查看: 534|回复: 1
海信LED46K270X3D不加电,打印信息如下
发表于: 2022-9-11 10:53:29
机器故障为不加电,版号是:RSAG7.820.5277/ROH
打印信息是:
014:  COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
Byte 1 : Gating(2 ~ 57), Size=56, Mid=29, Set=29.
Byte 2 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 3 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
HW Byte 0 : DQS(10 ~ 42), Size 33, Set 26, HW_Set 29.
HW Byte 1 : DQS(8 ~ 41), Size 34, Set 24, HW_Set 27.
HW Byte 2 : DQS(8 ~ 41), Size 34, Set 24, HW_Set 27.
HW Byte 3 : DQS(8 ~ 40), Size 33, Set 24, HW_Set 26.
DRAM A Size = 512 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xcb83a0c3
:0x0401007b
:0x32473163
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x000a70d8
LZHS checksum:0x00000086
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: A/C power on!!
use code based  EDID.................
Load HDMI internal EDID.................
CEC Physical offset 156
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0x69
HDMI2 PA 0x10
HDMI2 checksum 0x69
HDMI3 PA 0x20
HDMI3 checksum 0x59
HDMI4 PA 0x30
HDMI4 checksum 0x49
SIF_Master0: new design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  d80e50, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x5a080 0x80
1st MAC in EEP is valid (90:cf:7d:f7:d3:7b)
1st : (90:cf:7d:f7:d3:7b)
2nd : (ff:ff:ff:ff:ff:ff)
PDWNC_Init
Boot reason: A/C power on!!update check revovery,adc value:255
LDR_CheckRecovery,needn't enter recover
Do USB upgrade
USB: Vbus turn up time = 207 ms, Max =0 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x30 Flags:0x30
Flash load lzhs header from 0x80000 to dram(0x1506020), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x1506020), size=0x36892
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Nov 16 2016 - 23:48:56)
DRAM:  362 MiB
WARNING: Caches not enabled
MMC:   HOST 1
Dev Num: 0, Timing Position: 0, Sample Edge: 0x00
90014A48:32473163:0401007B:CB83A0C3
id1:4A483247 id2:31630401
eMMC Name: UNKNOWN
Dev Num: 0, Timing Position: 1, Sample Edge: 0x00
Dev Num: 0, Timing Position: 2, Sample Edge: 0x11
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
PDWNC_REBOOT_CMD_OFFSET contains
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
Initializing cgroup subsys cpuset
Linux version 3.0.13 (gfkfcmo@ubuntu-num3) (gcc version 4.5.1 (GCC) ) #1 SMP PREEMPT Wed Nov 16 23:48:37 CST 2016
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: MT5880
Memory policy: ECC disabled, Data cache writealloc
====> PMEM BOOTMEM ALLOC <=====
allocating 49283072 bytes at   (null) (40000000 physical) for pmem arena
PERCPU: Embedded 7 pages/cpu @c08ed000 s4960 r8192 d15520 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 91948
Kernel command line: lpj=4571136 console=ttyMT0,115200n1 root=/dev/mmcblk0p5 vmalloc=512M no_console_suspend androidboot.carrier=wifi-only mtdparts=mt53xx-emmc:2M(uboot),2M(uboot_env),1M(misc),16M(recovery),16M(boot),500M(system),500M(userdata),500M(cache),1M(reserved),1M(channelA),1M(channelB),1M(pq),1M(aq),4M(logo),4M(bootlogo) mali_core_num=2 usbportusing=1,1,1,0 usbpwrgpio=-1,-1,-1,-1 usbpwrpolarity=-1,-1,-1,-1 usbocgpio=-1,-1,-1,-1 usbocgpiopolarity=-1,-1,-1,-1
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
allocated 1482752 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 362MB = 362MB total
Memory: 352384k/352384k available, 18304k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd7000000 - 0xff000000   ( 640 MB)
    lowmem  : 0xc0000000 - 0xd6a00000   ( 362 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0029000   ( 132 kB)
      .text : 0xc0029000 - 0xc049ff44   (4572 kB)
      .data : 0xc04a0000 - 0xc04d71e0   ( 221 kB)
       .bss : 0xc04d7204 - 0xc060f398   (1249 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:256
timekeeping_init done
ckgen Xtal:27000000 Hz
Console: colour dummy device 80x30
console [ttyMT0] enabled
Calibrating delay loop (skipped) preset value.. 1828.45 BogoMIPS (lpj=4571136)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
CPU: Testing write buffer coherency: ok
Calibrating local timer... 445.11MHz.
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x73440001, Cache size: 262144 B
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3656.90 BogoMIPS).
