用户名  找回密码
查看: 1391|回复: 7
大师帮忙看看打印信息
发表于: 2022-9-13 16:25:30
鸿合教学一体机,版号ms901.6,开机卡logo,u盘升级到百分之五十直接跳到logo界面打印信息请帮忙分析
2022-9-13, 15:36:23 COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
UART_115200AC_ON
[3456789ABC][3456789ABC][3456789ABC][3456789ABCD]
[23456789ABC][123456789ABC][3456789ABC][3456789ABCDE]
{7778_7678}
[23456789ABC][23456789ABC][3456789ABCD][3456789ABCDE]
[0123456789ABCDEF][0123456789ABCDEF][0123456789ABCDEF][0123456789ABCDEF]
{7788_7777}
BISOK
BIOK__D[AutoTest][MBoot][start UBoot][676]
U-Boot 2011.06-00000-g4e29ac9-dirty (Dec 25 2015 - 14:59:46)
CPU  : Edison
Board: BD_MST036B_Edison
Hello U-Boot
New Stack Pointer is: 5ccddf60
DRAM:  480 MiB
SPI:  Flash is detected (0x0914, 0x1C, 0x70, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
spi_init: cfg_env_offset: 0x1e0000, at 560
initialization done!
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
uboot held at [5d000000~5e000000]
Now running in RAM - U-Boot at: 5d100000
MMC:        eMMC 3775MB
------------------- UART BUS ON!!! ----------------------
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env: <NULL>
Set MAC default
MAC:  0x0: 0x30: 0x1b: 0xba: 0x2: 0xdb
 -------------------MstarDrvInit----------------------------
offset 0x30000, size 0x74
offset 0x140000, size 0x30
It's the last cmd
@@@@@@ u32CpuSpeedMHz= 1152 MHz
>>>>>>>--------InitIT626X_Instance()-------
Instance[0].bAudFs=2
>>>>>>>--------InitIT626X()-------
---- RTC Alarm CLOSE ----
 --------------------MstarProcess---------------------------
|        |    SPI    |     DRAM     |    SIZ     |
| DDR_PM |  0x20000  |    0x0       |  0x10000   |
Wait for PM51 standby DRAM ...........PM51 run ok...........offset 0x15d878, size 0x5c
offset 0x15d8d4, size 0xc
--- by allan140528 m_ucDimmingCtl=6d
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
[_MDrv_PNL_Init_LPLL][303]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][305]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][348]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][350]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
Init PWM2[Utopia] T8 is not support
Changelist:        00112233
[ERROR] set_bootargs_cfg:325: bootargs doesn't exist
[ERROR] set_panelinit_cfg:482: set BOOTLOGO_IN_MBOOT to bootargs fail
[ERROR] set_env_cfg:438: set ho]ho]OFFSET=0x1E0000 to bootargs fail
rdl_002;custar_001;ret=0
zhangcs  do_custar_hht!!!!!!!!!!!!
Check USB port[0]:
Host type:0
scanning bus for devices...
[USB] interface[0] conf:1 value 3:
1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Check USB port[1]:
No USB is connecting
usb init failed
Check USB port[2]:
usb init failed
FAIL : can not init usb!!
 ------------------ MstarToKernel---------------------------
fore uup IRKey [0xff]
fore uup u8KeyPad_KeyVal [0xff]
40200000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40200010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40200020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40200030: 00 00    ..
Check USB port[0]:
usb init failed
Check USB port[1]:
usb init failed
Check USB port[2]:
usb init failed
offset 0x140030, size 0xe629
[AutoTest][MBoot][JPD Decode]
[GOP0, PID 0][Driver Version]: 0088, BuildNum: 0004, ChangeList: 13737988
[MApi_GOP_GWIN_DeleteWin]: winId=0 is not in existence
[MApi_GOP_GWIN_DeleteWin]: winId=1 is not in existence
[AutoTest][MBoot][Show Logo]
** Unable to use mmc 0:1 for fatload **
Edison#
请师傅看看故障方向。底下这一段是官方U盘升级的报错打印信息
2022-9-13, 15:37:25
UART_115200AC_ON
[3456789ABC][3456789ABC][3456789ABCD][3456789ABCDE]
[23456789ABC][123456789ABC][3456789ABC][3456789ABCD]
{7788_7678}
{7788_7777}
BISOK
CPU  : Edison
Hello U-Boot
DRAM:  480 MiB
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
MMC:        eMMC 3775MB
In:    serial
Out:   serial
Err:   serial
Set MAC default
It's the last cmd
Check USB port[0]:
Host type:0
Check USB port[1]:
Host type:2
[USB] interface[0] conf:1 value 8:
       scanning bus for storage devices... bulk max packet size: ep 200 ep2 200
max lun:0
1 Storage Device(s) found
zhangcs upgradeFiles == /IST901_Upgrade.bin
** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload **
reading /IST901_Upgrade.bin
1 bytes read
16384 bytes read
335245336 bytes read
zhangcs ntmp == 0
zhangcs ntmp == 0
zhangcs CRC_script_value == 1747524512
fnbase=IST901_Upgrade;upgradeFile=/IST901_Upgrade.bin
zhangcs savesum == 0
Current state ->[0x8]
1 bytes read
16384 bytes read
** Bad Signature on 0:11: expected 0x5840, got 0x0000
Error >> end searching partition
storage is empty
>> mmc slc 0 1
--21 %
SLC mode or reliable write has been set, slc size is 0 bytes
>> mmc rmgpt
--22 %
no UBOOT Partition found!
