查看: 1011|回复: 7
海信HZ55A55电视开机不显示
发表于: 2022-8-20 12:17:57
海信HZ55A55电视,通电红灯亮,遥控或者按键开机,变蓝灯,但是不显示,查看打印信息,有请大神帮忙看下这个是哪里出了问题。供电都正常。
发表于: 2022-8-20 13:17:18
2022-8-20, 12:7:39
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
armfwNOTICE:  BL3-1: v1.1(debug):e9dbd72
NOTICE:  BL3-1: Built : 14:07:05, Mar 18 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Initializing BL3-2
NOTICE:  [Ian] opteed_synchronous_sp_entry 103 20103750
IIFFO     CUU3 rrppaiin  fr  E33exxtttto eccrrewwordd
NNFO     CU13 exxtimmae  dddress   0xddf00164
NNO::    CUU Neext mmaee spr    011d
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x201009bc
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode
INFO:    R1 74e87206b191b34d
INFO:    R2 8dfdb00d0d333f2c
INFO:    R3 fcaf8b5251464f28
U
Relocation Offset is: 01700000
hs>>power-on
[AT][MB][start ub][785]
U-Boot 2011.06-00584-ga763002-dirty (Jan 16 2020 - 02:13:21)
msIR_Initialize
Function = SYSOpen, Line = 1071, current resource pri_shm content is: 0
Function = SYSOpen, Line = 1090, [SYS INFO] OPEN INSTANCE...
create instance at 2B4F3C50 with private size 128 bytes at 2B4F3C98
[MIU INFO] miu opencreate instance at 2B4F3D20 with private size 80 bytes at 2B4F3D68
create instance at 2B4F3DC0 with private size 52 bytes at 2B4F3E08
create instance at 2B4F3E40 with private size 52 bytes at 2B4F3E88
uboot held at [2B2DDF60~2C500000],size=012220A0
CPU  : << MStar >>#
Board: BD_MST123B_10A_MOONEY
DRAM:  197 MiB
Now running in RAM - U-Boot at: 2BB00000
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
eMMC SLC mmc type 0%-10% device life time used
eMMC MLC mmc type 20%-30% device life time used
eMMC pre_eol_info normal
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
no eeprom
0x8 0xBA 0x5F 0xF4 0x52 0x87
MACaddr = 0x80xBA0x5F0xF40x520x87
the same ethaddr!
MAC:  0x8: 0xBA: 0x5F: 0xF4:0x52: 0x87
[CPU INFO] cpu opencreate instance at 2B5042F8 with private size 44 bytes at 2B504340
[UTOPIA INFO] close moduleNames[tu]: ????? ?`???xV4
[AT][MBoot][Driver Init][955]
Changelist:        24543697
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
hisense>>AC on
no eeprom
FactoryMode is 0
Not in Factory Mode
fore uup IRKey [0xFF] repeatflag [0x2D]
Boot Check: BootMode = 1 --------
hisense>>AC on
No Reboot Flag, string is
no eeprom
FactoryMode is 0
Not in Factory Mode
no eeprom
ToFacMode is 0
ToFacMode is U
[Mboot][Check_Standby] factory_poweron_mode is secondary
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
Wait for PM51 standby...........PM51 run ok...........[Mboot][LED] his_led_type = [3] !!
[Mboot][LED] HIS_LED_REDBLUE_MODE
[Mboot][LED] Red ON!
[Mboot][Standby] KeyPad Init Finished!
==== Enter Standby Mode !! ==== 1
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IIFFO:    CUU3 Prepriin  fr  E33exxtt tossecueewoorl
IFF:     CPU2 eett mmage dddrsss   0x3df0016
INF:     CP1  Nex iimage ppsr   x1133
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
create instance at 2B505298 with private size 384 bytes at 2B5052E0
[ERROR] MsDrv_PNL_Init:1083: VB1 Link Type NA !!!!
