用户名  找回密码
查看: 6004|回复: 5
RT809H编程器新增电脑EC芯片ITE系列通过SMBUS读写
发表于: 2024-8-16 14:31:50
为什么要增加SMBUS读写呢?
原来的读写方式是通过键盘口读写,所需调整的信号线较多,不太方便,哪怕已经很多年了,还有不少新入行的朋友看了教程都不会调整线序;现增加通过SMBUS来读写,只需3线,甚至从电池接口处都可以读写EC。
软件支持:20240816及后续版本
连接示意图:
连接示意图
连接示意图
注意
  • 两个2.4KΩ电阻,如果主板上已有就不用再装了;如果没有则可能需要装上才能读写;
  • 主板自给供电的情况下,只需要飞线GND、SMCLK、SMDAT。
  • 线长最好在10cm内。
型号选项:IT8XXX(SMBUS) #ISP
型号选项
型号选项
速度设置:软件界面顶部的设置-编程设置选项-速度调节
速度调节
速度调节
IT8587成功读取截图:
成功读取
成功读取
  • 如果EC已经擦除了,是空白的情况下,ISP时需要在点击编程器读写按钮后的10秒内重新上电;
  • 如果里面有能跑的程序,不重新上电也能读写。
若使用中有什么问题,请跟帖反馈:芯片型号_电脑型号_主板印制版号,最好是有电路原理图。
举报
发表于: 2025-1-7 20:46:03
更新的脚步太慢了,这个功能其它工具好几年前就能实现,现在809一点也不上进,都快被淘汰了
回复 支持 2 反对 0
举报
发表于: 2024-9-23 13:10:26
新版什么时候发布,还是0731
举报
发表于: 2024-10-17 11:33:13
809H强悍的硬件,工技术程师们和市场的反馈使得809H软件程序与时俱进延伸下去。
举报
发表于: 2025-2-15 17:49:20
Hello friends!
I followed the tutorial and managed to read an IT8987E on an Acer DA0ZRTMB6D0 motherboard, but when I tried to erase and write a new firmware, it simply doesn't write. At first, I can check and confirm that it's blank. When I try to write a new firmware, I get an error at address 0x1E000, but when I remove the power from the board and turn it back on, the firmware is intact. Whether I just erase or try to rewrite, nothing changes.
I used the most recent version on that date 20241125 and selected IT8XXX(SMBUS)#ISP
I should also note that I had to turn off diode D3 that powers the battery's PWM, as it was interfering with the connection.
On the SMBUS port of the RT809H ISP board, two 8.2K resistors were placed as pull-up. Previously, 2.2K resistors were used, but they proved to be more unstable in this case.
Has anyone managed to record the ITE through the battery port?
举报
GMT+8, 2025-4-22 17:54 , Processed in 0.099798 sec., 14 queries .