>> mmc create misc 0x00080000
--23 %
Need write new driver description table!
Add new partition misc success!
>> mmc create recovery 0x00800000
--25 %
Add new partition recovery success!
>> mmc create boot 0x00400000
--26 %
Add new partition boot success!
>> mmc create system 0x17200000
--27 %
Add new partition system success!
>> mmc create userdata 0x32000000
--29 %
Add new partition userdata success!
>> mmc create cache 0x1F400000
--30 %
Add new partition cache success!
>> mmc create tvservice 0x03C00000
--31 %
Add new partition tvservice success!
>> mmc create tvcustomer 0x01000000
--33 %
Add new partition tvcustomer success!
>> mmc create tvdatabase 0x00800000
--34 %
Add new partition tvdatabase success!
>> mmc create vsdcard 0x42E00000
--35 %
Add new partition vsdcard success!
>> filepartload 50000000 IST901_Upgrade.bin 4000 6362fc
--37 %
>> mmc erase.p recovery
--38 %
MMC erase: dev # 0, user area part, block # 15360, count 16384 ...
16384 blocks erase: OK
>> mmc write.p 50000000 recovery 6362fc 1
--39 %
MMC write: dev # 0, block # 15360, count 12722 ... 12722 blocks written: OK
>> filepartload 50000000 IST901_Upgrade.bin 804000 3a54b0
--40 %
>> mmc erase.p boot
--42 %
MMC erase: dev # 0, user area part, block # 31744, count 8192 ...
8192 blocks erase: OK
>> mmc write.p 50000000 boot 3a54b0 1
--43 %
MMC write: dev # 0, block # 31744, count 7467 ... 7467 blocks written: OK
>> mmc erase.p system
--44 %
MMC erase: dev # 0, user area part, block # 39936, count 757760 ...
757760 blocks erase: OK
>> filepartload 50000000 IST901_Upgrade.bin c04000 60d5186
--46 %
>> mmc unlzo 50000000 60d5186 system 1
--47 %
   Uncompressing ...
    Continue uncompressing and writing emmc...
    Depressed OK! Write to system partition OK!
Total write size: 0x8000000
>> filepartload 50000000 IST901_Upgrade.bin 6cda000 53953a1
--48 %
>> mmc unlzo.cont 50000000 53953a1 system 1
--50 %
   Uncompressing ...
LZO: uncompress, out-of-mem or overwrite error -5
[ERROR] do_ustar:565: Error> cmd: mmc unlzo.cont 50000000 53953a1 system 1 Fail !!
[ERROR] do_custar_hht:516: Upgrade Application error!
40200030: 00 00    ..
Edison#
举报
发表于: 2022-9-14 00:03:40
从打印信息看与EMMC有关,大概意思是EMMC不能使用的意思,望大家指教。
举报
 楼主| 发表于: 2022-9-14 12:26:06
杨国应 2022-9-14 00:03
谢谢指点,这个没有备份刷机包。只有u盘升级包,暂时还不敢换emmc
举报
 楼主| 发表于: 2022-9-14 12:30:18
这种换了emmc ,没有备份软件也刷不了吧?
举报
发表于: 2022-9-15 14:33:59
是什么主芯片,是什么升级包。如果是高安芯片的话把原机的拆出来备份100M,写入新的EMMC,再强制升级
举报
GMT+8, 2025-4-23 00:02 , Processed in 0.062476 sec., 9 queries .