MsDrv_PNL_Init:Bypass SetDivison
MDrv_PNL_Init u32PnlRiuBaseAddr = 1F200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1F000000
MDrv_PNL_Init g_ptr_XCExtendRiuBaseAddr = 1FA00000
LINK TYPE = EXT [_MDrv_PNL_Init_LPLL][438]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_LPLL][440]u16HTotal=4400,u16VTotal=2260,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2260, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][490]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_Output_Dclk][492]u16HTotal=4400,u16VTotal=2260,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2260, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 2560]No instance existed, please get an instance by calling MApi_XC_Init() first
Init PWM0Init PWM1Init PWM2mboot:: u16PwmRstAttrFlag = 0
create instance at 2B505468 with private size 1856 bytes at 2B5054B0
[XC,Version]
TCON VERSION 1
[panel_dinit][755] u16Panel_SwingLevel=80
[AT][MB][panel_pre_init][1266]
[inner_tcon_init][430] enter
[TCON] PMU OK
[TCON] Gamma OK
[inner_tcon_init][442] leave
[AT][MB][bootlogo begin][1283]
nuc: HS_LogoSelect Enter, line = 518
nuc: logo_cmd = NULL, line = 523
nuc: logo_state = NULL, show default logo, line = 527
nuc: HS_LoadDefaultLogo Enter, line = 227
nuc: HS_LogoSelect Out, Ret = 0,  line = 566
JPD_InputADDR 726889392 ,724423128
create instance at 2B5367A0 with private size 312 bytes at 2B5367E8
[AT][MB][JPD Decode][1347]
g_state is 5
[showLogo] GOP Boot Logo Index 2
create instance at 2B536928 with private size 1728 bytes at 2B504768
[GOP INFO] gop opencreate instance at 2B504E30 with private size 9596 bytes at 2B505BF8
[_GOP_RegisterAllCBFunc][5606] fpSetFBFmt is NULL.(If on STR state, this is a normal message)
[_GOP_RegisterAllCBFunc][5658] fpEventNotify is NULL.(If on STR state, this is a normal message)
[_GOP_RegisterAllCBFunc][5672] fpXCSetDwinInfo is NULL.(If on STR state, this is a normal message)
<<set_mirror H ON!!>>
[AT][MB][Show Logo][1423]
##Wakeup Source 5
[Mboot][Wakeup Source] System is wake up by SAR!!
[AT][MBoot][Boot Nuttx][1814]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    15742736 Bytes = 15 MiB
   Load Address: 20280000
   Entry Point:  20280000
   Contents:
      Image 0: 13337896 Bytes = 12.7 MiB
      Image 1: 2404828 Bytes = 2.3 MiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
ramdisk start = 0x25CB8574, ramdisk end = 0x25F03750
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
   Loading Multi-File Image ... OK
[AT][MB][start kr][1880]
Starting kernel ...
set 64 bit mode
armfw_real_va_addr : 5EBE3000
optee_real_va_addr : 5EE00000
 [Ian] ARM_FW_Enter_64 259  ARMv8 NS-Uboot for 64bit kernel
 [Ian] ARM_FW_Enter_64 260 25CB8574 24B1DC 20200100
INFO:    CPU0 Preparing for EL3 exit to normal world
INFO:    CPU0 Next image address = 0x20280000
INFO:    CPU0 Next image spsr = 0x3c9
INFO:     [Ian] mstar_primary_kernel_enter 128 2b2dc3a4 20200100 25cb8574 24b1dc
[    0.000000] SAR5=ON
[    0.000000] SAR5=ON[    0.000000] [AT][KR][reset timer][2047]
[    0.000000] thread_info_cache_init, alloc 1536 thread_pool
INFO:    Kernel CPU3 Preparing for EL3 exit to normal world
INFO:    Kernel CPU2 Next image address = 0x202802c0
INFO:    Kernel CPU1 Next image spsr = 0x3c9
[    0.380000] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.430000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.430000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.440000] [KDEBUGD] enter : _MStar
[    0.440000]
[    0.450000] [AT][KR][start init][2491]
[    0.450000] [AutoTest][Kernel][start Initprocess][2491]
[    0.550000] init: property_set("ro.boot.selinux", "permissive") failed
[    0.590000] init: /init.rc: 631: invalid option 'setprop'
[    0.600000] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    0.800000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.810000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.810000] [KDEBUGD] enter : _MStar
[    0.810000]
