查看: 880|回复: 2
师傅们帮我看看这条信息
发表于: 2023-2-6 20:34:35
师傅们帮我看看这条打印信息有什么问题?谢谢!!
2023-2-6, 20:28:57
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
Bootrom start
Boot Media: eMMC
Decrypt auxiliary code ...OK
Entry boot auxiliary code
LSADC val: 000000FA
Reg Version:  v134
Reg Time:     2020/2/3   17:43:11
Reg Name:     hi3751v563dmo_cpu1200m_DDR3_2133m_1024m_512mch0_512mch1.reg
Reg Version:  v134
Reg Time:     2019/10/22 23:21:39
Reg Name:     hi3751v560_user_cpu_vdd_custom.reg
GPIO is high, use separate_mode
board_type:00000000
Boot auxiliary code success
Bootrom success
System startup
version:U-Boot 2018.07 (May 12 2020 - 18:16:13 +0800)
TLB ADDR:0xe000000
Build Date:    May 12 2020, 18:16:43
CPU:           Hi3751v560
Boot Media:    eMMC
gd:10bfff50,DRAM addr:0x0,size:0x60000000,actual size:0x60000000
1.5 GiB
DRAM actual size:1.5 GiB
WARNING: Caches not enabled
board_init,41
MMC:   hisi-sdhci: 0
EMMC/MMC/SD controller initialization.
current clock: 400000Hz, host timing: 0x0
current clock: 52000000Hz, host timing: 0x1
current clock: 150000000Hz, host timing: 0xa
MMC/SD Card:
    MID:         0x15
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Chip Size:   7456M Bytes (High Capacity)
    Chip Type:   MMC
    Version:     5.1
    Speed:       150000000Hz
    Bus Width:   8bit
    Mode:        HS400ES
Loading Environment from MMC... OK
Net:
======== [PARAM] ========
SYSID: 0x19060560
SUSPENDTYPE: shutdown
GPIO GROUP 0x0 disable
GPIO GROUP 0x1 disable
GPIO GROUP 0x2 disable
GPIO GROUP 0x3 disable
GPIO GROUP 0x4 disable
TIMER WAKEUP: 0xffffffff
IR NUM: 0x4
IR KEY: 0x639cff00
IR KEY: 0xd040
IR KEY: 0xed120e0e
IR KEY: 0xec130e0e
LSADC ZERO: 0xff
LSADC channel A disable
LSADC channel B disable
LSADC channel C enable
LSADC channel D disable
LSADC GLITCHSAMPLE: 0x5
LSADC TIMESCAN: 0x258
LSADC POWERKEY0: 0x0, 0x20
LSADC POWERKEY1: 0xff, 0xff
LSADC POWERKEY2: 0x0, 0x20
LSADC POWERKEY3: 0xff, 0xff
UART wakeup key: 0xff
auto wakeup flag: 0x0
wakeup condition: 0x777
power down delay: 0x4b0
power up delay: 0x14
light on
CEC ONE play: 0x0
HDMIRX_CLK_WKUP: 0x0
HDMIRX HPD invert: 0xf
HDMIRX HPD function: 0x0
HDMIRX g_cec_wake_up: 0x0
HDMIRX g_suspend_port: 0x5000000
lsadc:6bit,data_delta=8,enable deglitch,power down,continue scan
VGA wakeup is off!
====== [MCU init ready] ======
power down ARM ===>
ddr_power_ctrl:40201
group 2,bit 4 have no pinmux
====== [ARM power down] ======
stb gpio states:
group dir(0:in 1ut) level(0:low 1:high) func(0ther 1:gpio)
0 00000000 00001100 01001100
1 00000000 00000000 00000000
2 00010010 11000000 00000000
3 00000000 00000000 00000000
4 00000000 00000000 00000000
===== [waiting for powerkey] =====
_lsadc channel C: 0xfa000000
_power on!
====== [wake up by keypad] ======
suspend last 4s
====== [ARM power on] ======
Bootrom start
Boot Media: eMMC
LSADC val: 000000F8
Reg Version:  v134
Reg Version:  v134
board_type:00000400
Bootrom success
System startup
TLB ADDR:0xe000000
CPU:           Hi3751v560
Boot Media:    eMMC
gd:10bfff50,DRAM addr:0x0,size:0x40000000,actual size:0x40000000
1 GiB
DRAM actual size:1 GiB
board_init,41
MMC:   hisi-sdhci: 0
MMC/SD Card:
    MID:         0x15
    Chip Type:   MMC
    Version:     5.1
    Speed:       150000000Hz
    Bus Width:   8bit
    Mode:        HS400ES
Net:
Slave boot startup
version:U-Boot 2018.07 (May 12 2020 - 18:16:42 +0800)
TLB ADDR:0x10e00000
Build Date:    May 12 2020, 18:16:56
CPU:           Hi3751v560 a
Boot Media:    eMMC
gd:13ffff50,DRAM addr:0x0,size:0x40000000,actual size:0x40000000
1 GiB
board_init,41
The DDR memory layout:
      page table: 0x10e00000 - 0x11200000  4 MiB
           stack: 0x11200000 - 0x11600000  4 MiB
       irq stack: 0x11eefecc - 0x11fefecc  1 MiB
           .text: 0x14000000 - 0x1407d4d4  501.2 KiB
            data: 0x1407d4d4 - 0x1411b23c  631.4 KiB
init_sequence_r done!
