查看: 218|回复: 1
华硕A68HM-E编程器固件备份
发表于: 2024-7-13 14:36:13
[color=rgba(0, 0, 0, 0.85)]https://www.123pan.com/s/VEgeVv-qBTq3.html
[color=rgba(0, 0, 0, 0.85)]001:  序列号:20230831162712-000000,编程器固件版本:V5.0 。002:  自动识别到44个ID相符的型号。003:  http://www.ifix.net.cn/thread-2550-1-3.html004:  当前所选:W25Q64BV,容量:64M位,8M字节。005:  >------------------------------------OK---------------------------------------<006:  自动识别到44个ID相符的型号。007:  http://www.ifix.net.cn/thread-2550-1-3.html008:  当前所选:W25Q64BV,容量:64M位,8M字节。009:  >------------------------------------OK---------------------------------------<010:  引脚接触良好。011:  芯片ID校验正确。012:  UniqueID:0x271A4797C5B464D1013:  开始读取芯片......014:  状态寄存器1数值:0x0,状态寄存器2数值:0x2 。015:  读取成功,用时:12.94秒。016:  自动校验...017:  校验成功,用时:12.97秒。018:  缓冲区数据累加校验和:16位_0x6954 ,32位_0x4F536954 ;019:  用时:25.92秒,平均速率647269字节/秒。020:  >------------------------------------OK---------------------------------------<021:  文件已保存。[color=rgba(0, 0, 0, 0.85)]
GMT+8, 2024-12-19 15:09 , Processed in 0.049992 sec., 10 queries .
