查看: 533|回复: 7
微鲸W49F电视,蓝灯亮,不开机,打印信息如下,
发表于: 2024-3-9 20:05:35
微鲸W49F电视,蓝灯亮,不开机,打印信息如下,哪位帮忙看看时那里问题
Bootrom start
Boot Media: eMMC
Sys init OK
DDR Train 1 OK
DDR Train 2 OK
Starting fastboot ...
System startup
Reg Version:    v1.2.5
Reg Time:       2016/3/3115:59:03
Reg Name:       hi3751v500_2layer_cpu1000_ddr1600_1024m_1024mch0_0000mch1_emmc.xlsm
Fastboot 3.3.0 (jenkins@DS-55) (Dec 07 2018 - 13:59:39) APOLLOR-v0.9.2
Fastboot:      Version 3.3.0
Build Date:    Dec  7 2018, 13:59:55
CPU:           Hi3751v500
Boot Media:    eMMC
MMC:   Synopsys Mobile storage: 0
MMC/SD Card:
    MID:         0x000015
    OID:         0x0100
    PSN:         0xdedb538a
    DATA:        04/2016
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Clk:    50000000Hz
    Host Div:    0
    Bus Width:   8bit
    Chip Size:   7818182656 Bytes (High Capacity)
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Boot Addr:   0
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10ca3508  653.3 KiB
            data: 0x10ca3508 - 0x10e81784  1.9 MiB
Boot Env on eMMC
    Env Offset:          0x00200000
    Env Size:            0x00010000
    Env Range:           0x00010000
Legacy image detected...
   Image Name:   mcu.bin
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    34700 Bytes = 33.9 KiB
   Load Address: 00000000
   Entry Point:  00000000
SDK_VERSION: [HiDPTAndroidV200R001C01SPC115_20160506]
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[514] :--Board Name is:apollo, Power on optimize: FALSE
CUSTOM Func[HI_DRV_CUSTOM_SetGpioPower] Line[473] :--HI_DRV_CUSTOM_SetGpioPower gpio:<3>,on:<0>
CUSTOM Func[HI_DRV_CUSTOM_SetGpioPower] Line[473] :--HI_DRV_CUSTOM_SetGpioPower gpio:<28>,on:<1>
read ok mac:52:AC:0F:723:77
Reserve Memory
    Start Addr:          0x37FFF000
    Bound Addr:          0x13E82000
    Free  Addr:          0x37FFF000
    Alloc Block:  Addr        Size
cmd-bproc: !!!CONSOLE DISABLED!!!
发表于: 2024-3-10 19:31:11
最后一句是启动内核,查下cpu各项供电看看,
 楼主| 发表于: 2024-3-11 08:46:58
纸坊现代电器太阳雨太阳能 2024-3-10 19:31
1.0v  3.3v  1.5v  1.2v  都测量了  是正常的
发表于: 2024-3-11 10:37:58
最后句显示卡住BOOT引导这里,重新搞个EMMC备份写新块试试
 楼主| 发表于: 2024-3-11 12:52:30
hu5057310 2024-3-11 10:37
谢谢指导,目前也是打算这样操作的,EMMC已经取下了,显示芯片使用了30-40%的寿命,809离线成功读取了全片数据,等芯片到货后写入读取的数据再试试,
发表于: 2024-3-11 17:19:36
少帅七夜 2024-3-11 12:52
用旧的引导写新的还是开不了机的,要找别人能开机的引导才能用
 楼主| 发表于: 2024-3-11 22:08:18
hu5057310 2024-3-11 17:19
好的,我先试试看,
GMT+8, 2024-12-23 18:23 , Processed in 0.060254 sec., 10 queries .
