用户名  找回密码
查看: 405|回复: 9
康佳电视机打印信息问题
发表于: 2025-3-20 16:14:00
一台康佳电视机卡画面,更换emmc写备份并升级后,查看打印信息始终重复跑下面这段信息是什么原因,哪位大神帮忙看看。
R
U-Boot 2012.07-svn815094 (Jul 07 2015 - 11:08:04)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1 GiB
Watchdog: Enabled
Board: Tv035 2995D 512M_512M Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x07900000
MMC:
emmc:mmc_initial(1) Jul  7 2015 11:08:23
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 90
OEM: 14a
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x07880008
         rtk_eMMC_read blk_addr=0x0000c5b5, data_size=0x00000400, buffer=0x07880210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x07880008
         rtk_eMMC_read blk_addr=0x0000e5b5, data_size=0x00000400, buffer=0x07880210
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x000b6a00, buffer=0x07000000
Factory: seq:0x1fb9, blk:0xc000(pp:0), size:0xb6a00 (to 0x7000000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_BACKLIGHT_VALUE=253
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN not found
[bootparam.c 166]:can't find local_upgrade_en
BOOT_UART_OPEN_CLOSE=0
BOOT_MUSIC_VOL_VALUE=29
BOOT_LOGO_LED_MODE=1
bootparam.bUart = 0R
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1 GiB
Watchdog: Enabled
POWER ON: AC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
串口关闭了  发表于 2025-3-20 18:39
举报
发表于: 2025-3-21 10:45:50
学会应用deepseek:U-Boot 2012.07-svn815094 (2015年7月7日 - 11:08:04)
GPU: BISR测试中...
GPU: BISR测试完成(成功)
SCPU: BISR测试中....
SCPU: BISR测试完成(成功)
CPU: Cortex-A9 双核
媒体: eMMC BP0
MISC: 设置 FUSE_RDY
DRAM: 1 GiB
看门狗: 已启用
主板: Tv035 2995D 512M_512M 主板
电源: 交流电
缓存: 已启用
非缓存区域: 1 MB@0x07900000
MMC:
emmc:mmc_initial(1) 2015年7月7日 11:08:23
RTD299x eMMC: 0
设备: RTD299x eMMC
制造商 ID: 90
OEM: 14a
名称: H4G2a
传输速度: 52000000
读取块长度: 512
MMC 版本: 4.0
高容量: 是
容量: 3.6 GiB
总线宽度: 8-bit
外部参数: MMC 块:0x7c (到 0x9000)
rtk_eMMC_read 块地址=0x0000007c, 数据大小=0x00000800, 缓冲区=0x00009000
工厂: MMC
rtk_eMMC_read 块地址=0x0000c000, 数据大小=0x00000200, 缓冲区=0x07880008
rtk_eMMC_read 块地址=0x0000c5b5, 数据大小=0x00000400, 缓冲区=0x07880210
rtk_eMMC_read 块地址=0x0000e000, 数据大小=0x00000200, 缓冲区=0x07880008
rtk_eMMC_read 块地址=0x0000e5b5, 数据大小=0x00000400, 缓冲区=0x07880210
rtk_eMMC_read 块地址=0x0000c000, 数据大小=0x000b6a00, 缓冲区=0x07000000
工厂: 序列:0x1fb9, 块:0xc000(pp:0), 大小:0xb6a00 (到 0x7000000)
获取启动参数:
------------tmp/factory/bin_panel/000BootParam.h 找到
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
LOCAL_UPGRADE_EN 未找到
[bootparam.c 166]: 找不到 local_upgrade_en
举报
 楼主| 发表于: 2025-3-21 15:44:57
用809H查看提示没有串口调试开关
举报
发表于: 2025-3-21 15:57:16
R
U-Boot 2012.07-svn815094 (编译时间: 2015年7月7日 11:08:04)
GPU : 正在执行BISR测试(内建自修复测试)...
