查看: 919|回复: 8
请教TCL RT95机芯换了EMMC串口写了引导,怎么升级主程序,谢谢!
发表于: 2024-1-22 16:19:24
 楼主| 发表于: 2024-1-22 16:27:46
2024-1-22, 15:49:50
COM6, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
GGoo
ARM
A
U-Boot 2012.07-svn634805 (Mar 07 2014 - 19:10:32)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
Board: Tv030 2995 Board
REG_AC_DC_ON_reg: 0x0
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:
emmc:mmc_initial(1) Mar  7 2014 19:11:01
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000c003, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000e003, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000600, buffer=0x0a900000
Factory: seq:0x5, blk:0xe000(pp:1), size:0x600 (to 0xa900000)
get_bootparam:
------------can't find tmp/factory/bin_panel/000BootParam.h
148boot_power_on_mode=1
bootup_policy=0
boot_power_on_mode=0
boot_ac_on=1
get_layout:
------------can't find tmp/factory/layout.txt
[ENV] read_env from factory failed
[ENV] Using default environment variables
ee read 343, 1
name=EEP_I2C ppcb_enum.Name=EEP_I2C, ppcb_enum.info=4
EEP_I2C=4
name=EEP_DEVICE_ADDR ppcb_enum.Name=EEP_DEVICE_ADDR, ppcb_enum.info=50
name=PIN_EEP_WP ppcb_enum.Name=PIN_EEP_WP, ppcb_enum.info=100011304
m_PIN_EEP_WP = 0x100011304
ee read 366, 1
ee read 647, 1
 Eeprom.c GetProjectID() projectID = 1
factory_read tmp/factory/bin_panel/panel.bin or tmp/factory/bin_panel/pid_panel_list.h failed,assign panel.bin value
Panel: Use default config (tmp/factory/bin_panel/panel.bin is not found)
Panel: China_Star_4K2K_VBY1.h
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------can't find tmp/factory/recovery
################# index:hitvalue:torrence:lsadc_key1  0:0:3:63
======== Checking into android recovery ====
TCWCR_reg: 0
Start Boot Setup ...
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x0a820000
[ERR] rtk_plat_read_fw_desc_table_from_eMMC:Signature() error!
Final checksum check:
[FAC] factory_save: MMC
[FAC] Save to eMMC (blk#:0xc000, buf:0x0a900000, len:0x800)
[FAC] Save to eMMC (seq#:0x6, pp:0)
name=PIN_LED_RED ppcb_enum.Name=PIN_LED_RED, ppcb_enum.info=100010304
Enter console mode, disable watchdog ...
Realtek>
 楼主| 发表于: 2024-1-22 16:43:08
主板40-RT9502-MAE4HG
发表于: 2024-1-22 18:50:30
对应版本的强制升级文件install.img放U盘根目录,上电自动升级,或是按住键盘tab在上电就会升级
 楼主| 发表于: 2024-1-22 19:16:23
xxjgl 2024-1-22 18:50
就是这样操作不能升级,没搞清楚
 楼主| 发表于: 2024-1-22 19:20:29
不知道是不是引导不对
发表于: 2024-1-23 09:23:02
淮安新科 2024-1-22 19:16
就是这样操作不能升级,没搞清楚
有可能你的引导写错,这个分1G和1.5GDDR,引导不一样,看你的是1.5G,你看看硬件配置,写1G引导看看,实在不行站内有备份,找个对应的写备份
发表于: 2024-1-23 19:52:14
看引导ddr是1.5g的
GMT+8, 2024-12-19 16:58 , Processed in 0.050693 sec., 9 queries .
