查看: 12925|回复: 20
创维 55E70RG 开机到Skyworth界面不能进入了。求大师指点!
发表于: 2015-4-25 14:49:50
故障:开机到Skyworth界面停止,有时会自动重启也是进入到Skyworth界面再停止。
机型:55E70RG
板号:5800-A8M700-1030 Ver00.00
配屏:LC550EUD
打印信息如下://///////////////////////////////////////////////////////////////////////////
2015-4-25, 14:11:23
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
BIST1-OK
[123456789A][0123456789A]-55
[123456789A][0123456789]-54
_nPD
U-Boot 1.1.6 (Aug 12 2010 - 16:09:17)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Module: KEYPAD USB FAT NAND UBI UBIFS NET EEPROM JFFS2 LOGO
NAND:  nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x00540000
128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100222324DA:100726T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
cmd: md.b 0x80200000 0x1
80200000: ff    .
80200000: 5a5aa5ff    ..ZZ
.ndata_1[7fa]--->:ff
2.defatult_set is:165
3.*ucp is:255
keypad_pressed_1 is:0
keypad_pressed_2 is:1
1.MSAPI_WDT_Start
3.MSAPI_WDT_StopCheck USB port[0]:
??? Waiting for Peripheral Connecting Fail...
1.usb init failed
Check USB port[1]:
Host type:2
scanning bus for devices... Wait for hub reset....
1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
cmd: md.b 0x874bfef8 0x1
874bfef8: 01    .
cmd: md.b 0x874bfef9 0x1
874bfef9: 01    .
0x00220000-0x07220000 : "mtd=3"
Using volume CK
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 3, name "CK"
UBIFS: mounted read-only
UBIFS: file system size:   %ld bytes (%ld KiB, %ld MiB, 0 LEBs)
UBIFS: journal size:       %ld bytes (%ld KiB, %ld MiB, 0 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root:  %lu bytes (%lu KiB)
ubifs_mount SUCCESS !!
u32ReadBuffVirAddr = a2000000, u32IntBuffVirAddr = a2050000, u32OutBuffVirAddr = a3800000
MApi_JPEG_SetDbgLevel: DbgLevel = 0x0000
verJPD_SetStatus >>>>>>>>>>>>>>>>>>>>>>>> w: 1920  h: 1080
PNL_WIDTH=0x780
M_boot Melody on
  Dsp code verify ok!!
audio DSP_SE LoadCode success..  Dsp code verify ok!!
audio DSP_DEC LoadCode success..
Write 5706 Fail!
dai Write 5706 Success!
2.MSAPI_WDT_ClearUBI already initialized!!
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-07-20   3:16:06 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3411653 Bytes =  3.3 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
 楼主| 发表于: 2015-4-25 14:50:52
Starting kernel ...
L2 enabled
Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #34 PREEMPT Tue Jul 20 11:15:44 CST 2010
LINUX started...
boot_command_line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2900000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x46034000,0x1ED0000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),112m(UBI),-(NA)
LX_MEM  = 0x400000, 0x2900000
LX_MEM2 = 0x46034000, 0x1ED0000
CPHYSADDR(PFN_ALIGN(&_end))= 0x9AE000
EMAC_LEN= 0x100000
DRAM_LEN= 0x10000000
console [early0] enabled
CPU revision is: 00019554 (MIPS 34Kc)
Begin Titania3_setup
BDetermined physical RAM map:
memory: 02900000 @ 00400000 (usable)
memory: 01ed0000 @ 46034000 (usable)
Wasting 32768 bytes for tracking 1024 unused pages
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  DMA      0x00000400 -> 0x00008000
  Normal   0x00008000 -> 0x00020000
  HighMem  0x00020000 -> 0x00047f04
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000400 -> 0x00002d00
    0: 0x00046034 -> 0x00047f04
  Normal zone: 768 pages exceeds realsize 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16857
Kernel command line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2900000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x46034000,0x1ED0000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),112m(UBI),-(NA)
alloc ebase: 818fc000
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=0004840c
Readback ErrCtl register=0004840c
PID hash table entries: 256 (order: 8, 1024 bytes)
CPU freq count = 252000000
CPU frequency 504.00 MHz
console handover: boot [early0] -> real [ttyS0]
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 58420k/41984k available (3908k kernel code, 15096k reserved, 1338k data, 164k init, 31552k highmem)
SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 334.84 BogoMIPS (lpj=167424)
Mount-cache hash table entries: 512
net_namespace: 288 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND)2001-2006 Red Hat, Inc.
