查看: 13466|回复: 5
康佳35016105 981C机芯正常打印信息,线序:RXD: VGA->12,TXD: VGA->15
发表于: 2014-11-25 10:54:29
2014-11-19, 18:2:28
COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
[3456789AB]
[456789ABC]-78
_U
Hello U-Boot
U-Boot 1.1.6 (Jan 17 2013 - 09:55:36)
Board: MSTAR AMBER1 (CPU Speed 576 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO OSD ENV=SERIAL
Flash is detected (0x0707, 0xEF, 0x40, 0x14)
MDrv_SERFLASH_GetInfo()
u32AccessWidth = 1
u32TotalSize   = 1048576
u32SecNum      = 16
u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0xEC, ID = 0xDA
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100421604TH0000000T
EnvFlag =: 0xEFE2AE66.....CONFIG_ENV_ADDR=: 0xE0000
cbuffer[0] =:0xFF...cbuffer[1] =:0xFF...cbuffer[11] =:0xFF
Check USB port[0]:
Check USB port[1]:
keypad_pressed_1 is:0
[0]adc_val =:0xFF
keypad_pressed_2 is:0
--> ac boot <--
keypad_pressed is [0]
ir_pressed is [0]
targetFlag=======================[0]
Hit any key to stop autoboot:  3  2  1  0
0x00680000-0x0FB80000 : "mtd=3"
ubi part UBI success
Using volume PNL
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 5, name "PNL"
UBIFS: mounted read-only
UBIFS: file system size:   2920448 bytes (2852 KiB, 2 MiB, 23 LEBs)
UBIFS: journal size:       1142785 bytes (1116 KiB, 1 MiB, 8 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root:  0 bytes (0 KiB)
ubifs_mount SUCCESS !!
ubifsmount partitin success
LED43IS97N(4BOM)(MSD6I981C)正常打印信息.rar
11.13 KB, 阅读权限: 70, 下载次数: 17, 下载积分: 金钱 -10
发表于: 2014-11-25 10:59:23
谢谢超版的经验分享,您辛苦了!
发表于: 2015-2-12 22:48:47
这个,怎么看,能都翻译成中问吗
发表于: 2015-3-18 12:21:14
上面打印信息没看到自身硬件自检
发表于: 2017-2-16 19:11:57
谢谢超版的经验分享,您辛苦了!
发表于: 2017-2-22 05:34:55 来自手机
路过。学习,,学习,,,
GMT+8, 2024-12-21 14:20 , Processed in 0.057318 sec., 12 queries .
