用户名  找回密码
查看: 719|回复: 0
这打印信息是什么错误
发表于: 2023-9-20 22:21:20
T_115200
AC_ON
MIU0_DQS-OK
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 01200000
hs>>power-on
[AT][MB][start ub][352]
U-Boot 2011.06-00000-g86f4ac0-dirty (Jan 23 2019 - 11:43:57)  MBOT-2.12.$Change: 1206504 $
[MIU INFO] miu opencreate instance at 345aaad0 with private size 80 bytes at 345aab18
create instance at 345aab70 with private size 48 bytes at 345aabb8
uboot held at [342ddf60~36200000],size=01f220a0
CPU  : Muji
Board: BD_MST072B_20AEV_MUJI
DRAM:  354 MiB
Now running in RAM - U-Boot at: 35300000
FCIE_MODE_GPIO_PAD_DEFO_SPEED
FCIE_MODE_8BITS_MACRO_HIGH_SPEED
FCIE_MODE_32BITS_MACRO_HS400_DS
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
[CPU INFO] cpu opencreate instance at 345bafe8 with private size 44 bytes at 345bb030
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
MACaddr = 0xa80xa60x480x860x260xe2
the same ethaddr!
MAC:  0xa8: 0xa6: 0x48: 0x86:0x26: 0xe2
[CPU INFO] cpu opencreate instance at 345bb078 with private size 44 bytes at 345bb0c0
msIR_Initialize
[AT][MBoot][Driver Init][629]
[ERROR] MDrv_URSA_COM_Get_URSA_Type:472: [URSA_COMMON] ursa_type is an illeagal value !
MPOOL size : 0x200000
Changelist:     24543697
AC-on
FacMode is 0
fore uup IRKey [0xff]
Writing to MMC(0)... 128 blocks written: OK
done
AC-on
[CPU INFO] cpu opencreate instance at 345bb328 with private size 44 bytes at 345bb370
create instance at 345bb328 with private size 344 bytes at 345bb370
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
LINK TYPE = EXT
[MHal_PNL_Init_MOD][2179]Vx1 1 division
[msReadEfuse][1755]u32Result=50000050, after mask u32Result=40
[msReadEfuse][1755]u32Result=50000050, after mask u32Result=10
[msSetVBY1RconValue][1791]u16temp= 10
[_MDrv_PNL_Init_LPLL][339]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_LPLL][341]u16HTotal=4400,u16VTotal=2250,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2250, u16DefaultVFreq=600
@@11=11
[_MDrv_PNL_Init_Output_Dclk][391]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_Output_Dclk][393]u16HTotal=4400,u16VTotal=2250,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2250, u16DefaultVFreq=600
@@11=11
@@11=11
[MApi_XC_MLG_GetStatus, 1874]No instance existed, please get an instance by calling MApi_XC_Init() first
Init PWM0Init PWM1Init PWM3[msReadEfuse][1755]u32Result=50000050, after mask u32Result=40
no need to do rtpm
mmc change mount : tvconfig
Size of file "/boot0.jpg" from mmc device 0 partition tvconfig: 232199 bytes
Loading file "/boot0.jpg" at offset 0x0 from mmc device 0 partition tvconfig
232199 bytes read
create instance at 345bb4d0 with private size 312 bytes at 345bb518
[AT][MB][JPD Decode][2027]
[UTOPIA INFO] close moduleNames[35]: MODULE_NJPEG_EX
create instance at 345bb4d0 with private size 1720 bytes at 345bb518
[GOP INFO] gop opencreate instance at 345bbbd8 with private size 7760 bytes at 345bbc20
[GOP_SetGopExtendGwinInfo]WidthEnd 0x0 >WidthStart 0x0
[AT][MB][Show Logo][2077]
set tcon video mode for 50m7000(0003)
---MsDrv_PNL_BackLigth_On:1069 Set MsDrv_PNL_BackLigth_On DelayTask 278
## uCount 9
##Wakeup Source 0
##Wakeup Key 0
done
u32NuttxVirtAddr =345ee440
The version of tee.bin is 00:00:00:00
R2 Boot from 0x3ef40000
[CPU INFO] cpu opencreate instance at 345bdaf0 with private size 44 bytes at 345bdb38
[AT][MBoot][Boot Nuttx][3444]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    14696508 Bytes = 14 MiB
   Load Address: 20280000
   Entry Point:  20280000
   Contents:
      Image 0: 11976568 Bytes = 11.4 MiB
      Image 1: 2719928 Bytes = 2.6 MiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
ramdisk start = 0x25b6bfc4, ramdisk end = 0x25e0407c
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
-usb_stop(USB_PORT3)
-usb_stop(USB_PORT4)
   Loading Multi-File Image ... OK
[AT][MB][start kr][3513]
Starting kernel   ...
