查看: 8149|回复: 11
三洋42CE530BLED板号T.MS18VG.72(T.VST59.A5)25Q32屏T420HW09-V2
发表于: 2015-2-3 08:26:16
红灯亮不开机,按键遥控无反应,电源板只有5v,主板只有5v和3.3v,先软后硬,重写数据正常
发表于: 2015-5-30 14:36:56
谢谢楼主,重写后机子能开机了.
发表于: 2015-6-3 13:11:06
此机好像是TCL代工的  呵呵呵
发表于: 2015-7-11 15:49:11
HI GUYZ PLEASE ASSIST
I am having a problem ..i have connect my programmer via the VGA isp port and when i try write..this is what i get:
Programmer Firmware Version : V1.0 .
002:  Auto ISP...
003:  Scanning VGA port with wire mode A...
004:  MSTAR, MST/TSUM/SE/FE series, external flash.
005:  Current selected : MST_EXT_SPI #ISP,Size: 128Mbits,16MBytes.
006:  >------------------------------------OK---------------------------------------<
007:  C:\USERS\HP\DESKTOP\T.MS18VG.72(T.VST59.A5)25Q32|-T420HW09-V2.BIN
008:  File loading OK. Checksum: 16bit_0xBB53,32bit_0xE4A6BB53;
009:  VGA wire mode: SCL: VGA--15; SDA: VGA--12.
010:  Main Chip Name: TSUMV29/39/59 .
011:  SPI Flash : W25Q32, Buffer Set to 4MBytes.StatusReg: 0x8C.
012:  Programming device......
013:  Auto erasing...
014:  --> Unprotect failure.Please check the level of WP-Pin.
015:  Write error occurred,Operation was aborted
what could i have done wrong please assist..
发表于: 2016-6-13 16:03:59
I am having a problem ..i have connect my programmer via the VGA isp port an ...
bin可以从工厂模式升级呀,干嘛要这样
发表于: 2016-6-13 18:51:32
谢谢楼主好资料修炼了
发表于: 2016-7-19 19:37:33
谢谢我下载了
发表于: 2016-8-10 07:39:44
谢谢楼主的分享
发表于: 2018-4-28 22:40:42
谢谢 分享。下载 使用 修机...
发表于: 2018-6-22 13:27:15
谢谢楼主数据分享!
GMT+8, 2024-12-22 21:00 , Processed in 0.061119 sec., 11 queries .
