查看: 812|回复: 3
康佳KKTV U55F1升级重启
发表于: 2022-11-26 12:26:59
论坛里发过一个卡LOGO的。换了EMMC刷了引导可以出来LOGO了,强制升级也可以升。走了5-6秒就自动重启。打印代码如下:E:failed to mount /cache (Invalid argument)W:Can't unlink /cache/recovery/command
can not get upgrade file name from sdcard by key
I:find upgrade file
I:find HV553Upgrade.zip in /dev/block/sda
I:the new sdcard device is  "/dev/block/sda", and the new fstype is "auto"
-- Install /sdcard/HV553Upgrade.zip ...
Finding update package...
I:Update location: /sideload/package.zip
Opening update package...
[    8.132992] EXT4-fs (mmcblk0p24): VFS: Can't find ext4 filesystem
E:failed to mount /data (Invalid argument)
can not open verify swich file
[    8.767941] random: nonblocking pool is initialized
99018221
99018725[   15.685530] EXT4-fs (mmcblk0p23): VFS: Can't find ext4 filesystem
E:failed to mount /kkpanel (Invalid argument)
error,can not find update file
[   15.756637] EXT4-fs (mmcblk0p19): VFS: Can't find ext4 filesystem
file size = 2
-- access /cache/HV551PanelUpgrade.zip -1 -1 ...
No such package /cache/HV551PanelUpgrade.zip...
[   15.814726] EXT4-fs (mmcblk0p19): VFS: Can't find ext4 filesystem
Rebooting...
有知道的兄弟看看是那里出错了,这些天都是疫情。发不了货。看是引导出错还是升级包出错。谢谢。
发表于: 2022-11-26 22:17:26
强制升级的时候,进度条走一点就自动重启是吗
发表于: 2022-11-27 10:14:49
我也不懂,用百度可以翻译如下,希望有用
参数)W:无法取消链接/cache/recovery/command
无法通过密钥从sdcard获取升级文件名
I:查找升级文件
I:在/dev/block/sda中找到HV553Upgrade.zip
I:新的sdcard设备是“/dev/block/sda”,新的fstype是“auto”
-Install/SD card/HV 553 upgrade . zip...
正在查找更新包...
I:更新位置:/sideload/package.zip
正在打开更新包...
[8.132992]EXT4-fs(mmcblk 0 p 24):VFS:无法找到ext 4文件系统
e:未能装载/data(无效参数)
无法打开验证开关文件
[ 8.767941]随机:非阻塞池已初始化
99018221
VFS:找不到EXT4文件系统
e:无法挂载/kkpanel(无效参数)
错误,找不到更新文件
[15.756637]EXT4-fs(mmcblk 0 p 19):VFS:找不到ext 4文件系统
e:无法装载/缓存(无效参数)
文件大小= 2
-access/cache/HV 551 panelupgrade . zip-1-1...
没有这样的包/cache/HV551PanelUpgrade.zip...
[15.814726]EXT4-fs(mmcblk 0 p 19):VFS:找不到ext 4文件系统
e:无法装载/缓存(无效参数)
w:无法取消链接/缓存/恢复/命令
重新启动
 楼主| 发表于: 2022-11-27 12:10:14 来自手机
吴城之夜 2022-11-26 22:17
对,就是走一点就重启,换了好几个U盘都不行!不知道是引导还是升级包的问题。兄弟知道吗?
来自: 微社区
GMT+8, 2024-12-20 19:23 , Processed in 0.055065 sec., 9 queries .
