查看: 420|回复: 5
MSD6A818打印信息解读问题
发表于: 2024-4-15 19:39:48
请教各位老师们,这些打印信息有什么问题,是不是EMMC坏了,需要更换吗
UART_115200
[AT][MB][start sb][0]
AC_ON
AutoDQS0-[56789ABCE][56789ABCD][3456789AB][23456789A]-[0x6799]
AutoDQS1-[456789ABCD][56789ABCD][3456789AB][23456789AB]-[0x6798]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][342]
U-Boot 2011.06-svn1802 (Aug 25 2013 - 09:39:23)
CPU  : Nike
Board: BD_MST049B_10AQV_NIKE
Hello U-Boot
DRAM:  458 MiB
SPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)
spi_init: cfg_env_offset: 0x1e0000, at 560
uboot held at [3b6ddf60~3ca00000]
Now running in RAM - U-Boot at: 3bb00000
MMC:        [ eMMC_CMD9() ] eMMC WARN: CMD9 Reg.12: FF30h, Retry: 1
eMMC retry by DATA_SYNC: 0h, ori:51h
[ eMMC_CheckR1Error() ] eMMC Err: eMMC_ST_ERR_R1_23_16
  0x3C497854: 06h 00h 80h 08h 00h 08h 00h 00h 00h 00h 00h 00h 00h 00h 00h 00h  | ................
[ eMMC_CMD6() ] eMMC WARN: CMD6 check R1 error: 80000A05h, retry: 1
[ eMMC_FCIE_PollingEvents() ] eMMC Err: 2000000 us, Reg.0000h: 0002h, but wanted: 4800h
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: FF70h, Err: 80000005h, Retry: 1
[ eMMC_CMD3_CMD7() ] eMMC WARN: CMD7 Reg.12: FF30h, Retry: 1
eMMC retry by DATA_SYNC: 0h, ori:55h
[ eMMC_CMD3_CMD7() ] eMMC WARN: CMD7 Reg.12: FF28h, Retry: 2
[ eMMC_CMD3_CMD7() ] eMMC WARN: CMD7 Reg.12: FF28h, Retry: 3
eMMC retry by DATA_SYNC: 40h, ori:15h
[ eMMC_CMD6() ] eMMC WARN: CMD6 Reg.12: FE70h, Retry: 1
[ eMMC_CMD6() ] eMMC WARN: CMD6 Reg.12: FE70h, Retry: 2
eMMC Warn: slow SDR clk to 3h
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0531h, Err: 0h, Retry: 2
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 3
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 4
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 5
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0031h, Err: 0h, Retry: 6
[ eMMC_CMD3_CMD7() ] eMMC WARN: CMD7 Reg.12: FF30h, Retry: 4
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0531h, Err: 0h, Retry: 7
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 8
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0471h, Err: 0h, Retry: 9
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 10
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 11
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0531h, Err: 0h, Retry: 12
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: FF31h, Err: 0h, Retry: 13
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 14
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 15
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 16
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 17
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 18
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0531h, Err: 0h, Retry: 19
[ eMMC_CMD18_MIU() ] eMMC WARN: CMD18 Reg.12: 0071h, Err: 0h, Retry: 20
[ eMMC_CMD18_MIU() ] eMMC Err: CMD18 Reg.12: 0071h, Err: 80000A0Ch, Retry: 20
[ eMMC_DumpDriverStatus() ] eMMC Status:
[ eMMC_DumpDriverStatus() ]   MIU Mode
[ eMMC_DumpDriverStatus() ]   Polling Mode
[ eMMC_DumpDriverStatus() ]   FCIE Byte Mode
[ eMMC_DumpDriverStatus() ]   SDR Mode
[ eMMC_DumpDriverStatus() ]   FCIE Clk: 18000KHz
[ eMMC_DumpDriverStatus() ]   8-bits width
[ eMMC_DumpDriverStatus() ]   HIGH bus speed
[ eMMC_DumpDriverStatus() ]  PwrOff Notification: OFF
eMMC Burst Len:
  best:     0 blks,    0.0 MB/s
  worst:    0 blks,    0.0 MB/s
[clk setting]: 18000KHz
FCIE CLK(0x1F2016C4):0x0C0C
reg_ckg_nfie_div4_en (0x1F201794):0x4000
[pad setting]: BYPASS
reg_chiptop_0x50 (0x1F203D40):0x0000
reg_chiptop_0x43 (0x1F203D0C):0x001B
reg_chiptop_0x5D (0x1F203D74):0x4307
reg_chiptop_0x0B (0x1F203C2C):0x0000
[ eMMC_FCIE_DumpRegisters() ]
FCIE Reg:
00h:| 4807h 0000h 8020h 0000h 0000h 0000h 0000h 03FFh
08h:| 000Fh 0000h 0082h 0001h 0000h 0005h 0005h 0000h
10h:| 0055h 0002h FF31h 0000h 0000h 000Fh 0010h 0020h
18h:| 0000h 0000h 0000h 8200h 3840h 1C49h 0000h 0002h
20h:| 0000h 0000h 0000h 0000h 0000h 0000h 000Bh 0000h
28h:| 0000h 0012h 0001h 0000h 0000h 0010h 00FFh 0D10h
30h:| 581Bh 0000h 0040h 0001h FFFFh 0000h A0A0h 0000h
38h:| 0000h 0000h 00FFh FFFFh 0000h 0000h 2328h 0050h
40h:| 0004h 0000h 0000h 0000h 3000h 3F00h 0000h 0000h
48h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
50h:| 0000h 0000h 0000h 0000h 39AFh E005h 0085h 0000h
58h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h [ eMMC_FCIE_DumpRegisters() ]
FCIE JobCnt:
[ eMMC_FCIE_DumpRegisters() ] MIU side JobCnt: 0h
[ eMMC_FCIE_DumpRegisters() ] Card side JobCnt: 0h
FCIE CIFC:
00h:| 127Fh 0000h 0009h 0000h 0000h 0000h 0000h 0000h
08h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
10h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
18h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
[ eMMC_FCIE_DumpDebugBus() ]
FCIE_TEST_MODE: 581Bh
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 591Bh
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5A1Bh
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5B1Bh
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5C1Bh
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5D1Bh
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5E1Bh
FCIE_DEBUG_BUS: 600h
FCIE_TEST_MODE: 5F1Bh
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 0h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 1000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 2000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 3000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 4000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 5000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 6000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 7000h
FCIE_DEBUG_BUS: 0h
 楼主| 发表于: 2024-4-16 08:17:29
 楼主| 发表于: 2024-4-16 08:19:03
换的话,需要重写源程序
 楼主| 发表于: 2024-4-16 08:21:16
乐海平 2024-4-15 23:45
引导程序丢失
需要重写引导程序吗
GMT+8, 2024-12-19 20:00 , Processed in 0.052524 sec., 9 queries .
