查看: 751|回复: 0
海信HZ32E35A正常打印信息
发表于: 2023-9-5 21:24:36
版号:RSAG7.820.7800/RHO
01:  USB : 4.85V
002:  序列号:20220111101324-025215  ,PCB V1.90,Boot V1.00
003:  >------------------------------------OK---------------------------------------<
004:  使用模式A扫描VGA口...
005:  MSTAR方案,型号以MST、TSUM、SE、FE开头,程序在外挂SPI存储器里。
006:  当前所选:MST_EXT_SPI #ISP,容量:128M位,16M字节。
007:  http://www.ifix.net.cn/thread-14392-1-8.html
008:  >------------------------------------OK---------------------------------------<
009:  C:\Users\Administrator\Desktop\Print.log
010:  COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
UART_115200
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
#_NOTICE:  BL3-1: v1.1(debug):c25aa68
NOTICE:  BL3-1: Built : 14:03:56, Jun  9 2017
INFO:    BL3-1: Initializing runtime services
INFO:     [Booting] mstar_send_magic_ATF 135
INFO:    BL3-1: Initializing BL3-2
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x20100948
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode Jun  9 2017 14:03:53
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
Relocation Offset is: 01700000
hs>>power-on
[AT][MB][start ub][755]
U-Boot 2011.06-00127-g8269993-dirty (Mar 19 2019 - 11:09:06)
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 1115, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1134, [SYS INFO] OPEN INSTANCE...
create instance at 293EFC18 with private size 128 bytes at 293EFC60
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 293EFCE8 with private size 80 bytes at 293EFD30
create instance at 293EFD88 with private size 48 bytes at 293EFDD0
uboot held at [291DDF60~2AC00000],size=01A220A0
DRAM:  172 MiB
Now running in RAM - U-Boot at: 2A200000
eMMC: HS200 200MHz
eMMC 3.63 GB [747FF8h]
UART BUS OFF!!UART_115200
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
[AT][MB][start ub][754]
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
hs>>power-on
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
UART BUS OFF!!
GMT+8, 2024-11-18 08:29 , Processed in 0.051714 sec., 9 queries .