Loading Environment from MAILBOX... OK
set LOG level 0
HPLL clk=891000000, int_part=0x104a, minor_part=0x12400000
HPLL set new mode
vo_hd_tv_cksel=2
SDK_VERSION: [HiDPTAndroidV600R001C00SPC060]
CUSTOM func[hi_drv_custom_board_init] line[301] :--board name is:HI3751V560_DEMOD_BOARD, power on optimize: TRUE
burn EPI data!
i2c_drv_wait_write_end,151: wait write data timeout!
hi_drv_i2c_write,263: wait write data timeout!
CUSTOM func[custom_write_i2c] line[162] :hi_drv_i2c_write(i2c_num, i2c_dev_addr, i2c_reg_addr, i2c_reg_addr_byte_num, data, data_len) failure!
CUSTOM func[DRV_CUSTOM_SendPanelI2c_Tconless] line[625] :custom_write_i2c(stEpiSync.I2cNum,stEpiSync.I2cDevAddr,stEpiSync.pRegData[1], 1, stEpiSync.pRegData + 2, stEpiSync.pRegData[0]-1) failure!
NOTICE:  BL31: v2.0(release):4fee8af1c0-dirty
NOTICE:  BL31: Built : 18:36:19, May 12 2020
ERR: call hi_db_get_db_from_mem fail
Get first bootmusic partition parameter err! s32Ret = -1
------------- len: 9
0a 60 00 96 00 a5 00 01
0x01
pstAmpInfo->u32ReaDataLen = 1947
pstAmpInfo->u32ReaDataLen = 1947END TAG:ff ff ff------------- len: 8
ff 0a ff 00 00 00 00 00
u8DeviceType = 10  u8DeviceAddr = 60
pAmpRegData = 0x11eede5c RegDataLen = 1947
u8DeviceType = 10  u8DeviceAddr = 0x60 init.
pu8RegData = 0x11eede5c  u32DataLen = 1947
regCount = 392
paras amp init data over
u32AmpCount = 1
Try to enter wfi
check /data/dtv/data/TAG
konka dtv database is exit
shell@KKHi3751V563:/ $
发表于: 2023-2-7 12:48:42
2023-2-6, 20:28:57
COM4,波特率:115200 bps,RXD:VGA->12,TXD:VGA->15,RT809H打印:
Bootrom启动
启动媒体:eMMC
解密辅助代码。。。好啊
进入行李箱辅助代码
LSADC值:000000FA
注册版本:v134
注册名称:hi3751v563dmo_cpu1200m_DDR3_2133m_1024m_512mch0_512mch1.Reg
注册版本:v134
注册名称:hi3751v560_user_cpu_vdd_custom.Reg
GPIO高,使用separate_mode
板类型:00000000
引导辅助代码成功
Bootrom成功
系统启动
版本:U-Boot 2018.07(2020年5月12日-18:16:13+0800)
TLB地址:0xe00000
建造日期:2020年5月12日,18:16:43
CPU:Hi3751v560
启动媒体:eMMC
gd:10bff50,DRAM地址:0x0,大小:0x60000000,实际大小:0x60000
1.5千兆字节
DRAM实际大小:1.5 GiB
警告:未启用缓存
板_内,41
MMC:hisi sdhci:0
EMMC/MMC/SD控制器初始化。
当前时钟:400000Hz,主机定时:0x0
当前时钟:52000000Hz,主机定时:0x1
当前时钟:15000000Hz,主机定时:0xa
MMC/SD卡:
中间值:0x15
读取块:512字节
写入块:512字节
芯片大小:7456M字节(高容量)
名称:“8GTF4”
芯片类型:MMC
版本:5.1
速度:15000000Hz
总线宽度:8bit
模式:HS400ES
正在从MMC加载环境。。。好啊
净额:
==========[参数]========
系统ID:0x19060560
SUSPENDTYPE:关闭
GPIO GROUP 0x0禁用
GPIO GROUP 0x1禁用
GPIO GROUP 0x2禁用
GPIO GROUP 0x3禁用
GPIO GROUP 0x4禁用
计时器唤醒:0xffffffff
IR编号:0x4
IR键:0x639cff00
IR键:0xd040
IR键:0xed120e0e
IR键:0xec130e0e
LSADC零位:0xff
LSADC通道A禁用
LSADC通道B禁用
LSADC通道C启用
LSADC通道D禁用
LSADC增益:0x5
LSADC时间扫描:0x258
LSADC电源键0:0x0,0x20
LSADC电源键1:0xff,0xff
LSADC电源键2:0x0,0x20
LSADC电源键3:0xff,0xff
UART唤醒键:0xff
自动唤醒标志:0x0
唤醒条件:0x777
断电延迟:0x4b0
上电延迟:0x14
灯亮起
CEC ONE播放:0x0
HDMIRX_CLK_WKUP:0x0
HDMIRX HPD反转:0xf
HDMIRX HPD功能:0x0
HDMIRX g_cec_wake_up:0x0
HDMIRX g_suspend_port:0x5000000
lsadc:6bit,data_delta=8,启用deglitch,关闭电源,继续扫描
VGA唤醒已关闭!
