查看: 5006|回复: 6
海信LED32K300程序
发表于: 2015-3-5 09:35:49
用809F读取海信LED32K300程序,主板号:RSAG7.820.4801屏号:HE315FH-E38/PW1闪存;25Q32
下面是LED32K300打印信息看不懂是什么意思,有看懂了的给解释一下谢谢
2015-3-5, 9:13:43
COM4, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
  SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB  - DDR2 800MHz
BIST_0 PASS.
77
[123456789ABC][123456789ABC]
0066
MIU Initial OK
sar input test...
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
pnl type=1 => xc lpll type=1
GE_SetOnePixelMode
s8SN0(10) s8SN1(F)
g_u8DCOnOff = ON
Disable Aeon
Disable Aeon Done
DSP code loaded successfully
FORCE sub window blue screen OFF
INIT MoZuPanelSelect: 0
INIT FactoryReset: 44
========= CUS04_ATV_MM_M10 =========
DVB-T Software Version: 0.305665
[Board]: BD_MST6M182VG_HISENSE
[Panel]: HE315FH_E38
[Tuner]: HFT_96_T116H
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[ENABLE_POWERON_MUSIC]
-------------->show alert window
发表于: 2016-10-30 18:55:13
正好用上,写入开机正常,谢谢。
发表于: 2016-12-22 19:22:35
谢谢楼主的分享
发表于: 2017-2-8 17:45:54
下载了谢谢了
发表于: 2017-9-21 22:18:53
谢谢楼主提供!!
GMT+8, 2024-12-25 01:05 , Processed in 0.057006 sec., 12 queries .
