UART_115200
AC_ON
02-2L-DM-04-20180531
MIU0_DQS-OK
BIST0-OK
BIST1-OK
FT....
#_
AUTH_KEYBANK_FAIL
UFT_PASS
Relocation Offset is: 01700000
[AT][MB][start ub][697]
U-Boot 2011.06 (Nov 16 2022 - 18:26:40)
[ERROR] MstarSysInit:204: Optee OS is not running!!!
[Utopia][SYS]: Function = SYSOpen, Line = 1215, current resource pri_shm content is: 0rToUtopia..................
[Utopia][SYS]: Function = SYSOpen, Line = 1234, [SYS INFO] OPEN INSTANCE...
create instance at 278F15B8 with private size 128 bytes at 278F1608
[Utopia][MIU]:
[MIU INFO] miu opencreate instance at 278F1690 with private size 104 bytes at 278F16E0
create instance at 278F1750 with private size 60 bytes at 278F17A0
uboot held at [276DDF60~28900000],size=012220A0
DRAM: 137 MiB
Now running in RAM - U-Boot at: 27F00000
eMMC: HS200 200MHz
eMMC 29.12 GB [3A3DFF8h]
SAR5=ON
UART BUS OFF!!!In: serial
Out: serial
Err: serial
Net: No ethernet found.
MAC: 0xA0: 0x9F: 0x10: 0x94:0xA8: 0x5F
create instance at 27901C18 with private size 44 bytes at 27901C68
[AT][MBoot][Driver Init][925]
0:EXT_D4_2400_8G_4x
1:MCP_S_D3_2133_8G_4x
Changelist: 24543697
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
Hit any key to stop autoboot: 0
enable dont overwrite function
fore uup u8KeyPad_KeyVal [0xFF]
get boot mode 0
[ERROR] do_del_boogargs_cfg:801: delete tee_mode fail
AC on
create instance at 27901FC8 with private size 296 bytes at 27902018
--write to stm32...
write stm32 fail
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
Wait for PM51 standby...........PM51 run ok...........CRC Check OPEN: 1
0x8309
Power Down
AUTH_KEYBANK_FAIL
UFT_PASS
[AT][MB][start ub][663]
[Utopia][MIU]:
DRAM: 137 MiB
eMMC: HS200 200MHz
SAR5=ON
Out: serial
Err: serial
[AT][MBoot][Driver Init][892]
0:EXT_D4_2400_8G_4x
get boot mode 0
read PM_SLEEP_AC_DC_ON error
create instance at 27901FC8 with private size 400 bytes at 27902018
MOD Output Channel Order not set!!!!
MsDrv_PNL_Init:Bypass SetDivison
MDrv_PNL_Init u32PnlRiuBaseAddr = tx
MDrv_PNL_Init u32PMRiuBaseAddr = tx
MDrv_PNL_Init g_ptr_XCExtendRiuBaseAddr = 1F600000
MST: [MHal_PNL_IsFixVBackPorch, 5332] bFixVbackPorch = 0.
LINK TYPE = EXT MST: [MHal_PNL_IsFixVBackPorch, 5332] bFixVbackPorch = 0.
[MHal_PNL_Init_MOD][3490]Vx1 1 division
[MHal_PNL_Init_MOD][3598]Vx1 1 division
[_MDrv_PNL_Init_LPLL][478]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_LPLL][480]u16HTotal=4400,u16VTotal=2260,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2260, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][540]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_Output_Dclk][542]u16HTotal=4400,u16VTotal=2260,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2260, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 2920]No instance existed, please get an instance by calling MApi_XC_Init() first
create instance at 2791A1F8 with private size 1940 bytes at 2791A248
[XC,Version]
Init PWM0Init PWM1[AT][MB][panel_pre_init][1098]
[AT][MB][bootlogo begin][1101]
create instance at 27927CB8 with private size 312 bytes at 27927D08
HAL_MIU_SelMIU not support MIU selection!
[AT][MB][JPD Decode][1142]
[UTOPIA INFO] close moduleNames[tu]: '` `xV4
[showLogo] GOP Boot Logo Index 2
create instance at 27927CB8 with private size 1732 bytes at 27927D08
[GE_Init][801]VCmdQSize = 0xtx < GE_VCMDQ_SIZE_MIN = 0xtx
create instance at 279283D0 with private size 10112 bytes at 27928420
create instance at 2792ABA8 with private size 1940 bytes at 2792ABF8
[Utopia][GOP DRV]:
Not support GOP_2 palette!'
[Utopia][GOP DRV]:
[MDrv_GOP_GWIN_GetDstPlane] not support gop3 in this chip version!![Utopia][GOP DRV]:
[MDrv_GOP_GWIN_GetDstPlane] not support gop4 in this chip version!![AT][MB][Show Logo][1227]
---MsDrv_PNL_BackLigth_On:1274 Set MsDrv_PNL_BackLigth_On DelayTask 2068
## Booting Android Image at 0x25000000 ...
Kernel load addr 0x20280000 size 14945 KiB
Kernel command line: dvariant=userdebug
RAM disk load addr 0x21280000 size 1889 KiB
ramdisk start = 0x25E99000, ramdisk end = 0x2607121A
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
-usb_stop(USB_PORT3)
Loading Kernel Image ... OK
[AT][MB][start kr][3496]
Starting kernel ...
[ERROR] _get_new_map_format_from_env:547: get E_LX_MEM4_ADR fail
set 64 bit mode
TVOS *checkPoint*
请问大神能不能看出是什么原因,主芯片是MSD8386BQM-8-003D,换了也是一样卡Logo,等一会自动关机。