GPU : BISR测试完成(正常)
SCPU: 正在执行BISR测试...
SCPU: BISR测试完成(正常)
CPU  : Cortex-A9 双核
存储介质: eMMC BP0
MISC : 设置FUSE_RDY(熔丝就绪)
DRAM: 1 GiB内存
看门狗: 已启用
主板型号: Tv035 2995D 512M_512M 板
电源状态: 交流供电(AC)
缓存: 已启用
MMC(存储卡):
emmc:mmc_initial(1) 初始化中(时间戳: 2015年7月7日 11:08:23)
RTD299x eMMC: 0
设备: RTD299x eMMC
制造商ID: 90
OEM厂商: 14a
型号: H4G2a
传输速率: 52000000 Hz
读取块长度: 512字节
MMC版本: 4.0
支持高容量: 是
容量: 3.6 GiB
总线宽度: 8-bit
读取外部参数: 从MMC块0x7c读取到地址0x9000
Factory(工厂模式): MMC
         从MMC块0xc000读取数据到地址0x07880008
         从MMC块0xc5b5读取数据到地址0x07880210
         从MMC块0xe000读取数据到地址0x07880008
         从MMC块0xe5b5读取数据到地址0x07880210
         从MMC块0xc000读取0xb6a00字节到地址0x07000000
Factory: 序列号0x1fb9, 块0xc000(pp:0), 大小0xb6a00(写入地址0x7000000)
获取启动参数:
------------在tmp/factory/bin_panel/000BootParam.h中找到参数
BOOT_POWER_ON_MODE=1(开机模式为1)
BOOT_BACKLIGHT_VALUE=253(背光值253)
BOOT_LOGO_ENABLE=1(启用启动Logo)
CUSTOM_VIDEO1_LENG=0(自定义视频1长度为0)
CUSTOM_VIDEO2_LENG=0(自定义视频2长度为0)
BOOT_MUSIC_ENABLE=0(禁用启动音乐)
CUSTOM_AUDIO1_LENG=0(自定义音频1长度为0)
CUSTOM_AUDIO2_LENG=0(自定义音频2长度为0)
未找到LOCAL_UPGRADE_EN参数
[bootparam.c 166]: 无法找到local_upgrade_en
BOOT_UART_OPEN_CLOSE=0(UART调试关闭)
BOOT_MUSIC_VOL_VALUE=29(音乐音量29)
BOOT_LOGO_LED_MODE=1(Logo LED模式1)
bootparam.bUart = 0(UART关闭)
**关键信息总结**
1. **硬件配置**:
   - **CPU**: 双核ARM Cortex-A9
   - **内存**: 1 GiB
   - **存储**: RTD299x芯片的eMMC(3.6 GiB容量,8位总线)
   - **主板**: Tv035 2995D(为智能电视或媒体播放器主板)
2. **启动过程**:
   - GPU和SCPU(协处理器)通过了自检(BISR)。
   - 从eMMC存储中读取了启动参数(如背光值、Logo显示设置)。
   - 检测到部分参数缺失(如`local_upgrade_en`)。
3. **异常迹象**:
   - 日志末尾的 `R` 和重复的U-Boot开头信息表明系统可能处于**重启循环**。
   - 可能的故障点:eMMC读取错误、启动参数损坏或操作系统加载失败。
[b[img]]国亮家电为您敬上,看能不能帮到您。如果依然没有解决问题,您再问。
举报
 楼主| 发表于: 2025-3-21 17:13:00
国亮家电88 2025-3-21 15:57
R
GPU : 正在执行BISR测试(内建自修复测试 ...
