楼主: admin
RT809F使用教程 —— TCL MS801机芯MSD6A801_W25Q16在线读写和串口打印方法
发表于: 2017-12-3 14:52:50
一台海信LED42K01P读取校验错误,ISP速度调到哪一档都没有用,请教各位大师怎么办?
发表于: 2018-1-31 11:35:47
插上我的万能通用ban把我引到这里学习,太好了谢谢!
发表于: 2018-2-4 21:41:19
UART_115200
BIST0-OK
BIST1-OK
_U
Hello U-Boot
U-Boot 1.1.6 (Mar 17 2011 - 05:38:59)
Board: MSTAR TITANIA13 (CPU Speed 504 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: USB FAT NAND UBI UBIFS NET SPI STANDBY JFFS2 LOGO ENV=SERIAL
Flash is detected (0x0A02, 0x1C, 0x31, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100208768TH0000000T
EnvFlag =:192.....CONFIG_ENV_ADDR=:1E0000
0x00400000-0x0F700000 : "mtd=1"
Using volume CONFIG
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 3, name "CONFIG"
UBIFS: mounted read-only
UBIFS: file system size:   17649664 bytes (17236 KiB, 16 MiB, 139 LEBs)
UBIFS: journal size:       2666496 bytes (2604 KiB, 2 MiB, 21 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root:  0 bytes (0 KiB)
ubifs_mount SUCCESS !!
Using filename /
<DIR>                                <DIR>                <DIR>                        <DIR>                <DIR>
Mount Config 0
ubifs_filesize  00000A9A
Loading file 'sys.ini' to address 0x80400000 (size 2714)
Loading file 'sys.ini' to addr 0x80400000 with size 2714 (0x00000A9A)...
Done
獌?Ι?惎伐矂?畭奌ello PM51...
Hello Main
HAL_MB_Unmask_Cpu3_2_Cpu0
@@MDRV_PM:[00] = 46
@@MDRV_PM:[01] = d5
@@MDRV_PM:[02] = ff
@@MDRV_PM:[03] = ff
@@MDRV_PM:[04] = ff
@@MDRV_PM:[05] = ff
@@MDRV_PM:[06] = ff
@@MDRV_PM:[07] = ff
HAL_PM_DisableWkEventGPIO0
HAL_PM_DisableWkEventGPIO1
HAL_PM_DisableWkEventUart1
HAL_PM_EnableWkEventRtc0
HAL_PM_DisableWkEventRtc1
HAL_PM_DisableWkEventDVI0
HAL_PM_DisableWkEventDVI2
HAL_PM_DisableWkEventCEC
avlink_init done
HAL_PM_DisableWkEventAvlink
HAL_PM_EnablePmSleepInt
HAL_PM_WakeupFromZero
HAL_PM_EnableWkEventSAR
HAL_PM_EnableWkEventIr
_MDrv_PM_PowerDown2Standby
发表于: 2018-5-14 15:07:09
数据重组怎么知道开始位置和结束位置呢,一般液晶彩电刷机都需要这个步骤吗
发表于: 2018-5-20 14:14:24
下来学习下
发表于: 2018-7-19 10:01:34
请教一下TCL MS801机芯_MS80104版本第050版本V8-MS80104-LF1V050的有没,刷机后停在这画面就不运行了,找了好多的数据都搞不定。要吗老是在升级中,几个小时,要吗在台标就不动了。要吗就运行停止,求救!!
jing9981 该用户已被删除
发表于: 2018-8-16 21:53:56
提示: 作者被禁止或删除 内容自动屏蔽
发表于: 2018-11-1 18:11:12
85:  -->存储器写保护解除失败,请按以下步骤处理:
186:  -->1、按开关键将板卡置于待机状态再写入;
187:  -->2、使用MST官方软件,将“设置”里的“串行调试从地址”改为0xB2,
188:  -->      再选中“器件”里的“ISP时WP脚上拉为高电平”,然后写入;
189:  -->3、用镊子接8脚25xx的3、8脚或16脚25xx的2、9脚,然后写入,提示解保护成功即可松开;
190:  -->4、拆下存储器离线擦除后,装回板卡然后ISP。
191:  写入错误,操作终止。
出现这个怎么弄 3和8脚是怎么算
发表于: 2018-11-9 08:53:16
谢谢:):):)
发表于: 2018-11-9 09:33:16
Thank you for your post
GMT+8, 2025-12-15 14:50 , Processed in 0.056064 sec., 12 queries .
