用户名  找回密码
查看: 1039|回复: 2
RT809H and TH58NVG4S0FTAK0-Toshiba
发表于: 2023-5-16 20:13:32
Hello,
Is it possible to add this NAND in the programmer's software?
In auto mode it recognise it as TC58NVG3S0FTA00 and reads only the half of the information
TH58NVG4S0FTAK0 is not in the list of supported devices at all...
Thanks!
举报
 楼主| 发表于: 2023-5-17 17:04:13
Think I successful added this chip in DEVICE.INI file
ChipName = TH58NVG4S0FTAK0@TSOP48
ManuName = TOSHIBA
ChipID = 0x98D3902676150208
ChipSize = 2269118464
AlgoRef = TC58NVG3S0FTA00@TSOP48
Still did not tested writing, prefer to buy a spare ship for testing.
举报
 楼主| 发表于: 2023-6-7 23:13:32
The new chips came and I was able to make some tests.
Seems it was to early for effort...
As the nearest chip in the list of supported devices was TC58NVG3S0FTA00@TSOP48 and I used it, I did not took in mind that 3S0 is 8Gb capacity and the TH58NVG4S0FTAK0@TSOP48 is 16Gb but in 2 "banks" X 8Gb, like a separate chips - Chip A with Chip enable command CE1 and Chip B with CE2.
Now, as capacity I gave is correct = 16Gb the programmer reads two times the Chip A content and respectively writes only in Chip A.
So, I really need help with this.
Can someone push me in right direction, please!
Regards!
举报
GMT+8, 2025-4-6 22:58 , Processed in 0.049518 sec., 9 queries .