这个看的懂,谢谢。更换emmc重新写备份,插U盘串口升级提示成功,查看打印信息还是一样的。
举报
 楼主| 发表于: 2025-3-21 17:27:35
R
你这个是用什么翻译出来的啊?能说一下吗?谢谢!应该不是deepseek吧?:
BOOT_UART_OPEN_CLOSE=1(UART调试打开)
举报
发表于: 2025-3-22 12:41:35
我建议用ail的芯片,你看你的是4.0
设备: RTD299x eMMC
制造商ID: 90
OEM厂商: 14a
型号: H4G2a
传输速率: 52000000 Hz
读取块长度: 512字节
MMC版本: 4.0
支持高容量: 是
容量: 3.6 GiB
举报
发表于: 2025-3-23 10:18:15
1. U-Boot 版本与初始化
text
复制
翻译:U-Boot 版本号为 2012.07-svn815094,编译时间为 2015年7月7日 11:08:04。
说明:U-Boot 是嵌入式设备的通用引导程序,此处显示版本和编译时间,用于调试兼容性问题。
2. GPU/SCPU 自检(BISR)
text
复制
翻译:
GPU 正在进行 BISR(内置自修复)测试...
GPU BISR 测试完成(成功)。
SCPU(系统协处理器)正在进行 BISR 测试...
SCPU BISR 测试完成(成功)。
说明:BISR 是芯片内部存储单元的自动修复机制,测试通过表示硬件无严重缺陷。
3. 硬件配置信息
text
复制
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1 GiB
Watchdog: Enabled
POWER ON: AC
Cache: Enabled
翻译与解析:
CPU:采用 Cortex-A9 双核架构。
存储介质:使用 eMMC BP0(嵌入式存储芯片)。
MISC:已设置 FUSE_RDY(可能指熔断器就绪状态,用于安全启动)。
DRAM:动态内存容量为 1 GiB。
看门狗:已启用(防止系统死机)。
主板型号:Tv035 2995D 512M_512M,可能为定制电视主板。
电源模式:通过 交流电(AC) 供电。
缓存:已启用(加速数据访问)。
非缓存区域:保留 1 MB 内存(地址 0x07900000),通常用于直接内存访问(DMA)操作。
4. eMMC 存储初始化
text
复制
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 8-bit
翻译与解析:
MMC 初始化:
初始化时间:2015年7月7日 11:08:23。
芯片型号:Realtek RTD299x eMMC(常用于智能电视或机顶盒)。
制造商 ID:90(对应厂商代码,例如海力士)。
OEM:14a(原始设备制造商标识)。
名称:H4G2a(存储芯片型号)。
传输速率:52 MHz(52,000,000 Hz)。
块读取长度:512 字节(标准块大小)。
MMC 版本:4.0(支持高容量和高速传输)。
高容量支持:是(容量 > 2 GB)。
实际容量:3.6 GiB(约 3.8 GB)。
总线宽度:8-bit(并行数据传输模式)。
5. 外部参数与工厂模式操作
text
复制
Factory: MMC
翻译与解析:
外部参数:从 eMMC 块地址 0x7c 读取数据到内存 0x9000,数据大小为 0x800(2048 字节)。
工厂模式操作:
多次从 eMMC 的不同块地址(如 0xc000, 0xc5b5)读取数据到指定内存区域(如 0x07880008)。
最后一次操作从块 0xc000 读取 0xb6a00(748,544 字节)数据到内存 0x07000000。
序列信息:序列号 0x1fb9,块地址 0xc000,数据大小 0xb6a00,目标地址 0x7000000。
用途:可能是加载固件、校准数据或出厂配置。
6. 启动参数解析
text
复制
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
bootparam.bUart = 0
翻译与解析:
启动参数文件:从路径 tmp/factory/bin_panel/000BootParam.h 中读取配置。
关键参数:
BOOT_POWER_ON_MODE=1:开机模式为正常启动(非恢复模式)。
BOOT_BACKLIGHT_VALUE=253:背光亮度设为 253(最大值可能为 255)。
BOOT_LOGO_ENABLE=1:启用开机 Logo 显示。
BOOT_MUSIC_ENABLE=0:禁用开机音乐。
