如题 接一台创维32K06RK开机无光 绿灯亮 用809F读取时能联机但是不能识别存储器 主板5800-A8M860-0030 附打印信息如下求大侠帮忙:2003-2-12, 5:16:23
COM7, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
BIST0 OK
BIST1 OK
[0123456789][023456789]-44
[012345678][012345678]-44
BOOT_nPD
U-Boot 1.1.6 (Mar 26 2010 - 20:43:36)
Board: MSTAR EUCLID (CPU Speed 240 MHz)
DRAM: 0x8000000
Flash: 0 kB
NAND: nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x07ee0000
128 MiB
In: serial
Out: serial
Err: serial
Net: No ethernet found.
MSVC00B000100100220054TH0000000T
Change MIU0 select.....
Group0:3000 Group1:e Group2:2a41
Change MIU1 select.....
Group0:0 Group1:0 Group2:2000
cmd: md.b 0x80200000 0x1
80200000: ff .
80200000: 5aa55aff .Z.Z
data_1[1ffa]--->:ff
defatult_set is:165
*ucp is:255
Hit any key to stop autoboot: 0
cmd: md.b 0x874bfef8 0x1
874bfef8: 00 .
cmd: md.b 0x874bfef9 0x1
874bfef9: 00 .
0x00020000-0x07920000 : "mtd=1"
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
Image Name: Linux-2.6.28.10-mstar
Created: 2010-05-24 11:54:29 UTC
Image Type: MIPS Linux Kernel Image (lzo compressed)
Data Size: 3352631 Bytes = 3.2 MB
Load Address: 80400000
Entry Point: 80404150
Uncompressing Kernel Image ... OK
Starting kernel ...
L2 enabled
Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #1 PREEMPT Mon May 24 19:53:53 CST 2010
LINUX started...
boot_command_line: console=ttyS0,115200 ubi.mtd=1,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x3300000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x0,0x0 MS_GOP0_MIU=1 mtdparts=edb64M-nand:128k(NPT),121m(UBI),-(NA) MS_HP=0
LX_MEM = 0x400000, 0x3300000
LX_MEM2 = 0x0, 0x0
CPHYSADDR(PFN_ALIGN(&_end))= 0x990000
EMAC_LEN= 0x100000
DRAM_LEN= 0x10000000
console [early0] enabled
CPU revision is: 0001906c (MIPS 4KEc)
Begin Euclid_setup
etermined physical RAM map:
memory: 03300000 @ 00400000 (usable)
Wasting 32768 bytes for tracking 1024 unused pages
Initrd not found or empty - disabling initrd
Zone PFN ranges:
DMA 0x00000400 -> 0x00003700
Normal 0x00003700 -> 0x00003700
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000400 -> 0x00003700
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 12954
Kernel command line: console=ttyS0,115200 ubi.mtd=1,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x3300000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x0,0x0 MS_GOP0_MIU=1 mtdparts=edb64M-nand:128k(NPT),121m(UBI),-(NA) MS_HP=0
alloc ebase: 81069000
Primary instruction cache 8kB, VIPT, 4-way, linesize 16 bytes.
Primary data cache 8kB, 2-way, VIPT, no aliases, linesize 16 bytes
PID hash table entries: 256 (order: 8, 1024 bytes)
CPU freq count = 120000000
CPU frequency 240.00 MHz
console handover: boot [early0] -> real [ttyS0]
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 45968k/52224k available (3841k kernel code, 6188k reserved, 1306k data, 164k init, 0k highmem)
SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 237.56 BogoMIPS (lpj=118784)
Mount-cache hash table entries: 512
net_namespace: 288 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
JFFS2 version 2.2. (NAND)2001-2006 Red Hat, Inc.
fuse init (API version 7.10)
msgmni has been set to 89
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xbf201300 (irq = 8) is a 16550
brd: module loaded
loop: module loaded
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V1.0
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
usbmon: debugfs is not available
Mstar-ehci-2 H.W init
Mstar-ehci-2 Mstar-ehci-2.1: Mstar EHCI
Mstar-ehci-2 Mstar-ehci-2.1: new USB bus registered, assigned bus number 1
Mstar-ehci-2 Mstar-ehci-2.1: irq 74, io mem 0xbf201a00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Mstar EHCI
usb usb1: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb1: SerialNumber: mstar
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mstar-ehci-1 H.W init
Mstar-ehci-1 Mstar-ehci-1.0: Mstar EHCI
Mstar-ehci-1 Mstar-ehci-1.0: new USB bus registered, assigned bus number 2
Mstar-ehci-1 Mstar-ehci-1.0: irq 15, io mem 0xbf204800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Mstar EHCI
usb usb2: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb2: SerialNumber: mstar
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
[ PHY Addr ] ==> :1
alloRAM_ADDR_BASE= 0x3700000 alloRAM_SIZE= 0x100000
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Creating 3 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00020000 : "NPT"
mtd: Giving out device 0 to NPT
0x00020000-0x07920000 : "UBI"
mtd: Giving out device 1 to UBI
0x07920000-0x08000000 : "NA"
mtd: Giving out device 2 to NA
parse_cmdline_partitions: add_mtd_partitions
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x5095b417, read 0x4c35d43d
UBIFS error (pid 1): ubifs_check_node: bad node at LEB 274:63488
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 274:63488
UBIFS error (pid 1): ubifs_recover_leb: LEB 274 scanning failed
VFS: Cannot open root device "ubi:RFS" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00 128 mtdblock0 (driver?)
1f01 123904 mtdblock1 (driver?)
1f02 7040 mtdblock2 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
