usb标注rt rx gnd 但usb转ips查上打印不了。后来焊接三根线链接809h可以打出。
001: TXD: VGA--12; RXD: VGA--15.
002: C:\Users\HUAWEI\Desktop\Print.log
003: COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
[AT][MB][start ub][883]
U-Boot 2011.06-00000-g9e35659-dirty (Apr 24 2019 - 14:35:25)
[35mFunction = SYSOpen, Line = 1071, current resource pri_shm content is: 0[m
[35mFunction = SYSOpen, Line = 1090, [SYS INFO] OPEN INSTANCE...[m
create instance at 2B3F3C18 with private size 128 bytes at 2B3F3C60
[WDT]Is WDT reset ? 0
[WDT]Close WDT in MstarSysInit!
[MIU INFO] miu opencreate instance at 2B3F3CE8 with private size 80 bytes at 2B3F3D30
create instance at 2B3F3D88 with private size 52 bytes at 2B3F3DD0
create instance at 2B3F3E08 with private size 52 bytes at 2B3F3E50
uboot held at [2B1DDF60~2C500000],size=013220A0
DRAM: 197 MiB
Now running in RAM - U-Boot at: 2BA00000
[1;31m FFU: check start [m [1;31m FFU:MID is MID鏁板€? don't need update [m
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
In: serial
Out: serial
Err: serial
Net: No ethernet found.
MAC: 0x5C: 0xAD: 0x76: 0x18:0xB9: 0x6
Electric_Protect_OFF
[CPU INFO] cpu opencreate instance at 2B4042C0 with private size 44 bytes at 2B404308
[UTOPIA INFO] close moduleNames[tu]: ????? ?`???xV4
[AT][MBoot][Driver Init][1033]
Changelist: 24543697
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
Hit any key to stop autoboot: 0
UART BUS OFF!!UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_NOTICE: BL3-1: v1.1(debug):e9dbd72
NOTICE: BL3-1: Built : 14:25:40, Jul 24 2017
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Initializing BL3-2
NOTICE: [Ian] opteed_synchronous_sp_entry 103 20103920
IIFOO: CUU3 PeepainngfforEEL3eexi ttoseecure wrrl
IFOO: CCPU NNex iimaee ddrress = x55b000644
NNF:: CCP13 Nxtt iaagessps == 011d3
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x20100938
INFO: BL3-1: Next image spsr = 0x1d3
INFO: BIN1_32bit mode
INFO: R1 0
INFO: R2 0
INFO: R3 0
U
Relocation Offset is: 01600000
[AT][MB][start ub][827]
DRAM: 197 MiB
eMMC: HS400 200MHz
In: serial
Out: serial
Err: serial
[AT][MBoot][Driver Init][977]
UART BUS OFF!![RTPM] delay 917 ms to set backlight on
此机华星屏无逻辑板,有没有大师会维修?