BOOT_UART_OPEN_CLOSE=0:关闭 UART 调试端口。
LOCAL_UPGRADE_EN 未找到:本地升级功能未启用或配置缺失。
错误提示:在 bootparam.c 文件的第 166 行,未找到 local_upgrade_en 参数。
总结
此日志显示设备 正常启动,硬件自检(BISR)通过,eMMC 存储配置正确,但存在 本地升级功能缺失 的警告。
若需进一步分析(如修复 local_upgrade_en 错误),建议检查固件配置或联系硬件供应商。
举报
 楼主| 发表于: 2025-3-23 12:02:40
维修完毕,通过串口写引导,然后用U盘升级成功。
需要说明一下:在爱修论坛里下载的RTD2995D引导与备份都不能用(可能是这块主板与™提供的不一致)
下面是截取一段打印信息通过找Ai帮忙编译出来能看懂的信息:
【数据写入操作】
8192+0 条记录输入
8192+0 条记录输出
4194304 字节 (4.0MB) 已复制,耗时 0.335464 秒,速率 11.9MB/s
【系统操作日志】
[LOG][src/rtk_burn.cpp():2990]
[删除 000BootParam.h 文件]
[INFO][src/rtk_common.cpp():235] 执行命令:rm -f 000BootParam.h
[LOG][src/rtk_burn.cpp():3000]
[执行初始化命令组0]
[INFO][src/rtk_common.cpp():235] 执行命令:cd ../../;cp -rpf tmp/install_factory/* tmp/factory/;chmod 777 tmp/factory;
[LOG][src/rtk_burn.cpp():3004]
[执行初始化命令组1]
[INFO][src/rtk_common.cpp():235] 执行命令:rm -rf /tmp/factory/recovery;
[LOG][src/rtk_burn.cpp():3014]
[删除 env.txt 文件]
[INFO][src/rtk_common.cpp():235] 执行命令:rm -f env.txt
【固件打包操作】
[INFO][src/rtk_common.cpp():235] 执行命令:tar cf /tmp/factory.tar /tmp/factory
tar: 从成员文件名中移除前导 '/'
[LOG][src/rtk_factory.cpp():376] /tmp/factory.tar 文件大小:748032 字节
[INFO][src/rtk_factory.cpp():383] 保存到 current_pp = 0 分区,序列号 8109
【存储设备写入】
[INFO][src/rtk_common.cpp():235] 执行命令:dd if=/tmp/factory.tar of=/dev/block/mmcblk0 bs=512 count=8192 seek=49152 conv=notrunc > /dev/null
1461+0 条记录输入
1461+0 条记录输出
748032 字节 (730.5KB) 已复制,耗时 0.065055 秒,速率 11.0MB/s
【引导表更新】
[LOG][src/rtk_main.cpp():1526]
写入启动表
8192+0 条记录输入
8192+0 条记录输出
4194304 字节 (4.0MB) 已复制,耗时 0.258706 秒,速率 15.5MB/s
【多分区交替写入】(循环执行下列操作)
  • 创建新固件包(文件大小逐步增加至748544字节)
  • 使用 dd 命令写入 eMMC 存储:
    • 目标设备:/dev/block/mmcblk0
    • 块大小:512字节
    • 写入位置:交替在49152/57344扇区偏移
    • 同步模式:后期操作添加 fsync 参数
  • 记录操作:
    • 平均写入速度:374.9KB/s ~ 602.1KB/s
    • 序列号递增至8113
【安装完成统计】
[INFO][install_a.cpp
():312]
安装耗时:139秒
[INFO][install_a.cpp():313]
RTD299x 安装程序 (JH版本)
编译日期:2014年9月2日 15:13:06
版本号:641828M
():330]
=== 安装成功 ===
【系统重启序列】
[LOG][install_a.cpp
():337] 5秒后重启...(倒计时至1秒)
[INFO][install_a.cpp():341] 正在重启系统...