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource timer2
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 7248K
PMU: registered new PMU device of type 0
Power Management for MTK DTV.
ashmem: initialized
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 702
io scheduler noop registered
io scheduler deadline registered
io scheduleSerial: MT53xxttyMT0 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT1 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT2 at MMIO 0xf0028800 (irq = 32) is a MT53xx Serial
ttyMT3 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
brd: module loaded
loop: module loaded
pmem: 1 init
android_pmem: probe of android_pmem.0 failed with error -1
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
star: desc addr: 0xffdff000(virtual)/0x15d49000(physical)
Star Ethernet: Internal Vitesse PHY
star: PHY addr = 0x0000
star: EthTool installed
star: Star MAC init done
MUC_init 5037: [USB]Controller in DMA mode
MGC_VBusControl 725: [USB0]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.0: USB Host Controller
MtkUsbHcd MtkUsbHcd.0: new USB bus registered, assigned bus number 1
MtkUsbHcd MtkUsbHcd.0: irq 47, io mem 0xf0050000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
MGC_VBusControl 725: [USB1]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.1: USB Host Controller
MtkUsbHcd MtkUsbHcd.1: new USB bus registered, assigned bus number 2
MtkUsbHcd MtkUsbHcd.1: irq 43, io mem 0xf0051000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
MGC_VBusControl 725: [USB2]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.2: USB Host Controller
MtkUsbHcd MtkUsbHcd.2: new USB bus registered, assigned bus number 3
MtkUsbHcd MtkUsbHcd.2: irq 80, io mem 0xf0052000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
using rtc device, mt53xx_rtc, for alarms
mt53xx_rtc mt53xx_rtc.0: rtc core: registered mt53xx_rtc as rtc0
mt53xx_rtc mt53xx_rtc.0: MT53xx Real Time Clock driver.
adbattery: android dummy battery driver loaded
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
Bluetooth: Atheros AR30xx firmware driver ver 1.0
usbcore: registered new interface driver ath3k
mmc0: 5880
at 0xf006d000 irq 100 data mode 3 Optimization
mmc1: 5880
at 0xf0012000 irq 60 data mode 3
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
zram: num_devices not specified. Using default: 2
special_arg: 00000002
test mmc...
zram: Creating 2 devices ...
usbcore: registered new interface driver snd-usb-audio
ALSA device list:
MUC_Irq 4221: [USB]Connect interrupt  = 0x10.
  No soundcards found.
nf_conntrack version 0.5.0 (5619 buckets, 22476 max)
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
Bluetooth: RFCOMM TTY layer initialized
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 H2G1c 1.76 GiB
mmcblk0boot0: mmc0:0001 H2G1c partition 1 1.00 MiB
mmcblk0boot1: mmc0:0001 H2G1c partition 2 1.00 MiB
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 3
part 01: startblk 0x00000000, blkcnt 0x00001000, <uboot>
part 02: startblk 0x00001000, blkcnt 0x00001000, <uboot_env>
part 03: startblk 0x00002000, blkcnt 0x00000800, <misc>
usb_events_timer_func 555: [usb]USB_EVENTS_CHECK_CONNECT
MGC_VBusControl 725: [USB2]Vbus On gpio[-1].
part 04: startblk 0x00002800, blkcnt 0x00008000, <recovery>
part 05: startblk 0x0000a800, blkcnt 0x00008000, <boot>
part 06: startblk 0x00012800, blkcnt 0x000fa000, <system>
part 07: startblk 0x0010c800, blkcnt 0x000fa000, <userdata>
part 08: startblk 0x00206800, blkcnt 0x000fa000, <cache>
part 09: startblk 0x00300800, blkcnt 0x00000800, <reserved>
mt53xx_rtc mt53xx_rtc.0: setting system clock to 2000-01-01 16:00:00 UTC (946742400)
part 10: startblk 0x00301000, blkcnt 0x00000800, <channelA>
part 11: startblk 0x00301800, blkcnt 0x00000800, <channelB>
part 12: startblk 0x00302000, blkcnt 0x00000800, <pq>
part 13: startblk 0x00302800, blkcnt 0x00000800, <aq>
part 14: startblk 0x00303000, blkcnt 0x00002000, <logo>
part 15: startblk 0x00305000, blkcnt 0x00002000, <bootlogo>
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
RAMDISK: gzip image found at block 0
usb 3-1: new high speed USB device number 2 using MtkUsbHcd
uncompression error
UDF-fs: No partition found (1)
List of all partitions:
b300         1847296 mmcblk0  driver: mmcblk
  b301            2048 mmcblk0p1 00000000-0000-0000-0000-000000000000mmcblk0p1
  b302            2048 mmcblk0p2 00000000-0000-0000-0000-000000000000mmcblk0p2
  b303            1024 mmcblk0p3 00000000-0000-0000-0000-000000000000mmcblk0p3
  b304           16384 mmcblk0p4 00000000-0000-0000-0000-000000000000mmcblk0p4
  b305           16384 mmcblk0p5 00000000-0000-0000-0000-000000000000mmcblk0p5
  b306          512000 mmcblk0p6 00000000-0000-0000-0000-000000000000mmcblk0p6
  b307          512000 mmcblk0p7 00000000-0000-0000-0000-000000000000mmcblk0p7
  103:00000     512000 mmcblk0p8 00000000-0000-0000-0000-000000000000mmcblk0p8
  103:00001       1024 mmcblk0p9 00000000-0000-0000-0000-000000000000mmcblk0p9
  103:00002       1024 mmcblk0p10 00000000-0000-0000-0000-000000000000mmcblk0p10
  103:00003       1024 mmcblk0p11 00000000-0000-0000-0000-000000000000mmcblk0p11
  103:00004       1024 mmcblk0p12 00000000-0000-0000-0000-000000000000mmcblk0p12
  103:00005       1024 mmcblk0p13 00000000-0000-0000-0000-000000000000mmcblk0p13
  103:00006       4096 mmcblk0p14 00000000-0000-0000-0000-000000000000mmcblk0p14
  103:00007       4096 mmcblk0p15 00000000-0000-0000-0000-000000000000mmcblk0p15
b310            1024 mmcblk0boot1  (driver?)
