谢谢 技术下面是cu后的打印信息
Check USB port[0]:
[USB] usb_lowlevel_init++
[USB] USB EHCI LIB VER: 2014.10.02
[USB] Port 0 is Enabled
[USB] TV_usb_init (UTMI Init) ++
[USB] UTMI Base 1F207500
[USB] UHC Base 1F204800
[USB] USBC Base 1F200E00
[USB] BC Base 1F246C00
[USB] config miu select [30] [74] [FF] ][FF]
[USB] enable miu lower bound address subtraction
[USB] TV_usb_init--
[USB] Usb_host_Init++
[USB] Async base addr: 0xABB9100
[USB] Reg 0x28: 0x9100 0xABB
[USB] disable run
[USB] Host Speed:2
[USB] enable aynch
[USB] Usb_host_Init--
[USB] usb_lowlevel_init--
scanning bus for devices... [USB] control1 max:40
[USB] interface[0] conf:1 value FF:
1 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
Check USB port[1]:
[USB] Port 1 is Enabled
[USB] UTMI Base 1F207400
[USB] UHC Base 1F201A00
[USB] USBC Base 1F200F00
[USB] BC Base 1F246C40
[USB] TV_usb_init--
[USB] disable run
[USB] Host Speed:2
[USB] enable aynch
[USB] interface[0] conf:1 value 8:
scanning bus for storage devices... [USB] no_of_ep: 2
[USB] find bulk ep: 0
[USB] find bulk ep2: 1
[USB] bulk max packet size: ep(in) 0x200, ep2(out) 0x200
[USB] bulk0 is in
max lun:0
1 Storage Device(s) found
** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload **
reading /M348Upgrade.bin
1 bytes read
reading /SbootUpgrade.bin
** Unable to read "/SbootUpgrade.bin" from usb 0:1 **
** Partition 2 not valid on device 0 **
** Unable to use usb 0:2 for fatload **
** Partition 3 not valid on device 0 **
** Unable to use usb 0:3 for fatload **
** Partition 4 not valid on device 0 **
** Unable to use usb 0:4 for fatload **
reading /MBootUpgrade.bin
** Unable to read "/MBootUpgrade.bin" from usb 0:1 **
reading /UrsaUpgrade.bin
** Unable to read "/UrsaUpgrade.bin" from usb 0:1 **
reading /M348PanelUpgrade.bin
** Unable to read "/M348PanelUpgrade.bin" from usb 0:1 **
Writing to MMC(0)... 128 blocks written: OK
done
Current state ->[0x8]
1 bytes read
16384 bytes read
518696992 bytes read
Saving Environment to MMC...
done
>> filepartload 0x20200000 $(UpgradeImage) 0x4000 0x13800
>> mmc write.boot 1 0x20200000 0 0x13800
156 blocks written: OK
>> filepartload 0x20200000 $(UpgradeImage) 0x18000 0x18ae00
>> mmc write.p 0x20200000 MBOOT 0x18AE00
3159 blocks written: OK
>> filepartload 0x20200000 $(UpgradeImage) 0x1a3000 0xd7b330
>> mmc erase.p misc
** Bad Signature on 0:3: expected 0x5840, got 0x0000
ERR:invalid parameter, please check partiton name!
[ERROR] do_ustar:575: Error> cmd: mmc erase.p misc Fail !!
[ERROR] do_custar:761: Upgrade Application error!
done
AP upgrade OK!~
[AT][MB][start do_reset]
do_reset: Using RIU_MAP: 0x1F000000, at 55
UART_115200
AC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
#_U
Relocation Offset is: 01700000
[AT][MB][start ub][409]
U-Boot 2011.06-svn1782 (May 10 2018 - 14:22:15)
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 1115, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1134, [SYS INFO] OPEN INSTANCE...
create instance at 293EAF18 with private size 128 bytes at 293EAF60
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 293EAFE8 with private size 80 bytes at 293EB030
create instance at 293EB088 with private size 48 bytes at 293EB0D0
uboot held at [291DDF60~2AC00000],size=01A220A0
DRAM: 172 MiB
Now running in RAM - U-Boot at: 2A200000
eMMC: HS200 200MHz
eMMC 3.68 GB [75FFF8h]
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Set MAC default
MAC: 0x0: 0x30: 0x1B: 0xBA:0x2: 0xDB
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 293FB540 with private size 44 bytes at 293FB588
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]: *? *? * *` *? *xV4
[AT][MBoot][Driver Init][544]
<env reload for CHECK_IF_MBOOT_DEFAULT_ENV>
mmc change mount : system
Unable to use mmc 0:0 for fattable
[ERROR] loadscript:793: No enough buffer or path fail(/etc/set_env) :
[src/MsUtility.c] [loadscript]
mmc change mount : tvconfig
[ERROR] del_bootargs_cfg:545: No env 'bootargs'
[ERROR] LoadMMAP:760: get the file size of /config/mmap.ini fail
[ERROR] init_mmap:546: load mmap fail
[ERROR] get_mmap:514: init mmap fail
[ERROR] LoadMMAP:745: LoadMMAP fail last time, skip it!
[ERROR] pattern_search:843: One of the parameters is null pointer
no miu_setting information in mmap.ini
[ERROR] syncMmap2bootargs:1128: sync LX_MEM fail
[ERROR] do_sync_mmap_to_env:1549: sync the part of mmap info to bootargs fail
[ERROR] loadscript:793: No enough buffer or path fail(/config/sys.ini) :
mmc change mount : customercfg
[ERROR] prepare_nand_dbtable:973: get logo_size fail...>>>:0
[ERROR] write_dbtable:1129: flash database not ready...>>>
[ERROR] do_dbtable_init:247: dbtable init fail
ERRlease check the blk# or partiton name!
[ERROR] raw_read_mmc:995: read raw data from mmc fail
[ERROR] raw_read:575: read raw data fail
[ERROR] GetSecureImage:2727: raw_read boot secure info fail!
[ERROR] CheckSecureMerge:2671: read kernel fail
MPOOL size : 0x200000
[ERROR] CheckSignature:1609: ********************************
[ERROR] CheckSignature:1610: !!SecureInfo ID compare fail
[ERROR] CheckSignature:1611: Please do sw upgrade
[ERROR] CheckSignature:1612: ********************************
[ERROR] LoadSignature:1403: Check signature fail
[ERROR] LoadCustomerKeyBank:1446: get E_MMAP_ID_HW_AES_BUF_ADR mmap fail
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
done
UART BUS ON!
jump_to_console start!!
<< MStar >>#