[    0.820000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.820000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.830000] [KDEBUGD] enter : _MStar
[    0.830000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IINOO:   CPPU  Prppainn  oorEEL  eitt oo eecueewwolld
INNFO:   CCU12 Nxxtiimgge address== x33d00066
NFF::   CCP1  Nxtt maage pps  =001dd
U
hs>>power-on
[AT][MB][start ub][1012]
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
[AT][MBoot][Driver Init][1182]
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[AT][MB][panel_pre_init][1493]
[TCON] PMU OK
[TCON] Gamma OK
[AT][MB][bootlogo begin][1510]
[AT][MB][JPD Decode][1574]
g_state is 5
[AT][MB][Show Logo][1650]
##Wakeup Source 5
[AT][MBoot][Boot Nuttx][2041]
   Contents:
[AT][MB][start kr][2107]
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
[    0.000000] SAR5=ON[    0.000000] [AT][KR][reset timer][2274]
INFO:    Kernel CPU1 Next image address = 0x202802c0
INFO:    Kernel CPU3 Next image spsr = 0x3c9
[    0.360000] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.410000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.410000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.420000] [KDEBUGD] enter : _MStar
[    0.420000]
[    0.420000] [AT][KR][start init][2714]
[    0.430000] [AutoTest][Kernel][start Initprocess][2714]
[    0.810000]
[    0.830000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IINOO:    PUU2Prrpprrnng forEEL eeitttto seuure oord
NFFO:   CCP1  Net  imag aaddrsss== 0xddf00144
IFFO:    CPU2Neett imae  sprr = 011d
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
   Contents:
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
INFO:    Kernel CPU3 Next image address = 0x202802c0
[    0.420000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.420000]
[    0.430000] [AT][KR][start init][2716]
[    0.430000] [AutoTest][Kernel][start Initprocess][2716]
[    0.560000] init: property_set("ro.boot.selinux", "permissive") failed
[    0.600000] init: /init.rc: 631: invalid option 'setprop'
[    0.610000] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    0.810000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.820000] [KDEBUGD] enter : _MStar
[    0.820000]
[    0.830000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.830000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.840000] [KDEBUGD] enter : _MStar
[    0.840000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
INNFO:   CCPU  Prpaarigg frr LL3eext  oo scuur  wolld
INOO     PUU2Neet  iaage dddrsss =00xddf0016
IFFO    CCPU2Neex  imae  spsr== 01dd
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
[AT][MBoot][Boot Nuttx][2039]
   Contents:
[AT][MB][start kr][2105]
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
[    0.000000] SAR5=ON[    0.000000] [AT][KR][reset timer][2272]
[    0.420000]
[    0.420000] [AT][KR][start init][2712]
[    0.430000] [AutoTest][Kernel][start Initprocess][2712]
[    0.510000] init: property_set("ro.boot.selinux", "permissive") failed
[    0.550000] init: /init.rc: 631: invalid option 'setprop'
[    0.560000] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    0.760000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.770000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.770000] [KDEBUGD] enter : _MStar
[    0.770000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IINOO:   CCPU3 reepainng frr E3  exit t  scuuee wrrl
NNFO:   CCUU2NNex  imae  adrrsss== 033d000664
INF:    CCPU3Neettiimaeespps  =00x1d3
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
[AT][MBoot][Boot Nuttx][2040]
   Contents:
[AT][MB][start kr][2106]
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
[    0.000000] SAR5=ON[    0.000000] [AT][KR][reset timer][2273]
INFO:    Kernel CPU2 Next image spsr = 0x3c9
[    0.420000]
[    0.420000] [AT][KR][start init][2713]
[    0.430000] [AutoTest][Kernel][start Initprocess][2713]
[    0.770000]
[    0.780000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.780000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.790000] [KDEBUGD] enter : _MStar
