查看: 16007|回复: 13
求 51Pin LVDS 屏线 脚位排序定义
发表于: 2014-5-18 11:13:25
现有一台康佳47寸LED为60HZ的单排线,接口类型为51Pin,换了一张120HZ的屏,用乐华120HZ的转接板,经过挑屏线至120HZ转接板,现在的情况是满屏花,好像时钟乱序,实在没办法求助,望赐教!
原屏型号为:LC470EUN SD F1
发表于: 2014-5-18 11:36:23
只有找到屏规格书,才能干活吧。
发表于: 2014-6-1 09:13:10
Full_HD 屏(51Pin)接口定义(包含 3D)
Pin No.
Symbol
Dscription
备注
1
WP
Write enable
内部调试
2
SCL
SCL
当作Vcc时I2C使用
8、9pin
3
SDA
SDA
4
自检模式
拉高为3.3V时显示flicker图卡自检模式
内部调试
5
L/R_Out
Output signal for Left Right Glasses
control
SG同步信号
输出
6
B/L_Out
Backlight on/off control to B/L Driver
(H:B/L off;L:B/L on)
3D背光控制
信号
7
LVDS_SL
LVDS Data Format Selection
(H:JEIDA L:VESA)
8
PWM_In
Extemal PWM (from System)
使用屏调光功能时
使用
9
PWM_Out
PWM Out to System(Power Board)
10
LOCAL DIMM
H=Enable; L=Disable
调光功能开关
11
GND
GND
12
ERX0-
First pixel Negative LVDS Pair0
13
ERX0+
First pixel Positive LVDS Pair0
14
ERX1-
First pixel Negative LVDS Pair1
15
ERX1+
First pixel Positive LVDS Pair1
16
ERX2-
First pixel Negative LVDS Pair2
17
ERX2+
First pixel Positive LVDS Pair2
18
GND
GND
19
ECLK-
First pixel Negative of clock
20
ECLK+
First pixel Positive of clock
21
GND
Ground
22
ERX3-
First pixel Negative LVDS Pair3
23
ERX3+
First pixel Positive LVDS Pair3
24
ERX4-
First pixel Negative LVDS Pair4
25
ERX4+
First pixel Positive LVDS Pair4
26
2D/3D
Input signal for 2D/3D Mode Selection
2D/3D模式切换
27
L/R_In
Input signal for Left Right eye frame
synchronous
L/R帧同步信号
28
ORX0-
Second pixel Negative LVDS Pair0
29
ORX0+
Second pixel Positive LVDS Pair0
30
ORX1-
Second pixel Negative LVDS Pair1
31
ORX1+
Second pixel Positive LVDS Pair1
32
ORX2-
Second pixel Negative LVDS Pair2
33
ORX2+
Second pixel Positive LVDS Pair2
34
GND
GND
35
OCLK-
Second pixel Negative of clock
36
OCLK+
Second pixel Positive of clock
37
GND
Ground
38
ORX3-
Second pixel Negative LVDS Pair3
39
ORX3+
Second pixel Positive LVDS Pair3
40
ORX4-
Second pixel Negative LVDS Pair4
41
ORX4+
Second pixel Positive LVDS Pair4
42
NC
No Connection
43
Bit_SELE
Bit Select(L: LOW H:HIGH)
色深选择
44
GND
Ground
45
GND
Ground
46
GND
Ground
47
NC
No Connection
48
Vcc
+12V Power supply
49
Vcc
+12V Power supply
50
Vcc
+12V Power supply
51
Vcc
+12V Power supply
接口形态:FI-RE51S-HF(JAE/UJU)
发表于: 2014-6-1 09:14:02
120Hz 屏(51Pin+41Pin)接口定义
Pin No.
Symbol
Dscription
备注
1
WP
Write enable
内部调试
2
SCL
SCL
3
SDA
SDA
4
自检模式
内部调试
5
L/R_Out
Output signal for Left Right Glasses control
SG同步信号
输出
6
B/L_Out
Backlight on/off control to B/L Driver (H:B/L
off;L:B/L on)
3D背光控制
信号
7
LVDS_SL
LVDS Data Format Selection(H:JEIDA L:VESA)
8
PWM_In
使用屏调光功能
时使用
9
PWM_Out
10
LOCAL DIMM
H=Enable; L=Disable
调光功能开关
11
GND
GND
12
ERX0-
13
ERX0+
14
ERX1-
15
ERX1+
16
ERX2-
17
ERX2+
18
GND
GND
19
ECLK-
20
ECLK+
21
GND
Ground
22
ERX3-
23
ERX3+
24
ERX4-
25
ERX4+
26
2D/3D
2D/3D模式切换
27
L/R_In
synchronous
L/R帧同步信号
28
ORX0-
29
ORX0+
30
ORX1-
31
ORX1+
32
ORX2-
33
ORX2+
34
GND
GND
35
OCLK-
36
OCLK+
37
GND
Ground
38
ORX3-
39
ORX3+
40
ORX4-
41
ORX4+
42
NC
No Connection
43
Bit_SELE
色深选择
44
GND
Ground
45
GND
Ground
46
GND
Ground
47
NC
No Connection
48
Vcc
+12V Power supply
49
Vcc
+12V Power supply
50
Vcc
+12V Power supply
51
Vcc
+12V Power supply
Pin No.
Symbol
Dscription
备注
1
NC
No Connection
2
NC
No Connection
3
NC
No Connection
4
NC
No Connection
5
NC
No Connection
6
NC
No Connection
7
NC
No Connection
8
NC
No Connection
9
GND
GND
10
ERX0-
11
ERX0+
12
ERX1-
13
ERX1+
14
ERX2-
15
ERX2+
16
GND
GND
17
ECLK-
18
ECLK+
19
GND
Ground
20
ERX3-
21
ERX3+
22
ERX4-
23
ERX4+
24
NC
No Connection
25
NC
No Connection
26
ORX0-
27
ORX0+
28
ORX1-
29
ORX1+
30
ORX2-
31
ORX2+
32
GND
GND
33
OCLK-
34
OCLK+
35
GND
Ground
36
ORX3-
37
ORX3+
38
ORX4-
39
ORX4+
40
NC
No Connection
41
NC
No Connection
接口形态:FI-RE51S-HF 和 FI-RE41S-HF(JAE/UJU)
发表于: 2014-6-2 16:14:52
唉,有点复杂呀,不太好看
发表于: 2014-6-7 11:54:35
复杂啊看不懂
 楼主| 发表于: 2014-6-11 18:23:40
结果出来了,这个主板不没有120HZ的程序,首先必须要主板程序支持120HZ,再用转接板就可以了;
谢谢大家的帮助;
发表于: 2016-12-16 19:46:11
谢谢 楼主分享数据
发表于: 2017-4-8 15:33:29
数据给力  谢谢   分享
发表于: 2017-4-26 11:22:25
Panel_LG_Display_LC470EUN-SDV1_0_[DS]
GMT+8, 2024-12-22 01:38 , Processed in 0.059928 sec., 11 queries .
