查看: 21476|回复: 17
809F编程器的打印信息不能用???
发表于: 2014-10-23 14:53:35
打印信息怎么设置,主机名任意取什么都可以吗
 楼主| 发表于: 2014-10-23 14:56:46
怎么解决连接失败原因
发表于: 2014-10-23 19:48:28
应该是你的设置有误 请看下面的2个图 希望能你
发表于: 2014-10-24 13:35:06
学习学习,是不是要保留自己刷的信息所以要打印?
发表于: 2014-10-24 14:07:01
回复的够水,自己还是先看看论坛上有关打印信息的资料吧
 楼主| 发表于: 2014-10-25 13:49:25
RTD2692D的芯片没有打不出信息吗
发表于: 2014-10-26 14:29:58
在主界面自动识别ISP,然后断电,然后点串口打印,3秒内上电,打印信息就出来了。
 楼主| 发表于: 2014-10-26 20:11:28
断电是电视断电还是809断电
 楼主| 发表于: 2014-10-27 10:16:02
很难打出来,下面是创维32E20RN (8R61机芯正常信息)
Nand Flash Vendor : Hynix
Page Size = 2112
Block # of Page = 64
NandImageRead : dwLogicalAddress = 0x00600000 read image fail.
Load kernel from 0x01000000
81a28000 81a30000
dlmem_initdo_fhd_frc....
MCPU BISR PASSdlmem_init<5>Creating 1 MTD partitions on "NANDemul2k":
<5>0x00000000-0x00040000 : "NANDemul partition 1"
Nand Flash DevID  : 0xf1
Page Size = 2112
Spare Size Per Page = 64
NfMtdProbe : Writesize = 0x800 , Erasesize = 0x20000
<5>Creating 1 MTD partitions on "Realtek NAND Flash Controller":
<5>0x02000000-0x02600000 : "Realtek NAND Flash Partition 2"
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Board init
unzipper: VGA EDID 3 install fail
unzipper: HDMI1 EDID 0 install fail
unzipper: HDMI2 EDID 1 install fail
unzipper: HDMI3 EDID 2 install fail
All BISR are finished!
oliver+ Play Boot music
-->aaaaaa fileId=0
read from factory,power_on_music_volume=15
start to go Kernel...
Linux version 2.6.23 (lxf@localhost.localdomain) (gcc version 4.1.2-1.4.3) #258 Tue Dec 20 04:18:29 EST 2011
CPU revision is: 0000cd01
Determined physical RAM map:
memory: 01700000 @ 00000000 (usable)
memory: 04000000 @ 0c000000 (usable)
Built 1 zonelists in Zone order.  Total pages: 65024
Kernel command line: root=/dev/ram console=0 ramdisk_start=0 load_ramdisk=1 single
icache: 16kB/32B, dcache: 16kB/32B, scache: 0kB/0B
Synthesized TLB refill handler (17 instructions).
Synthesized TLB load handler fastpath (31 instructions).
Synthesized TLB store handler fastpath (31 instructions).
Synthesized TLB modify handler fastpath (25 instructions).
PID hash table entries: 1024 (order: 10, 4096 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 82048k/89088k available (3319k kernel code, 6936k reserved, 896k data, 332k init, 0k highmem)
NET: Registered protocol family 16
SCSI subsystem initialized
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
unpack to rootfs
Register gdeMapper device, Major[254] Minor[0]
Register mapper device, Major[253] Minor[0]
squashfs: version 3.4 (2008/08/26) Phillip Lougher
NTFS driver 2.1.28 [Flags: R/O].
yaffs Dec 20 2011 04:15:44 Installing.
io scheduler noop registered (default)
busTO.o: bus timeout warning quipped.
kSocket.o: kSocket entries driver module
Register kSocket_devno device, Major[252] Minor[0]
User[0x1] register kernel's watch dog, timeout is [0x1388]
init watchdog thread: 66, prio:1 , ret:0
Register watchdog device, Major[251] Minor[0]
Register Transport device, Major[249] Minor[0]
Testing Transport Driver Initialization
Register FSCON device, Major[248] Minor[0]
[AUDIO][DRV] audio de-pop finish!
avp_PresentDrv.o:AV Present entries driver module
[AVP_DRV] dev_major=f4, dev_minor=0
Disable DDS[18007000]
Register OSD device, Major[243] Minor[0]
hdmiRxDrv.o:  HDMI RX driver module
hdmiRxDrv, Major[242] Minor[0]
md_dev_init
usbcore: registered new interface driver r871x_usb_drv
vgefb_init register frame buffer
fb0: VgeFB frame buffer device
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0x11320 (irq = 4) is a 8250
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
Page Size = 2112
NandImageRead : dwLogicalAddress = 0x600000 read image fail.
realtek_nandFlash_rom_read [Error] : Read data fail.