b308            1024 mmcblk0boot0  (driver?)
No filesystem could mount root, tried:  ext3 ext2 ext4 squashfs vfat msdos iso9660 udf
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
[<c0033efc>] (unwind_backtrace+0x0/0xe4) from [<c037fd80>] (panic+0x68/0x188)
[<c037fd80>] (panic+0x68/0x188) from [<c0008d6c>] (mount_block_root+0x238/0x288)
[<c0008d6c>] (mount_block_root+0x238/0x288) from [<c000906c>] (prepare_namespace+0x164/0x1b8)
[<c000906c>] (prepare_namespace+0x164/0x1b8) from [<c00089f4>] (kernel_init+0x124/0x160)
[<c00089f4>] (kernel_init+0x124/0x160) from [<c002f4ec>] (kernel_thread_exit+0x0/0x8)
CPU1: stopping
[<c0033efc>] (unwind_backtrace+0x0/0xe4) from [<c0029368>] (do_IPI+0xc8/0x198)
[<c0029368>] (do_IPI+0xc8/0x198) from [<c002e6ac>] (__irq_svc+0x4c/0xe0)
Exception stack(0xd645ff90 to 0xd645ffd8)
ff80:                                     00000000 00000000 d645ffd8 00000000
ffa0: d645e000 c04af48c c04d72e4 c0384974 0000406a 413fc090 00000000 00000000
ffc0: d6442044 d645ffd8 c002f548 c002f54c 60000013 ffffffff
[<c002e6ac>] (__irq_svc+0x4c/0xe0) from [<c002f54c>] (default_idle+0x24/0x28)
[<c002f54c>] (default_idle+0x24/0x28) from [<c002f824>] (cpu_idle+0x7c/0xdc)
[<c002f824>] (cpu_idle+0x7c/0xdc) from [<0037d180>] (0x37d180)
MGC_VBusControl 725: [USB0]Vbus On gpio[-1].
MGC_VBusControl 725: [USB1]Vbus On gpio[-1].
哪位大师,给指点一下,打印信息内容,故障在哪里?谢谢!
 楼主| 发表于: 2022-9-12 11:29:38
论坛里的打印信息软件,翻译的也是,一塌糊涂!如下:
杨师傅家电维修翻译结果:
014:COM4,波特率:115200 bps,RXD:VGA->15,TXD:VGA->12,靴子-DRAM通道A校准。字节0:选通(2~62),大小=61,中间=32,设置=32。字节1:选通(2~57),大小=56,中间=29,设置=29。字节2:选通(2~67),大小=66,中间=34,设置=34。字节3:选通(2~67),大小=66,中间=34,设置=34。HW字节0QS(10~42),大小33,集合26,HW_Set 29。HW字节1QS(8~41),大小34,集合24,HW_Set 27。HW字节2QS(8~41),大小34,集合24,HW_Set 27。HW字节3QS(8~40),大小33,集合24,HW_Set 26。DRAM A大小=512兆字节。靴子启动Pmain0x0000a000EMMC启动CID:0xcb83a0c3:0x0401007b:0x32473163:0x90014a48LZHS地址:0x00100040LZHS尺寸:0x000a70d8LZHS校验和:0x00000086靴子开始MT5880引导加载程序v0.9开机原因:空调开机!!加载VGA内部EDID。。。。。。。。。。。。。。。。。使用基于EDID的代码。。。。。。。。。。。。。。。。。加载HDMI内部EDID。。。。。。。。。。。。。。。。。CEC物理偏移量156HDMI1物理adr 0x10HDMI1 PA 0x10HDMI1校验和0x69HDMI2 PA 0x10HDMI2校验和0x69HDMI3 PA 0x20HDMI3校验和0x59HDMI4 PA 0x30HDMI4校验和0x49SIF_Master0:新设计IR数据寄存器:0x 0开机原因:空调开机!!T8032案例加载器阶段初始化A/C。。。