fuse init (API version 7.10)
msgmni has been set to 52
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xbf201300 (irq = 8) is a 16550
serial8250: ttyS1 at I/O 0xbf220c00 (irq = 79) is a 16550
serial8250: ttyS2 at I/O 0xbf220d00 (irq = 90) is a 16550
brd: module loaded
loop: module loaded
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V1.0
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
usbmon: debugfs is not available
Mstar-ehci-2 H.W init
Titania3_later_start_ehc2 start
Mstar-ehci-2 Mstar-ehci-2.1: Mstar EHCI
Mstar-ehci-2 Mstar-ehci-2.1: new USB bus registered, assigned bus number 1
Mstar-ehci-2 Mstar-ehci-2.1: irq 74, io mem 0xbf201a00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Mstar EHCI
usb usb1: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb1: SerialNumber: mstar
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mstar-ehci-1 H.W init
Titania3_later_start_ehc1 start
Mstar-ehci-1 Mstar-ehci-1.0: Mstar EHCI
Mstar-ehci-1 Mstar-ehci-1.0: new USB bus registered, assigned bus number 2
Mstar-ehci-1 Mstar-ehci-1.0: irq 15, io mem 0xbf204800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Mstar EHCI
usb usb2: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb2: SerialNumber: mstar
====> hub_port_init 1
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
[ PHY Addr ] ==> :1
alloRAM_ADDR_BASE= 0x2D00000  alloRAM_SIZE= 0x100000
After T12 FIX -----------------------------Plug in USB Port2:20
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00020000 : "NPT"
mtd: Giving out device 0 to NPT
0x00020000-0x00120000 : "BL0"
mtd: Giving out device 1 to BL0
0x00120000-0x00220000 : "BL1"
mtd: Giving out device 2 to BL1
0x00220000-0x07220000 : "UBI"
mtd: Giving out device 3 to UBI
0x07220000-0x08000000 : "NA"
mtd: Giving out device 4 to NA
parse_cmdline_partitions: add_mtd_partitions
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
udev->speed: 3
UBIFS error (pid 1): ubifs_recover_leb: corrupt empty space LEB 60:79872, corruption starts at 2711
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 60:2711
UBIFS error (pid 1): ubifs_recover_leb: LEB 60 scanning failed
VFS: Cannot open root device "ubi:RFS" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             128 mtdblock0 (driver?)
1f01            1024 mtdblock1 (driver?)
1f02            1024 mtdblock2 (driver?)
1f03          114688 mtdblock3 (driver?)
1f04           14208 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
发表于: 2015-4-25 17:57:07
5V正常吗?换一下24XX数据试试
 楼主| 发表于: 2015-4-25 19:18:34
minami0760 发表于 2015-4-25 17:57
5V正常吗?换一下24XX数据试试
用户程序?!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于: 2015-4-25 20:30:08
我看了nand有坏块区 多少字节,   没有发现以太网,USB接口初始化失败---找个nand程序在用户菜单内升级吧
 楼主| 发表于: 2015-4-25 22:13:07
现在开机到一个界面就不动了。按键操作无作用,遥控也无效。根本不能进用户菜单操作了。
发表于: 2015-4-25 23:29:07
可能是24C32或24C64内用户数据错可用空白的试一下
 楼主| 发表于: 2015-4-26 17:16:30
问题已解决!谢谢大家的帮助。。。。。。。。。。。。。。。。
发表于: 2015-4-26 17:50:02
怎么解决的发上来大家分享下嘛
发表于: 2015-4-26 18:24:51
是什么问题呀?分享一下吧-----------【是否数据不良啦】
GMT+8, 2024-11-27 06:14 , Processed in 0.054642 sec., 10 queries .