realtek_nandFlash_rom_read : Use the default booting partition
Creating 3 MTD partitions on "Realtek NAND Flash Controller":
0x02800000-0x05000000 : "Realtek NAND Flash Partition 0"
0x01000000-0x01800000 : "Realtek NAND Flash Partition 1"
eth0: RTL-8139C+ at 0xb8016000, 00:00:00:00:00:00, IRQ 10
Register miscellaneous device, Major[240] Minor[0]
rtk_dmp-ehci rtk_dmp-ehci: Rtk Dmp EHCI
rtk_dmp-ehci rtk_dmp-ehci: new USB bus registered, assigned bus number 1
rtk_dmp-ehci rtk_dmp-ehci: irq 11, io mem 0xb8013000
rtk_dmp-ehci rtk_dmp-ehci: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
rtk_dmp-ohci rtk_dmp-ohci: Rtk Dmp OHCI
rtk_dmp-ohci rtk_dmp-ohci: new USB bus registered, assigned bus number 2
rtk_dmp-ohci rtk_dmp-ohci: irq 11, io mem 0xb8013400
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
TCP cubic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
*** VGE Drv 2.0 ****
bank:[0],size:[78643200],base addr:[5780000]
bank:[1],size:[30932992],base addr:[a280000]
Kernel_OpenVGESocket 536
Open Netlink Socket OK!!
Open Netlink RMP Socket OK!!
Open Netlink Audio Socket OK!!
Freeing unused kernel memory: 332k freed
Mounted /dev/mtdblock/0 on /data
Mounted /dev/mtdblock/2 on /factory
TC_WR_CR_VADDR is 80000001
TC_WR_TR_VADDR is 0
TC_WR_MR_VADDR is 0
init started:  BusyBox v1.1.3 (2011.01.12-08:18+0000) multi-call binary
Starting pid 109, console /dev/ttyS0: '/bin/sh'
BusyBox v1.1.3 (2011.01.12-08:18+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
time(seconds)        unlimited
file(blocks)         unlimited
data(kbytes)         unlimited
stack(kbytes)        8192
coredump(blocks)     100
memory(kbytes)       unlimited
locked memory(kbytes) 32
process              696
nofiles              1024
vmemory(kbytes)      unlimited
locks                unlimited
mkdir: Cannot create directory `run': File exists
mkdir: Cannot create directory `wpa_supplicant': File exists
eth0: Promiscuous mode disabled.
ADDRCONF(NETDEV_UP): eth0: link is not ready
link down
xInitUnzipPara:panel parameter form file.
--->fileId=5
-->cnt=40149  ,  buf=40149
xInitUnzipPara:panel vip data form file.
enter scalerIRQ_init
CONFIG_VGIP_IN_MAIN_CPU   scalerIRQ_vgipInit()
Trying to free already-free IRQ 7
wdg_private_open
User Register watch dog, threshold[10000]
User[0x2] register kernel's watch dog, timeout is [0x3e8]
Create netlink socket ok and id:[10]
Bind netlink socket ok
NLsocket id:[11]
   eprom channel start add  = 0x180 ,EEP_AD_SYS_IDENT1 add =0x881
   EEP_AD_HDCPKEY add = 39
   size COOCA_SYS_SIZE = 70 ,
   EEP_AD_COOCASYS_SET = 0xdfc
   EEP_AD_SYS_IDENT2 = 0xeaf
g_setup.misc add = 0x884
   EEP_AD_USED_END = 0xeb0
==SrEprom_check 730==
Load  eprom ok    eth0: Promiscuous mode disabled.
cp_close***************************************
cp_stop_hw *********************************
-->fileId=12
read from factory,vol table by src
->volTableAtv{...-65,-33}
->volTableDtv{...-96,-8}
->volTableAv{...-14,15}
->volTableSv{...-14,15}
->volTableYpp{...-14,15}
->volTableVga{...-14,15}
->volTableHdmi{...-30,-5}
->volTableUSB{...-90,-60}
drv mmap 8192
ioctl cmd=0x3, arg=0x7f5ffa18
[user land] CmdBuf virt addr = 2aaa8000, phy addr = fc28000
========== Uart Disable ==========
 hide printf
发表于: 2014-10-27 10:59:19
http://www.ifix.net.cn/thread-3722-1-1.html
注意:只要电视板卡输出了打印信息,809F就能接收到。使用者能否看到打印信息,关键看两点:
1、板卡确实输出了打印信息;早期的电视主板根本没有输出打印信息,自然看不到;
2、使用者设定了正确的线序和波特率,并给板卡重新加电;
打印信息功能,没有那么神秘,对于编程器而言,只是一个USB转串口TTL,接收字符的功能,搞不定去检查板卡和自己的操作,而没有必要质疑编程器是否支持。重新设定线序和波特率以后,必须给板卡断电,等电容放完电后再加电,很多新手栽在不知道打印信息只在加电后那段时间才有。
GMT+8, 2024-12-26 15:17 , Processed in 0.066976 sec., 13 queries .