=====[MCU初始化就绪]======
关闭ARM==>
第2组第4位没有pinmux
=====[ARM电源关闭]======
stb gpio声明:
组目录(0:in 1ut)级别(0:low 1:high)func(0ther 1:gpio)
=====[等待电源键]=====
_lsadc通道C:0xfa000000
_打开电源!
=====[通过键盘唤醒]======
暂停最后4秒
=====[ARM通电]======
Bootrom启动
启动媒体:eMMC
解密辅助代码。。。好啊
进入行李箱辅助代码
LSADC值:000000F8
注册版本:v134
注册版本:v134
板类型:00000400
引导辅助代码成功
Bootrom成功
系统启动
TLB地址:0xe00000
CPU:Hi3751v560
启动媒体:eMMC
gd:10bff50,DRAM地址:0x0,大小:0x40000000,实际大小:0x40000000
1千兆字节
DRAM实际大小:1 GiB
警告:未启用缓存
板_内,41
MMC:hisi sdhci:0
EMMC/MMC/SD控制器初始化。
MMC/SD卡:
中间值:0x15
读取块:512字节
写入块:512字节
芯片大小:7456M字节(高容量)
名称:“8GTF4”
芯片类型:MMC
版本:5.1
速度:15000000Hz
总线宽度:8bit
模式:HS400ES
正在从MMC加载环境。。。好啊
净额:
从引导启动
版本:U-Boot 2018.07(2020年5月12日-18:16:42+0800)
TLB地址:0x10e0000
建造日期:2020年5月12日,18:16:56
CPU:Hi3751v560 a
启动媒体:eMMC
gd:13ffff50,DRAM地址:0x0,大小:0x40000000,实际大小:0x40000000
1千兆字节
DRAM实际大小:1 GiB
警告:未启用缓存
板_内,41
DDR内存布局:
页表:0x10e0000-0x11200000 4 MiB
堆栈:0x11200000-0x11600000 4 MiB
irq堆栈:0x11efecc-0x11efec 1 MiB
文本:0x14000000-0x1407d4d4 501.2 KiB
数据:0x1407d4d4-0x1411b23c 631.4 KiB
初始化序列已完成!
正在从MAILBOX加载环境。。。好啊
设置日志级别0
HPLL clk=891000000,内部零件=0x104a,次要零件=0x12400000
HPLL设置新模式
vo_hd_tv_cksel=2
SDK_版本:[HiDPTAndroidV600R001C00SPC060]
CUSTOM func[hi_drv_CUSTOM_board_init]行[301]:--板名称为:HI3751V560_DEMOD_board,通电优化:TRUE
烧掉EPI数据!
i2c_drv_wait_write_end,151:等待写入数据超时!
hi_drv_i2c_write,263:等待写入数据超时!
自定义函数[CUSTOM_write_i2c]行[162]:hi_drv_i2c_write(i2c_num,i2c_dev_addr,i2c_reg_addr、i2c_reg_addr_byte_num,data,data_len)失败!
自定义函数[DRV_CUSTOM_SendPanelI2c_Tconless]行[625]:CUSTOM_write_i2c(stEpiSync.I2cNum,stEpiSync.I2cDevAddr,stEpiSync.pRegData[1],1,stEpiSync.pRegData+2,stEpi同步.pRegData[0]-1)失败!
注意:BL31:v2.0(版本):4fee8af1c0脏
通知:BL31:建造时间:2020年5月12日18:36:19
正在解压缩Linux。。。完成,引导内核。
错误:调用hi_db_get_db_from_mem失败
获取第一个bootmusic分区参数错误!s32重置=-1
-------------长度:9
0x01
pstAmpInfo->u32ReaDataLen=1947
pstAmpInfo->u32ReaDataLen=1947结束标记:ff ff ff------------len:8
u8DeviceType=10 u8Device Addr=60
pAmpRegData=0x11eede5c RegDataLen=1947
u8DeviceType=10 u8Device Addr=0x60初始化。
pu8RegData=0x11ede5c u32DataLen=1947
regCount=392
paras-amp初始化数据
u32AmpCount=1
尝试输入wfi
检查/data/dtv/data/TAG
konka dtv数据库已退出
发表于: 2023-2-7 15:36:21
应该先升级一下软件试试。没必要研究这一大堆的字母组合吧
GMT+8, 2024-12-20 13:48 , Processed in 0.052813 sec., 9 queries .
