查看: 11772|回复: 7
海尔LE32A910正常机打印信息
发表于: 2015-4-27 08:43:37
2015-4-27, 8:25:8
COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
  SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB  - DDR2 800MHz
BIST_0 PASS.
77
[23456789AB][23456789AB]
0066
MIU Initial OK
sar input test...
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
PNL type=1 => XC lpll type=1
GE_SetOnePixelMode
s8SN0(44) s8SN1(43)
Mirror function (1)
=============== eWin = 0 ==============
Enter enUiInputSourceType = 7
Set blue FALSE
Set black TRUEenUiInputSourceType  = 7
__DMP__
Result enInputSourceType = 36
[Set] _enSysInputSource = 0x100
MApp_DMP_InitDMPStat
Set black TRUE
Skip_Logo_temp=[1 ] , s16valueB=[50]
Set black FALSE
---MApi_PNL_SetInverter true----
Disable Aeon
Disable Aeon Done
DSP code loaded successfully
Logo Delay 2 seconds
Set black TRUE=============== eWin = 0 ==============
Set blue FALSE
Set black TRUE[Clear] _enSysInputSource = 0x0
__DMP__
========= CUS04_ATV_MM_M10 =========
DVB-T Software Version: 0.305665
[Board]: BD_MST021B_10ALG_11313_64M
[Panel]: PNL_LCM_T315H86_LED
[Tuner]: HTF2_8C_116CW
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 1
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
##########go to main loop#########
show DMP_MSG_TYPE_LOADING
MApp_MPlayer_SetCurrentMediaType fail
*** _MApp_DMP_Init() ***
MApp_UiMediaPlayer_Init()
DMP_UI_STATE_MEDIA_SELECT
clear Flag 16
clear Flag 32
还有程序,主板0091802371F V10.2 屏是京东方屏,型号H320EHC-YB30(一体屏)
海尔LE32A910 主板0091802371F V10.2 屏H320EHC-YB30 芯片MST6M181 182 MST_EXT_SPI #.rar
2.12 MB, 下载次数: 1139, 下载积分: 金钱 -10
发表于: 2015-4-27 09:54:42
谢谢楼主的资料,顶一下。
发表于: 2015-6-8 10:35:02
谢谢楼主,打印信息这方面的知识还比较少,学习
发表于: 2015-6-8 10:40:46
发表于: 2015-11-4 11:35:27
怎么连的机呢
发表于: 2015-12-1 12:18:15
学习观摩  慢慢消化
发表于: 2017-2-10 15:42:07
谢谢了下载了
发表于: 2017-2-10 16:59:49
good brother
GMT+8, 2024-12-21 13:37 , Processed in 0.060850 sec., 12 queries .