加载T8032固件(地址:0x d80e50,大小:24576)成功!!T8032固件版本:73T8032更改为装载机阶段。。。LDR_FlashCopy 0xf010 0x5a080 0x80EEP中的第一个MAC有效(90:cf:7d:f7:d3:7b)第一:(90:cf:7d:f7:d3:7b)第二名:(ff:ff:ff:ff:ff)PDWNC_Init开机原因:空调开机!!更新检查回顾,adc值:255LDR_CheckRecovery,无需输入recover进行USB升级USB:Vbus开启时间=207毫秒,最大值=0毫秒。没有USB设备。USB升级停止开机原因:空调开机!!开机原因:空调开机!!组织:0x30标志:0x30将lzhs头从0x80000闪存加载到dram(0x1506020),大小=2048解压uboot到0x00800000。。。将图像从0x80000闪存加载到dram(0x1506020),大小=0x36892安全启动okLZHS启动LZHS完成正在启动图像。。。U-Boot 2011.12.12(2016年11月16日-23:48:56)DRAM:362 MiB警告:未启用缓存MMC:主机1偏差数量:0,定时位置:0,样本边缘:0x0090014A48:32473163:0401007B:CB83A0C3id1:4A483247 id2:31630401eMMC名称:未知偏差数量:0,定时位置:1,样本边缘:0x00Dev数量:0,定时位置:2,样本边缘:0x11: 00.0.0.0在:序列输出:序列号错误:序列号Net:跳过网络初始化找不到以太网。PDWNC_REBOOT_CMD_OFFSET包含按任意键停止自动启动:0##正在从旧映像以00008000启动内核。。。XIP内核映像…OK好啊正在启动内核。。。解压Linux…完成,启动内核。初始化cgroup子系统cpuset初始化cgroup子系统cpuLinux版本3.0.13(gfkfcmo@ubuntu-num3)(gcc版本4.5.1(gcc))#1 SMP抢占2016年11月16日星期三23:48:37 CSTCPU:ARMv7处理器[413fc090]版本0(ARMv7),cr=10c53c7dCPU:VIPT非关联数据缓存、VIPT别名指令缓存机器:MT5880内存策略:禁用ECC,数据缓存写位置===>MEM BOOTMEM ALLOC<=====为pmem arena分配49283072字节(空)(40000000物理)PERCPU:嵌入式7页/cpu@c08ed000 s4960 r8192 d15520 u32768按区域顺序构建1个区域列表,移动分组。总页数:91948内核命令行:lpj=4571136 console=ttymt0115200n1 root=/dev/mmcblk0p5 vmalloc=512M no_console_suspend androidboot。运营商=仅限wifi的mtdparts=mt53xx emmc:2M(uboot)、2M(uboot_env)、1M(misc)、16M(恢复)、16M(启动)、500M(系统)、500M、500M(用户数据)、500M(缓存)、1M、1M(信道A)、1M和1M(pq)、1M(aq)、4M(徽标)、4M-1,-1 usbocgpiopolarity=-1,-1,-2,-1PID哈希表条目:2048(顺序:18192字节)Dentry缓存哈希表条目:65536(顺序:6262144字节)索引节点缓存哈希表条目:32768(顺序:5131072字节)分配了1482752字节的page_cgroup如果不需要内存cgroup,请尝试“cgroup_disable=memory”选项内存:362MB=总计362MB内存:352384k/352384k可用,18304k保留,0K高内存虚拟内核内存布局:向量:0xffff0000-0xffff1000(4KB)固定映射:0xfff00000-0xfffe0000(896KB)DMA:0xffc00000-0xffe00000(2 MB)vmalloc:0xd7000000-0xff000000(640MB)低内存:0xc0000000-0xd6a00000(362 MB)pkmap:0xbfe00000-0xc0000000(2 MB)模块:0xbf000000-0xbfe00000(14 MB).init:0xc0008000-0xc0029000(132 kB).文本:0xc0029000-0xc049ff44(4572 kB).数据:0xc04a0000-0xc04d71e0(221KB).bss:0xc04d7204-0xc060f398(1249KB)SLUB:Genslabs=13,hAlign=32,阶数=0-3,最小对象=0,CPU=2,节点=1可抢占分层RCU实现。NR_IRQ:256timekeeping_init完成ckgen Xtal:27000000HzC
请大师们,给指导一下!谢谢!
GMT+8, 2024-11-19 01:42 , Processed in 0.050925 sec., 9 queries .
