查看: 1837|回复: 11
P50-358V3.0量产加U盘程序
发表于: 2022-8-31 20:50:23
P50-358V3.0量产加U盘程序
这是绑定IP的, 换主芯片 闪存是不会开机的,写入量产即可正常开机
UART BUS OFF!!UART_115200
AC_ON
BIST0-OK
#_U
Relocation Offset is: 01600000
[AT][MB][start ub][499]
U-Boot 2011.06-00056-ga3b1ef7-dirty (Nov 20 2019 - 19:28:12)
[SYS][Utopia]: Function = SYSOpen, Line = 1143, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1162, [SYS INFO] OPEN INSTANCE...
create instance at 292EB248 with private size 128 bytes at 292EB290
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 292EB318 with private size 80 bytes at 292EB360
create instance at 292EB3B8 with private size 48 bytes at 292EB400
uboot held at [290DDF60~2AC00000],size=01B220A0
DRAM:  172 MiB
Now running in RAM - U-Boot at: 2A100000
eMMC: HS200 200MHz
eMMC 3.63 GB [747FF8h]
SAR5=ON
In:    serial
Out:   serial
Err:   serial
Net:   mmc change mount : license
** File not found /license/macandci.ini
[ERROR] vfs_getsize:420: ext4filesize mmc fail, try again!
[ERROR] vfs_getsize:424: ext4filesize mmc fail
[ERROR] loadscript:947: No enough buffer or path fail(/license/macandci.ini) :
[src/MsUtility.c] [loadscript]
filter /license, and find file again!!
Size of file "/macandci.ini" from mmc device 0 partition license: 284 bytes
Loading file "/macandci.ini" at offset 0x0 from mmc device 0 partition license
284 bytes read
sizeof( model ini script ) --------> 284 bytes
[mac address] macandci.ini path --> 00:cb:b4:27:d0:85
parse_mac_ini,154load mac from sn successNo ethernet found.
MAC:  0x0: 0xCB: 0xB4: 0x27:0xD0: 0x85
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 292FB870 with private size 44 bytes at 292FB8B8
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]: *?*?* *`*?*xV4
[AT][MBoot][Driver Init][774]
MPOOL size : 0x200000
Changelist:        24543697
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
UART BUS OFF!!
发表于: 2022-8-31 22:18:02
我这里有一块一样的主板,明天用你的软件试一下,我这个板没有打印信息,主芯片有温度,谢谢
发表于: 2022-9-1 06:04:23
这都被楼主掌握了,谢谢楼主无私分享资料
发表于: 2022-9-1 10:12:43
感谢分享自制量产软件
发表于: 2023-2-1 15:31:16
请问你的数据电视型号和屏型号是啥
发表于: 2023-2-8 11:17:37
AC_ON
BIST0-OK
#_U
[AT][MB][start ub][508]
U-Boot 2011.06-00065-g8a496e0-dirty (Jan 09 2020 - 19:33:10)
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS200 200MHz
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
pc : [<2A100430>]           lr : [<2A196E0C>]
sp : 28AFFFB8  ip : 292FBEE8         fp : 2A2AD1D4
r10: 290DD407  r9 : 00005000         r8 : 0000FFFF
r7 : 00000020  r6 : 2AAE025C         r5 : 00001000  r4 : 292FB938
r3 : 292EB6F0  r2 : 00000988         r1 : 00008000  r0 : 292FB938
Flags: nzCv  IRQs off  FIQs on  Mode UND_32
Undefined instruction........
发表于: 2023-2-9 10:20:53
这个下载地址。必须粘贴访问才行。百度收索不行。不然提示连接失效。
 楼主| 发表于: 2023-2-10 19:52:48
81227 2023-2-9 10:20
金币也花了。怎么连接失效了。欺骗消费者。
没有失效。已经试过了。找自己的原因
GMT+8, 2024-12-19 20:47 , Processed in 0.055974 sec., 11 queries .