[    0.790000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IIFFO     CP13 Preparingforr EL3 extt oo eccur  worl
IINF:     CU13 Nxxt imae  dddress =00x3df0114
NFFO     PPU  Nxx iimggessssr   011d
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
   Contents:
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
INFO:    Kernel CPU2 Preparing for EL3 exit to normal world
[    0.420000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.440000]
[    0.440000] [AT][KR][start init][2713]
[    0.440000] [AutoTest][Kernel][start Initprocess][2713]
[    0.530000] init: property_set("ro.boot.selinux", "permissive") failed
[    0.570000] init: /init.rc: 631: invalid option 'setprop'
[    0.580000] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    0.790000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.790000]
[    0.800000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    0.810000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IIFFO     CUU  rreaainng forEEL3 exit to scuue  wrlld
INFO     CUU2 eext imgeeaadrres  =0033f00066
IIFFO:   CPP12 Nextiimag ssps  =00x1d3
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
   Contents:
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
INFO:    Kernel CPU1 Preparing for EL3 exit to normal world
[    0.440000]
[    0.440000] [AT][KR][start init][2715]
[    0.450000] [AutoTest][Kernel][start Initprocess][2715]
[    0.520000] init: property_set("ro.boot.selinux", "permissive") failed
[    0.560000] init: /init.rc: 631: invalid option 'setprop'
[    0.570000] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    0.770000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.780000] [KDEBUGD] enter : _MStar
[    0.780000]
[    0.790000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    0.800000] [KDEBUGD] enter : _MStar
[    0.800000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IINOO:    PUU2PPrpprrigg fr  LL3eexttttossecurewoordd
INF::    PPU NNxttiimageaadrress =0033df0164
INF::   CCPU3 eext mmaee pss == xx1d3
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
   Contents:
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
[    0.420000]
[    0.820000]
[    0.840000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IIFFO:    CP1  Prearrig  oor L33 eitt oo eecrre wrrd
IFOO:    PPU Neex  iaag  adrres  = 033f00016
INFO:    CPU2 exxt image pprr   011d3
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
##Wakeup Source 5
   Contents:
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
[    0.420000]
[    0.780000]
[    0.790000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IINF::    CP1  Pepprrigg for E33 xxtt oo seurrewworld
IFOO:    CPU2NNxxt mmage addees  =0x33df0166
IFOO     CP13 exx  imggessprr =0xx1d3
U
hs>>power-on
msIR_Initialize
CPU  : << MStar >>#
DRAM:  197 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
no eeprom
the same ethaddr!
hs>>DC on
hs>>DC on
[XC,Version]
TCON VERSION 1
[TCON] PMU OK
[TCON] Gamma OK
g_state is 5
[AT][MB][Show Logo][1651]
##Wakeup Source 5
   Contents:
Starting kernel ...
set 64 bit mode
[    0.000000] SAR5=ON
[    0.370000] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.430000] [KDEBUGD] enter : _MStar
[    0.430000]
[    0.430000] [AT][KR][start init][2707]
[    0.440000] [AutoTest][Kernel][start Initprocess][2707]
[    0.810000]
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
IINFO:   CCP13PPrpaarigg frr LL3 xxt  t  seuueewworl
IFF::   CCP1  Next mmae  adrress== 0x3d000644
NNFO:    PPU  Next iaage pss == 0x1d3
U
hs>>power-on
msIR_Initialize
[MIU INFO] miu
 楼主| 发表于: 2022-8-20 13:41:04
qj711 2022-8-20 13:17
2022-8-20, 12:7:39
到底问题出在哪里呢,
发表于: 2022-8-21 09:56:22
nmcfzhf 2022-8-20 21:38
重启灯条坏了吧
有可能   也有可能是灰屏
发表于: 2022-8-21 14:49:44
创维海信康佳有几款型号灯条坏了电源总线重启,55A55肯定是灯条坏了。
 楼主| 发表于: 2022-8-22 15:47:58
时代电子小智 2022-8-21 14:49
昨天测试了一下,灯条很可能有问题,用灯条测试仪电压不稳,也不亮,今天看到你的信息,估计板子没有问题,8月6日换的板,当时是卡聚好看,现在灯条又坏了,客户要弃修。
GMT+8, 2024-11-19 01:50 , Processed in 0.054629 sec., 9 queries .
