fd54  61735f79 313d6174 54230a0a 45462056 52555441 6f720a45 2e76742e 726f6873
fd74  74756374 3d79656b 76740a33 6f6c672e 736c6162 70757465 6f68735f 74735f77
fd94  73757461 6c61663d 740a6573 76742e76 72617473 74735f74 73757461 6c61663d
fdb4  740a6573 68732e76 6374726f 656b7475 68735f79 663d776f 65736c61 2e6f720a
fdd4  732e7674 6372756f 65725f65 7265626d 6c61663d 740a6573 6f702e76 6d726577
fdf4  67616e61 6e2e7265 72657665 656d6974 3d74756f 65757274 2e6f720a 612e7674
fe14  6f696475 6e616863 2e6c656e 72616f62 30323d64 2e6f720a 612e7674 6f696475
fe34  6e6f632e 3d676966 2c302c30 0a312c30 742e6f72 73732e76 65642e6d 65636976
Stack: (0xf4c39e28 to 0xf4c3a000)
9e20:                   0000ffea 40000000 c017518e 00000000 c01750fb 00000000
9e40: 00000017 c0361658 c03fce48 f4c39e5c f4c36000 c0195e38 c03fce48 00000000
9e60: f4c39e48 f4c3e000 f4c39e68 f4c39e68 00000000 f4c39fa0 f4c30000 c001fdd2
9e80: 00000001 f4c39ecc 00000000 c001fdd4 00000017 c01817b8 f4c382e8 0000000b
9ea0: 00000000 00008000 62363536 35373437 37383620 37663533 36362039 37376433
9ec0: 36206636 36333735 20313663 36653228 30323766 00202961 00000002 c04ab850
9ee0: 00000002 f4c39fa0 c001fdd0 f4c38050 00000001 00000200 c017db64 f4c38120
9f00: 00000000 c017518c 00000006 00000000 00000004 00000000 00030001 c001fdd0
9f20: 00000002 c04a3850 00000002 000081a4 f4c39f84 00000000 00000000 c025a5e4
9f40: f4c39f58 f4c07850 00000000 f4c39f58 f4c39f7c c0225750 00000000 c01e3e24
9f60: 00000000 f4c39fa0 00000006 c0224e00 f4c39fa0 f4c182d0 f4c39fa0 f4c181e0
9f80: f4c39fa0 00008010 f4c39fa0 00000000 c04623c4 f4c39fd4 f4c38050 c017db64
9fa0: 00000000 c025b0a8 00000000 00000000 c017c388 00000000 00000000 00000000
9fc0: 00000000 00008000 00000000 00000000 00000011 f4c39fe8 c0288dbc c001fdd0
9fe0: 60000013 ffffffff c017c388 c00083e0 00000000 c017e950 ffffffff ffffffff
[<c018abe8>] (vfp_single_multiply_accumulate+0xdc/0x154) from [<00000000>] (0x0)
Code: ffffffff ffffffff ffffffff ffffffff (ffffffff)
---[ end trace 1b75b31a2719ed1d ]---
Fixing recursive fault but reboot is needed!
到这里就不动了,中间有一小节因为太长被我删了
 楼主| 发表于: 2015-5-15 10:53:39
怎么没有大师帮忙看一下,顶起来
GMT+8, 2024-12-26 15:07 , Processed in 0.052506 sec., 9 queries .
