发表于: 2015-10-24 22:46:27
显示全部楼层
我想问一下智能电视的屏驱动是在 引导程序还是在主程序里 我的长虹3D55C2000I强制升级后屏上显示各种颜色的竖彩条
下面是打印信息
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 67), Size=66, Mid=36, Set=26.
Byte 1 : Gating(2 ~ 62), Size=61, Mid=34, Set=24.
Byte 2 : Gating(2 ~ 82), Size=81, Mid=44, Set=34.
Byte 3 : Gating(2 ~ 77), Size=76, Mid=41, Set=31.
HW Byte 0 : DQS(10 ~ 43), Size 34, Set 25, HW_Set 27.
HW Byte 1 : DQS(8 ~ 41), Size 34, Set 23, HW_Set 26.
HW Byte 2 : DQS(11 ~ 35), Size 25, Set 23, HW_Set 24.
HW Byte 3 : DQS(11 ~ 36), Size 26, Set 23, HW_Set 25.
DRAM A Size = 768 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x807bcf9f
:0x473af81e
:0x4d433032
:0xfe014e4d
LZHS addr:0x00100040
LZHS size:0x000999c0
LZHS checksum:0x0000008b
Boot
Start Lmain
MT5880 Boot Loader v0.10 //mt5880引导装载程序v0.10
Boot reason: A/C power on!!
Load HDMI internal EDID.................
CEC Physical offset 159
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0x52
HDMI2 PA 0x10
HDMI2 checksum 0x52
HDMI3 PA 0x20
HDMI3 checksum 0x42
HDMI4 PA 0x30
HDMI4 checksum 0x32
SIF_Master0: new design
IR DATA register : 0x 0
T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x d6af50, size: 24576)success!!
T8032 FW version: 81
LDR_FlashCopy 0xf010 0x4cc00 0x80
1st MAC in EEP is invalid! (ff:ff:ff:ff:ff:ff)
Both MAC in EEP is invalid! Need write by cli mac
1st : (ff:ff:ff:ff:ff:ff), checksum(ff) error
2nd : (9f:01:f2:b2:b3:10), checksum(fb) error
EEPEtherMAC_Read() fail -1
Use default Eth MAC address: 00:0c:e7:06:00:00 \\使用默认的MAC地址:00:0c:e7:06:00:00
PDWNC_Init
GPIO_MtkLedCtrlFunc_eLedStatus=1
Enable Led blinking (gpio_idx 201, on_value 1, period 20, type: 80)\\使LED闪烁(gpio_idx on_value 201,1,20期,类型:80)
USB0: Set GPIO64 = 1.
USB1: Set GPIO64 = 1.
USB2: Set GPIO61 = 1.
Do USB upgrade \\做USB升级
USB: Vbus turn up time = 436 ms, Max =0 ms.\\VBUS打开时间= 436毫秒,最大值为0毫秒。
No USB device. \\没有任何USB设备。
USB upgrade stop \\USB升级停止
eepNptv offset: 0x260, EEP_BOOT_LOGO_INDEX offset: 0x91
Read boot logo index from eeprom: 255, 0xff
Load boot logo index: 0
下面是我用百度翻译的
引导—
DRAM通道校准。
字节0:门(2 - 67),大小= 66,中= 36,设置= 26。
字节1:门(2 - 62),大小= 61,中= 34,设置= 24。
字节2:门(2 - 82),大小= 81,中= 44,设置= 34。
字节3:门(2 - 77),大小= 76,中= 41,设置= 31。
HW字节0:DQS(10 ~ 43),大小34,25,27 hw_set。
HW字节1:DQS(8 ~ 41),大小34,23,26 hw_set。
HW字节2:DQS(11 ~ 35),大小25,23,24 hw_set。
HW字节3:DQS(11 ~ 36),大小26,23,25 hw_set。
一个大小为768 MB DRAM。
启动
开始pmain
0x0000a000
eMMC启动
CID:0x807bcf9f
:0x473af81e
:0x4d433032
:0xfe014e4d
lzhs地址:0x00100040
lzhs尺寸:0x000999c0
lzhs校验:0x0000008b
启动
开始lmain
mt5880 Boot Loader v0.10 / mt5880引导装载程序v0.10
开机原因:一个/电源的!!
VGA EDID .................内部负荷
HDMI EDID .................内部负荷
CEC物理偏移159
hdmi1物理ADR 0x10
hdmi1 PA 0x10
hdmi1校验0x52
HDMI2 PA 0x10
0x52 HDMI2校验
hdmi3 PA 0x20
hdmi3校验0x42
hdmi4 PA 0x30
hdmi4校验0x32
sif_master0:新设计
红外数据寄存器:0x 0
开机原因:一个/电源的!!
t8032 init的A / C对装载机阶段…
负载t8032 FW(地址:0x%2 d6af50,尺寸:24576)成功!!
t8032固件版本:81
t8032改变装载阶段…
ldr_flashcopy 0xf010 0x4cc00 0x80
在EEP第一MAC无效!(FF FF FF FF:::::FF FF)
无论是MAC在EEP是无效的!需要通过CLI MAC写
第一:(FF FF FF FF:::::FF FF),校验和(FF)误差
第二:(9F:01:F2:B2:b3:10),校验和(FB)误差
eepethermac_read()失败- 1
使用默认的MAC地址:00:0c:e7:06:00:00 ETH
开机原因:一个/电源的!!
开机原因:一个/电源的!!
开机原因:一个/电源的!!
开机原因:一个/电源的!!
pdwnc_init
开机原因:一个/电源的!!
gpio_mtkledctrlfunc_eledstatus = 1
USB0:集gpio64 = 1。
USB1:集gpio64 = 1。
USB2:集gpio61 = 1。
做USB升级
USB:VBUS打开时间= 436毫秒,最大值为0毫秒。
任何USB设备。
USB升级停止
eepnptv偏移:0x260,eep_boot_logo_index偏移:0x91
读引导标识指数从EEPROM:255,0xFF
负荷启动标识指数:0
开机原因:一个/电源的!!
这里是长虹智能电视的升级软件(引导程序和主程序)需要的朋友可以去下载
链接:http://pan.baidu.com/s/1qW9XKx2 密码:4ln2
