用户名  找回密码
查看: 1195|回复: 11
求解:小米电视卡在LOGO
发表于: 2024-4-24 20:02:21
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
A#_
AUTH_KEYBANK_FAI
Relocation Offset is: 01700000
[AT][MB][start ub][419]
U-Boot 2011.06-00000-gcaecefa-dirty (Sep 14 2021 - 20:26:55)
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 1143, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1162, [SYS INFO] OPEN INSTANCE...
create instance at 293EAEA8 with private size 128 bytes at 293EAEF0
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 293EAF78 with private size 80 bytes at 293EAFC0
create instance at 293EB018 with private size 48 bytes at 293EB060
uboot held at [291DDF60~2AC00000],size=01A220A0
DRAM:  172 MiB
Now running in RAM - U-Boot at: 2A200000
eMMC: HS200 200MHz
eMMC 3.68 GB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x6C: 0xD: 0xC4: 0x96:0x3C: 0x49
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 293FB4D0 with private size 44 bytes at 293FB518
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]:  *? *? *  *` *? *xV4
[AT][MBoot][Driver Init][558]
factory: user mode
Writing to MMC(0)... 128 blocks written: OK
done
no force panel type
done
Changelist:        24543697
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
AC on
done
fore uup IRKey [0xFF]
fore uup u8KeyPad_KeyVal [0xFF]
AC on
bt_vendor_name = Realteck,bt_vendor_id= 0x5D00
mmc change mount : tvinfo
Size of file "rtl8723ds_config" from mmc device 0 partition tvinfo: 83 bytes
Loading file "rtl8723ds_config" at offset 0x0 from mmc device 0 partition tvinfo
83 bytes read
Read bt fw file: rtl8723ds_fw
Size of file "rtl8723ds_fw" from mmc device 0 partition tvinfo: 59744 bytes
Loading file "rtl8723ds_fw" at offset 0x0 from mmc device 0 partition tvinfo
59744 bytes read
no recovery mod,break at here!
no recovery mod!
BT_MAC:6C:0D:C4:97:C2:E9
Write RTK BT_MAC:6C:0D:C4:97:C2:E9
Size of file "wake_on_ble.conf" from mmc device 0 partition tvinfo: 0 bytes
enter wake on ble!
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
[PM][Utopia]: Wait for PM51 standby...........[PM][Utopia]: PM51 run ok...........CRC Check OPEN: 1
0x8301
Power Down
AUTH_KEYBANK_FAI
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
In:    serial
Out:   serial
Err:   serial
[CPU][Utopia]:
factory: user mode
done
no force panel type
done
DC on !!
DC on !!
done
fore uup u8KeyPad_KeyVal [0xCC]
Pressing the KEYPAD_FORCEUGRADE_KEY
Ticking: ###
No enough time(0.1s < 1.1s), continue to booting...
DC on !!
create instance at 2941D3F8 with private size 356 bytes at 2941D440
[ERROR] MsDrv_PNL_Init:865: VB1 Link Type NA !!!!
MsDrv_PNL_Init:Bypass SetDivison
MDrv_PNL_Init u32PnlRiuBaseAddr = tx
MDrv_PNL_Init u32PMRiuBaseAddr = tx
LINK TYPE = EXT [SYS][Utopia]: [SYS] Unknown query![_MDrv_PNL_Init_LPLL][340]pstPanelInitData->u16Width=1366, pstPanelInitData->u16Height=768
[_MDrv_PNL_Init_LPLL][342]u16HTotal=1560,u16VTotal=804,pstPanelInitData->u16HTotal=1560,pstPanelInitData->u16VTotal=804, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][392]pstPanelInitData->u16Width=1366, pstPanelInitData->u16Height=768
[_MDrv_PNL_Init_Output_Dclk][394]u16HTotal=1560,u16VTotal=804,pstPanelInitData->u16HTotal=1560,pstPanelInitData->u16VTotal=804, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 2685]No instance existed, please get an instance by calling MApi_XC_Init() first
create instance at 2941DB28 with private size 1892 bytes at 2941DB70
[XC,Version]
TCON VERSION 1
[AT][MB][panel_pre_init][1055]
[AT][MB][bootlogo begin][1058]
create instance at 29424CF8 with private size 312 bytes at 29424D40
[AT][MB][JPD Decode][1169]
[UTOPIA INFO] close moduleNames[tu]: *` *? *? *  *` *? *xV4
[showLogo] GOP Boot Logo Index 2
create instance at 29424CF8 with private size 1728 bytes at 29424D40
create instance at 29425408 with private size 9596 bytes at 29425450
[AT][MB][Show Logo][1215]
---MsDrv_PNL_BackLigth_On:1092 Set MsDrv_PNL_BackLigth_On DelayTask 340
[PWM][Utopia]: Init PWM0mmc change mount : factory
Size of file "/factory.prop" from mmc device 0 partition factory: 234 bytes
Loading file "/factory.prop" at offset 0x0 from mmc device 0 partition factory
234 bytes read
sar(8bit) = 51
## Booting kernel from Legacy Image at 24D00000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    15681648 Bytes = 15 MiB
   Load Address: 20280000
   Entry Point:  20280000
   Contents:
      Image 0: 13388416 Bytes = 12.8 MiB
      Image 1: 2293220 Bytes = 2.2 MiB
## Loading init Ramdisk from multi component Legacy Image at 24D00000 ...
ramdisk start = 0x259C4ACC, ramdisk end = 0x25BF48B0
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
   Loading Multi-File Image ... OK
[AT][MB][start kr][1856]
Starting kernel ...
set 64 bit mode
armfw_real_va_addr : 5EBE3000
optee_real_va_addr : 5EE00000
 [Ian] ARM_FW_Enter_64 258  ARMv8 NS-Uboot for 64bit kernel
 [Ian] ARM_FW_Enter_64 259 259C4ACC 22FDE4 20200100
举报
发表于: 2024-4-25 08:20:35
按住红外遥控主页键和菜单键,通电后进入三清界面执行3清后重新启动一般能恢复正常。如果还不行需要换EMMC。
举报
 楼主| 发表于: 2024-4-25 10:58:22
谢谢,按住红外遥控主页键和菜单键,进不了三清
举报
发表于: 2024-4-26 07:25:28
xiexinchong 2024-4-25 10:58
多试几下,有的型号需要同时按着电视机开关键。
举报
发表于: 2024-4-26 11:19:18
有些遥控器不行 ,如果你有测试红外遥控器的接收器,测试一下同时按键能否继续发送信号,我遇到过一个小米换了个红外遥控才进去三清的
举报
 楼主| 发表于: 2024-4-26 11:31:35
非常感谢!!等会在试试看
举报
 楼主| 发表于: 2024-4-26 11:33:42
缘来一长梦 2024-4-26 11:19
非常感谢!!等会在试试看!
举报
 楼主| 发表于: 2024-4-28 12:20:52
用原装遥控器也不能进三清,又找了个emmc数据写入,开机也是卡在MI界面。大师们看是什么地方出问题?打印信息上面一样,。
举报
发表于: 2025-2-12 13:42:22
你的小米怎么连接的串口?
举报
GMT+8, 2025-4-16 22:25 , Processed in 0.053356 sec., 10 queries .