[INFO][src/rtk_common.cpp():235] 执行命令:reboot
【底层硬件操作】
[ 310.594791] 系统重启中...
[ 310.597939] 重启参数:(空)
[ 310.601072] 等待硬件准备...(0/2)
[ 311.603706] 等待硬件准备...(1/2)
[ 312.607706] 等待完成,开始重启...(2/2)
【关键寄存器状态】
0xb8000804=0xF0400010 (系统控制寄存器 - 触发硬件复位)
0xb8000808=0xF2400000 (电源管理寄存器 - 清除电源保持状态)
0xb8000810=0x10101010 (IO端口配置寄存器A)
0xb8000814=0xF0101010 (IO端口配置寄存器B)
0xb8000818=0x10101010 (IO端口配置寄存器C)
(注:寄存器地址对应Realtek RTD299X芯片组的特定硬件控制模块)
安装用户界面完成..[ 306.582244] arch/arm/bsp-realtek/mach-rtd299x/se.c, 1083 电源触发器 = 0[日志][install_a.cpp:main():337]3秒后重启...[日志][install_a.cpp:main():337]2秒后重启...[日志][install_a.cpp:main():337]1秒后重启...[信息][install_a.cpp:main():341]正在重启...[信息][src/rtk_common.cpp:rtk_command():235]执行命令: reboot[ 310.594791] 系统重启中[ 310.597939] 重启参数=(空)[ 310.601072] 等待中...(0/2)[ 311.603706] 等待中...(1/2)[ 312.607706] 等待完成,正在重启...(2/2)0xb8000804=0xF0400010  (寄存器地址与值)0xb8000808=0xF24000000xb8000810=0x101010100xb8000814=0xF01010100xb8000818=0x10101010分区配置 : 0x02启动配置 : 0x00启动写保护状态 : 0x00启动写保护 : 0x00分区配置 : 0x01启动配置 : 0x00启动写保护状态 : 0x00启动写保护 : 0x00分区配置 : 0x00启动配置 : 0x00启动写保护状态 : 0x00启动写保护 : 0x00启动分区索引 = 0x00000000R  (系统启动标记)U-Boot 2012.07-svn815094 (编译时间: 2015年7月7日 11:08:04)GPU : 正在进行BISR测试...GPU : BISR测试完成(正常)SCPU: 正在进行BISR测试...SCPU: BISR测试完成(正常)CPU : Cortex-A9双核存储介质: eMMC BP0MISC : 设置FUSE_RDY内存: 1 GiB看门狗: 已启用主板: Tv035 2995D 512M_512M 开发板电源输入: 直流缓存: 已启用非缓存区域: 1 MB@0x07900000MMC控制器:emmc:mmc_initial(1) 2015年7月7日 11:08:23RTD299x eMMC: 0设备: RTD299x eMMC制造商ID: 11OEM: 100名称: 004G9传输速度: 52000000读取块长度: 512MMC版本4.0高容量: 是容量: 3.7 GiB总线宽度: 8-bit扩展参数: MMC块地址:0x7c (至0x9000)rtk_eMMC读取 块地址=0x0000007c, 数据大小=0x00000800, 缓冲区=0x00009000工厂模式: MMC... (后续为eMMC存储的详细读取过程)工厂: 序列号:0x1fb1, 块地址:0xc000(pp:0), 大小:0xb6a00 (至0x7000000)获取启动参数:------------在tmp/factory/bin_panel/路径下找到000BootParam.hBOOT_POWER_ON_MODE=1 (电源模式)BOOT_BACKLIGHT_VALUE=253 (背光值)BOOT_LOGO_ENABLE=1 (启动LOGO启用)... (其他启动参数配置)
在此感谢一下以上师傅参与此话题互动,谢谢!
举报
GMT+8, 2025-4-16 20:24 , Processed in 0.097113 sec., 10 queries .
