创维创维55S1YP(8H52机芯)灰屏(背光亮),检测主板12V、3.3V、5V、1.2V、1.8V、1V都正常,求助!下面是打印信息
2023-6-6, 9:32:4
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
Bootrom start
Boot Media: eMMC
Decrypt auxiliary code ...OK
Entry boot auxiliary code
Reg Version: v1.5.3p
Reg Time: 2017/06/16 16:32:23
Reg Name: hi3751v551dmoA_2layers_cpu1100Mbps_DDR4_1866_2048M_1024Mch0_1024Mch1_emmc.reg
DDRTR Suc
Boot auxiliary code success
Bootrom success
System startup
Fastboot 3.3.0 (www-data@rjyby07) (Jun 11 2020 - 05:51:02)
Fastboot: Version 3.3.0
Build Date: Jun 11 2020, 05:51:44
CPU: Hi3751v550
Boot Media: eMMC
Found flash memory controller hifmc100.
MMC: Synopsys Mobile storage: 0
MMC/SD Card:
MID: 0x000090
OID: 0x014a
PSN: 0x0c381c3f
DATA: 08/2018
Chip Type: MMC
Version: UNKNOWN
Timing: HS
Host Clk: 50000000Hz
Host Div: 0
Bus Width: 8bit
Chip Size: 7818182656 Bytes (High Capacity)
Read Block: 512 Bytes
Write Block: 512 Bytes
Boot Addr: 0
The DDR memory layout:
page table: 0x0c000000 - 0x0c400000 4 MiB
stack: 0x0c400000 - 0x0c800000 4 MiB
irq stack: 0x0cafff7c - 0x0cbfff7c 1 MiB
global data: 0x0cbfffc4 - 0x0cc00000 60 Bytes
malloc: 0x0cc00000 - 0x10c00000 64 MiB
.text: 0x10c00000 - 0x10c8e64c 569.6 KiB
data: 0x10c8e64c - 0x10d3ef00 706.2 KiB
Boot Env on eMMC
Env Offset: 0x00100000
Env Size: 0x00010000
Env Range: 0x00010000
in load_mcu_image:
enter getLedDisturbinMode
getIRSystemCode exit,IRSystemCode=14
Get IR system code = 0x0E
after change ir system code,wakeup ir key is:0xF30C0E0E
after change ir system code,wakeup ir key is:0xED120E0E
after change ir system code,wakeup ir key is:0xEC130E0E
after change ir system code,wakeup ir key is:0x6E910E0E
saved param:uSkyModelTitle=85,uSkyTypeTitle=170, uLogo=255
EEP Derive switch is open and not set derive successThe end number pos = 4
Derive info skyModel : 8H55
Derive info skyType : S1YP
set derive tv success
SDK_VERSION: [HiDPTAndroidV300R002C01SPC050_20170710]
Set CEC onetouchplay :0
saved param:bootmode=1,bootsel=0 u8ChildLock=0
BootMode = POWER OFF
BootMode = 1 ACDC = 0
will_enter_recovery = 0
boot_after_reboot = 0
Go to sleep
in boot_suspend,POWERON_FLAG=0
System suspend.
poweroff_led
======== [MCU PARAM] ========
SYSID: 0x19060550
DBGMASK: 0x00000001
SUSPENDTYPE: 0x00000000
GPIO POWER KEY: 0x00000000
GPIO LEVEL: 0x00000000
TIMER WAKEUP: 0xFFFFFFFF
IRTYPE: 0x00000004
IR NUM: 0x00000004
IR KEY: 0xF30C0E0E
IR KEY: 0xED120E0E
IR KEY: 0xEC130E0E
IR KEY: 0x6E910E0E
LSADC ZERO: 0x00000000
LSADC channel A enable
LSADC GLITCHSAMPLE: 0x00000005
LSADC TIMESCAN: 0x00000258
LSADC POWERKEY0: 0x00000000, 0x000000EC
LSADC POWERKEY1: 0x000000FF, 0x000000FF
LSADC POWERKEY2: 0x000000FF, 0x000000FF
LSADC POWERKEY3: 0x000000FF, 0x000000FF
UART Wakeup Key: 0x000000FF
Auto wakeup flag: 0x00000000
Wakeup Condition: 0x00000041
board_type mask(0:no use 1:G3 2:E388G/E388A 3:E392G/E396G): 0x00000001
board_config_mask: 0x00000000
set_gpio_mux
Light off
CEC ONE Play:0x00000000
HDMIRX_CLK_WKUP:0x00000000
HDMIRX HPD invert:0x00000006
HDMIRX HPD function:0x00000000
HDMIRX bCecWkup:0x00000000
HDMIRX enSuspendPort:0x00000005
HDMIRX HI3751V550on't Need Clk Wake Up
Don't Need Clk Wake Up
lsadc:6bit,data_delta=8,enable deglitch,power down,continue scan
======== [MCU Init Ready] ========
Power down ARM ===>
Set MCU to 24MHz ===>
Config bus core idle state ===>
Test bus core state ===>
DDR_PowerCtrl:0
set_gpio_mux
set_gpio_mux
======== [ARM Power Down] ========
Wait for 2s ...
======== [Waiting for Powerkey] ========
