查看: 925|回复: 1
小米L40M5-4C升级重启反复进行
发表于: 2022-8-4 13:21:42
20金钱
        小米电视L40M5-4C升级重启反复进行
                                     大家帮我看看这个打印信息是什么意思,问题出在哪里。
2022-8-4, 11:11:57
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
bist_test rank: 0 2b 07 4f 31 11 52 28 05 4c 2f 10 4f 26 05 48 32 11 53 22 00 44 37 18 56 650
DDR3 Rank0
run bl31
NOTICE:  BL3-1: v1.0(debug):4fec997
NOTICE:  BL3-1: Built : 19:08:29, Nov  2 2018
aml log : bl31 normal boot !
[Image: txl_v1.1.3168-0e1e562 2019-01-27 16:18:34 qiufang.dai@droid07]
30 7b 30 a7 fe 3 f4 6 d8 3b ea 15 [0.556463 Inits done]
U-Boot 2015.01-g030fac1-g44183d8 (Aug 22 2021 - 19:00:16)
DRAM:  1 GiB
shutdown_reboot
t37z
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =33ebd7f0
copy done
      Single dtb detected
load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x02073950
   Loading Ramdisk to 33c90000, end 33e8e862 ... OK
   Loading Device Tree to 000000001ffef000, end 000000001ffffcd7 ... OK
Starting kernel ...
uboot time: 2707713 us
[    0.000000@0] Linux version 3.14.29-gf4340b3e366 (jenkins@c3-mitv-bsp-build02.bj) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #1 SMP PREEMPT Wed Sep 1 15:29:39 CST 2021
[    0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200 quiet no_console_suspend earlyprintk=aml-uart,0xc81004c0 androidboot.selinux=enforcing ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 logo=osd1,loaded,0x3d800000 vout=1080p60hz,enable panel_type=lvds_3 androidboot.firstboot=0 androidboot.console_enable=0 jtag=disable androidboot.mi.panel_size=40 androidboot.mi.panel_vendor=INX androidboot.mi.panel_resolution=1920x1080 androidboot.mi.panel_buildin=true androidboot.mi.panel_3d_attribut=0 androidboot.panel_type=14 sdc_panel_reverse=1 osd_reverse=all,false video_reverse=0 androidboot.watchdog=enabled androidboot.hardware=amlogic androidboot.hardware_version=030026 androidboot.reboot_mode=shutdown_reboot aux_codec=tas5707 androidboot.ffu_status=1 androidboot.platform_name=txl_xmen_t37z androidboot.platform_id=656 androidboot.curved=0 androidboot.tuner=si2151 androidboot.serialno=21173422100594702 androidboot.assm_mn=T37ZAAF9B11BXNXX0domain-0 init dvfs: 4
[    0.223195@0] genirq: Setting trigger mode 8 for irq 249 failed (gic_set_type+0x0/0xbc)
[    0.807101@0] amlogic-new-usb3 d0078080.usb3phy: This phy has no usb port
[    0.818235@0] wakeup_reason: 0x6
[    0.819927@0] genirq: Setting trigger mode 8 for irq 249 failed (gic_set_type+0x0/0xbc)
[    0.858001@0] get_storage_dev return 1
[    0.945946@1] PPMGRDRV: err: ppmgr_driver_probe called
[    0.967264@1] emmc: retry, rx_phase 0 -> 1
[    0.970355@1] Do't get valid ln_delay @ line 3, try
[    0.972405@1] Do't get valid ln_delay @ line 3, try
[    0.977241@1] Do't get valid ln_delay @ line 3, try
[    1.152284@1] amlvideo2 probe called
[    1.167406@1] aud pll test OK
[    1.175150@1] DVB:async fifo 0 buf size 524288, flush size 262144
[    1.176441@1] cannot find tuner0 driver: si2151_tuner
[    1.196233@1] aml_g9tv: of_get_phonepin_pdata fail to get phone pin from dts!
[    1.197805@1] aml_g9tv: of_get_scanpin_pdata fail to get scan pin from dts!
[    1.204621@1] aml_g9tv: DTD of drc2_table_0 not found!
[    1.209740@1] aml_g9tv: DTD of wall_0 not found!
[    1.214286@1] aml_g9tv: DTD of init_reg_0 not found!
[    1.219216@1] aml_g9tv: of_get_init_pdata : can't get init_reg_buf
[    1.225319@1] aml_g9tv: of_get_init_pdata fail to get input data format
[    1.510217@2] tas5707_set_eq_biquad: tas5707 reg_num 280
[    2.264700@1] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[  [    2.681121@3] init: waitpid failed: No child processes
[    2.685029@3] init: /init.amlogic.rc: 438: invalid command 'e2fsck'
[    2.687649@3] init: could not import file 'init.amlogic.wifi.rc' from '/init.amlogic.rc'
[    2.694885@3] init: could not import file 'init.mtk.rc' from '/init.amlogic.rc'
[    2.702421@3] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    3.640996@2] init: /recovery not specified in fstab
[    3.769702@1] init: cannot find '/sbin/healthd', disabling 'healthd'
[    3.797081@2] dig: dig start!
[    3.797123@2] SysRq : Changing Loglevel
[    3.798230@1] Loglevel set to 4
[    3.820650@3] init: cannot find '/system/bin/remotecfg', disabling 'remotecfg'
[    3.822919@3] init: cannot find '/system/bin/pppoe_wrapper', disabling 'pppoe_wrapper'
[    3.839906@3] init: cannot find '/system/xbin/shelld', disabling 'shelld'
[    3.841281@3] init: cannot find '/system/xbin/mqsasd', disabling 'mqsasd'
[    3.848111@3] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[    3.855284@3] init: cannot find '/system/bin/logo_retriever.sh', disabling 'logo_retriever'
[    3.937435@1] zsmalloc no cma shrinker has been registered.
[    6.335900@2]  key_unify_init() already inited!
[    6.336026@2] name: hdcp14_rx, size 328
[    7.288291@3] FE: cannot find resource "tuner0_reset_gpio"
[    7.288465@3] FE: cannot find resource "atv_demod0_i2c_adap_id"
[    7.294014@3] FE: cannot find resource "atv_demod0_i2c_addr"
[    7.299733@3] FE: cannot find resource "atv_demod0_reset_gpio"
[    7.305412@3] FE: cannot find resource "dtv_demod0_i2c_adap_id"
[    7.311439@3] FE: cannot find resource "dtv_demod0_i2c_addr"
[    7.316923@3] FE: cannot find resource "dtv_demod0_reset_gpio"
[    7.327477@3] FE: cannot find resource "tuner1"
[    7.327520@3] FE: cannot find resource "atv_demod1"
[    7.337406@3] FE: cannot find resource "dtv_demod1"
[   36.152426@3] init: powerctl cmd: dead0003, target: clear storage
[   36.399740@2] SysRq : Emergency Remount R/O
[   36.756875@1] binder_alloc: 2977: binder_alloc_buf, no vma
[   36.834209@3] dig: /cache became read-only!
[   36.834452@3] dig: /data became read-only!
[   38.820433@0] reboot: Restarting system(init) with command 'clear storage'
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd  1.
TXL:BL1:1ef924:56431c;FEAT:ADFC718COC:0;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 58554
BL2 Built : 16:21:29, May 30 2019.
txl g0df0643 - xingyu.chen@droid12-sz
发表于: 2022-8-4 17:37:16
重写EMMC数据试试看!
GMT+8, 2024-11-17 19:52 , Processed in 0.046177 sec., 7 queries .
