查看: 12924|回复: 1
EDP接口介绍、定义、与LVDS定义的比较
发表于: 2015-4-11 20:29:08
DisplayPort是一种高清数字显示接口标准,可以连接电脑和显示器,也可以连接电脑和家庭影院。目前市场上部分液晶面板也是Display Port接口(简称DP或EDP接口),这种接口的液晶屏并不是通用的LVDS驱动板可以驱动,需要增加LVDS转EDP板才能完美点亮。
目前市场的EDP屏接口规格主要两种:一种是30pin, 另一种是40pin
EDP信号输出接口定义
Pin  NO.
SYMBOL
DESCRIPTION
1
VCC
Power Supply for EDP Panel(EDP屏供电)
2
VCC
3
GND
Ground
4
GND
5
AUX-
Display  Port AUX - channel negative signal
6
AUX+
Display  Port AUX + channel Positive signal
7
GND
Ground
8
GND
9
D3-
Display  Port Lane 3 negative output
10
D3+
Display  Port Lane 3 Positive output
11
D2-
Display  Port Lane 2 negative output
12
D2+
Display  Port Lane 2 Positive output
13
D1-
Display  Port Lane 1 negative output
14
D1+
Display  Port Lane 1 Positive output
15
D0-
Display Port Lane 0 negative output
16
D0+
Display Port Lane 0 Positive output
17
GND
Ground
18
GND
19
3V3
3.3V  OUTPUT
20
HPD
Hot  Plug
LVDS 屏接口的定义
Pin  NO.
SYMBOL
DESCRIPTION
1
PVCC
Power Supply for  EDP board
EDP板供电输入
2
PVCC
3
PVCC
4
GND
Ground
5
GND
6
GND
7
RXO0-
LVDS ODD 0- Signal
8
RXO0+
LVDS ODD 0+ Signal
9
RXO1-
LVDS ODD 1- Signal
10
RXO1+
LVDS ODD 1+ Signal
11
RXO2-
LVDS ODD 2- Signal
12
RXO2+
LVDS ODD 2+ Signal
13
GND
Ground
14
GND
15
RXOC-
LVDS ODD Clock- Signal
16
RXOC+
LVDS ODD Clock+ Signal
17
RXO3-
LVDS ODD 3- Signal
18
RXO3+
LVDS ODD 3+ Signal
19
RXE0-
LVDS EVEN 0- Signal
20
RXE0+
LVDS EVEN 0+ Signal
21
RXE1-
LVDS EVEN 1- Signal
22
RXE1+
LVDS EVEN 1+ Signal
23
RXE2-
LVDS EVEN 2- Signal
24
RXE2+
LVDS EVEN 2+ Signal
25
GND
Ground
26
GND
27
RXEC-
LVDS EVEN Clock- Signal
28
RXEC+
LVDS EVEN Clock+ Signal
29
RXE3-
LVDS EVEN 3- Signal
30
RXE3+
LVDS EVEN 3+ Signal
31
GND
Ground
32
GND
33
NC
No Connect
34
NC
No Connect
35
SCL
I2C SCL
36
SDA
I2C SDA
37
RXO4-
LVDS ODD 4- Signal
38
RXO4+
LVDS ODD 4+ Signal
39
RXE4-
LVDS EVEN 4- Signal
40
RXE4+
LVDS EVEN 4+ Signal
发表于: 2015-4-12 09:44:08
这些都是宝贵资料啊,学习一下啊
GMT+8, 2024-12-19 23:32 , Processed in 0.058238 sec., 13 queries .