set 64 bit mode
__fdt_pointer=0x23000000
[    0.000000] [AT][KR][reset timer][3681]
[    0.004205] thread_info_cache_init, alloc 1536 thread_pool
[    0.406048] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.525573] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[    0.525573]
[    0.620724] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.626805] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.632294] [KDEBUGD] enter : _MStar
[    0.632294]
[    0.637474] [AT][KR][start init][4318]
[    0.641225] [AutoTest][Kernel][start Initprocess][4318]
[    0.655516] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    1.060199] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[    1.060199]
[    1.068153] hub 3-0:1.0: state 7 ports 1 chg 0000 evt 0000
[    1.068153]
[    1.076066] hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0000
[    1.076066]
[    1.083919] hub 5-0:1.0: state 7 ports 1 chg 0000 evt 0000
[    1.083919]
[    1.091811] hub 6-0:1.0: state 7 ports 2 chg 0000 evt 0000
[    1.091811]
[    1.099688] hub 7-0:1.0: state 7 ports 2 chg 0000 evt 0000
[    1.099688]
[    1.107559] hub 2-0:1.0: state 7 ports 1 chg 0002 evt 0000
[    1.107559]
[    1.138777] init: /dev/hw_random not found
[    1.143055] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    1.149018] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    1.154506] [KDEBUGD] enter : _MStar
[    1.154506]
[    1.159722] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    1.179245] init: /dev/hw_random not found
[    1.185326] fs_mgr: Warning: unknown flag block_validity
[    1.191424] fs_mgr: Warning: unknown flag nodiscard
[    1.196326] fs_mgr: Warning: unknown flag data=ordered
[    1.201475] fs_mgr: Warning: unknown flag journal_checksum
[    1.207006] fs_mgr: Warning: unknown flag block_validity
[    1.212329] fs_mgr: Warning: unknown flag nodiscard
[    1.217327] fs_mgr: Warning: unknown flag data=ordered
[    1.222476] fs_mgr: Warning: unknown flag journal_checksum
[    1.228007] fs_mgr: Warning: unknown flag block_validity
[    1.233330] fs_mgr: Warning: unknown flag nodiscard
[    1.238226] fs_mgr: Warning: unknown flag data=ordered
[    1.243375] fs_mgr: Warning: unknown flag journal_checksum
[    1.249096] fs_mgr: Warning: unknown flag block_validity
[    1.254420] fs_mgr: Warning: unknown flag nodiscard
[    1.259316] fs_mgr: Warning: unknown flag data=ordered
[    1.264465] fs_mgr: Warning: unknown flag journal_checksum
[    1.481353] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0002
[    1.481353]
[    1.530971] EXT4-fs (mmcblk0p8): VFS: Can't find ext4 filesystem
[    1.588055] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    1.588567] init: Warning!  Service jamdeod needs a SELinux domain defined; please fix!
[    1.602068] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    1.607573] [KDEBUGD] enter : _MStar
[    1.607573]
[    1.615998] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
[    1.631604] init: Warning!  Service hisenselog needs a SELinux domain defined; please fix!
<IAMREADY>
[    1.840240] init: Warning!  Service multicast needs a SELinux domain defined; please fix!
[    2.048616] fs_mgr: Warning: unknown flag block_validity
[    2.054754] fs_mgr: Warning: unknown flag nodiscard
[    2.060203] fs_mgr: Warning: unknown flag data=ordered
[    2.065487] fs_mgr: Warning: unknown flag journal_checksum
[    2.072852] fs_mgr: Warning: unknown flag block_validity
[    2.078403] fs_mgr: Warning: unknown flag nodiscard
[    2.083371] fs_mgr: Warning: unknown flag data=ordered
[    2.088621] fs_mgr: Warning: unknown flag journal_checksum
[    2.094630] fs_mgr: Warning: unknown flag block_validity
[    2.100289] fs_mgr: Warning: unknown flag nodiscard
[    2.105492] fs_mgr: Warning: unknown flag data=ordered
[    2.111407] fs_mgr: Warning: unknown flag journal_checksum
[    2.117713] fs_mgr: Warning: unknown flag block_validity
[    2.123333] fs_mgr: Warning: unknown flag nodiscard
[    2.128662] fs_mgr: Warning: unknown flag data=ordered
[    2.134572] fs_mgr: Warning: unknown flag journal_checksum
[    2.291084] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[    2.291084]
[    2.583985] healthd: No charger supplies found
[    2.703452] CMA_Pool_Init:526 heapid 23
[    2.716758] CMA_Pool_Alloc:1226 heapid 23
[    2.826670] CMA_Pool_Init:526 heapid 24
[    2.830821] CMA_Pool_Alloc:1226 heapid 24
[    2.927987] genirq: Flags mismatch irq 115. 00000000 (MiSysSrv) vs. 00000000 (MiScalerSrv)
[    2.945623] genirq: Flags mismatch irq 115. 00000000 (MiMMSrv) vs. 00000000 (MiScalerSrv)
[    2.958917] genirq: Flags mismatch irq 115. 00000000 (MiVDECSrv) vs. 00000000 (MiScalerSrv)
[    2.981953] genirq: Flags mismatch irq 115. 00000000 (MiDtvSrv) vs. 00000000 (MiScalerSrv)
[    3.117408] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[    3.117408]
[    3.760100] genirq: Flags mismatch irq 115. 00000000 (dfb_daemon) vs. 00000000 (MiScalerSrv)
[    4.592112] CMA_Pool_Init:526 heapid 22
[   12.061607] CMA_Pool_Init:526 heapid 19
[   14.181739] init: Warning!  Service cpudvfsscaling needs a SELinux domain defined; please fix!
举报
GMT+8, 2025-4-23 00:35 , Processed in 0.052641 sec., 10 queries .
