楼主: 小星河
求助32s2换emmc后不能升级
 楼主| 发表于: 2023-3-23 11:33:20
UART_115200
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
#_U
Relocation Offset is: 01700000
[AT][MB][start ub][421]
U-Boot 2011.06-svn1913 (Nov 27 2018 - 15:07:50)
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 1115, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1134, [SYS INFO] OPEN INSTANCE...
create instance at 293EAF18 with private size 128 bytes at 293EAF60
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 293EAFE8 with private size 80 bytes at 293EB030
create instance at 293EB088 with private size 48 bytes at 293EB0D0
uboot held at [291DDF60~2AC00000],size=01A220A0
DRAM:  172 MiB
Now running in RAM - U-Boot at: 2A200000
eMMC: HS200 140MHz
eMMC 3.68 GB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x88: 0x79: 0x5B: 0x97:0x4: 0x7E
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 293FB540 with private size 44 bytes at 293FB588
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]:  *? *? *  *` *? *xV4
[AT][MBoot][Driver Init][566]
MPOOL size : 0x200000
Changelist:        24543697
fore uup IRKey [0xFF]
fore uup u8KeyPad_KeyVal [0xFF]
AC on
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
[PM][Utopia]: Wait for PM51 standby...........[PM][Utopia]: PM51 run ok...........mmc change mount : customercfg
Size of file "/customercfg/panel/extra.ini" from mmc device 0 partition customercfg: 470 bytes
Loading file "/customercfg/panel/extra.ini" at offset 0x0 from mmc device 0 partition customercfg
470 bytes read
GMT+8, 2024-11-18 05:52 , Processed in 0.052023 sec., 8 queries .
