查看: 1385|回复: 8
Don't buy the RT809H programmer because it's plain junk!
发表于: 2022-7-15 23:00:31
Dear colleagues! Don't buy the RT809H programmer becauseit's plain junk! Don't waste your money, that programmer has very limited capabilities!
I tried to read and rewrite the eMMC software from two Sony TVs into thesame chip with EMMC_AUTO_ISP flying line. One Sony is Model KD-55X9005C withmainboard 1-894-595-12 and the other is Sony TV Model KD55-X8505C withmainboard 1-894-596-22. With both TVs, I originally had a problem with Androidconstantly restarting. I was not able to solve it by resetting the TV asinstructed by Sony support, so I decided to try to solve the problem with myRT809H programmer. I have pictures of the eMMC pinout and I was able to readthe eMMC chip with my RT809H programmer. Then I did a write with my RT809H andput the read content of 14GBit back into the eMMC chip. However when I tried toturn on my TV after this rewrite my TV behaved like it was completely dead! Nowit doesn't show any signs of life, nor does the stand bay front LED light up atall! I did the same procedure with the motherboard of another Sony TV and gotthe same problem! My other TV is now dead too, don't give any signs of life!Let me mention that the process of reading and rewriting the software to theeMMC chip via the ISP port on the RT809H went without any complications. Thedeveloper did the job successfully and his operating program confirmed thesuccess of the write but unfortunately this is false information!
Frustrated by the failure with my RT809H I soughthelp from a colleague who owns a "Datamann 48Pro2C" Programmer. Mycolleague has eMMC software from Sony TV KD-49X8305C which has mainboard1-894-595-12. With the "Datamann" programmer, we successfully wrotethat software to both of my boards, and behold miracles, both of my Sony TVs  now work normally! Inoticed in the content of the software for Sony Tv owned by my colleague thatit has 4X EXTCSD data, while the program of my RT809H recognizes and reads onlyone single EXTCSD data. ! ??? I got this softwarefrom my colleague and tried to apply it on my RT809H programmer. Writing withthis software, my programmer starts and then the program stops and stays likethat for half an hour, at the end comes the message that "time out".Write EXTCSD data doesn't work at all and just blocks while ROM1, ROM2 and ROM3bin files can be overwritten individually but after that I get nothing! The TVstands as if dead, in the eMMC content it lacks 4X EXTCSD data ! That is not inthe driver program for RT809H and it is not possible to read and write it!
Based on this bad experience, I claim that there is a problem either in theRT809H programmer itself or in its operating program, it is not able toproperly read the software from the eMMC chips of these Sony TVs!
发表于: 2022-7-16 09:51:36
This apparently misleading view is that the defective EMMC chip cannot read the correct data on a broken machine. Vccq1.8v read and write is required on the left side of the 5.1 chip, and the read is verified separately. I don't see anything that doesn't work if I check the same.
发表于: 2022-7-16 12:26:18
EMMC standard, EXTCSD also 512 bytes, no 4*512 bytes ,
  • And only parts of it can be rewritten.
If the Dataman file is truly 4*512 bytes, the vendor may have encrypted the data or created a special format
 楼主| 发表于: 2022-7-16 15:13:12
You are mistaken, my friends! Did you read my text carefully? I repaired my boards without changing the eMMC chips which are 100% correct! However, I did not repair my Sony mainboards with Chinese garbage from RT809H programmers! I did this with the "Datamann" programmer. The Chinese garbage RT809H can't do it because it has a bad operating system! It only reads the EXTCSD data once, while in reality with Soi we have as many as four times the EXTCSD data! RT809H is definitely a very bad and unusable device! Whoever buys it has wasted their money!
 楼主| 发表于: 2022-9-17 16:57:15
Dear Sir / Madam, Chinese Engineers !
I managed to fix both my Sony android TVs! I was able to program the eMMC chips correctly but not with your RT809H programmer. Unfortunately, your programmer does not have that option! I wrote the software on a new eMMC with a „Easy-Jtag plus box“ with an adapter. Now both my TVs are working perfectly normal!
EMMC chips Sony Android TVs  can not be written with RT809H ! I tried writen these  eMMC chip with RT809H through ISP, that connected, I could see the eMMC- I could read and write to it, but the my Sony TV didn't turn on, it didn't show any signs of life.
I had the same problem with programming eMMC chips with Panasonic TVs! So Yours RT809H programmer has major flaws. My opinion is that you have a problem with the program. Your program does not allow correct chip partitioning and RPMB settings! Dear friends, you need to compare the operating program of your RT909 H programmer with the program of "Easy-Jtag plus box" programmer and repair Yours program.
 楼主| 发表于: 2022-9-23 16:32:49
great 2022-7-16 09:51
This apparently misleading view is that the defective EMMC chip cannot read the correct data on a br ...
Dear friend !
EMMC chips Sony Android TVs  can not be written with programmer RT809H, Mainboards 1-894-596-22. 1-894-595-12
and others !  I tried writen these eMMC chip with RT809H through ISP, that connected, I could see the eMMC.
I could read and write to it  but after writing the my Sony TV didn't turn on, it didn't show any signs of life.
I had the same problem with programming eMMC chips with Panasonic TVs! So Ifix RT809H programmer has major flaws,
he can't do writen this eMMC chips!
I managed to fix  my Sony android TVs! I was able to program the eMMC Sony Android TV chips correctly but not with
RT809H programmer. I wrote the software on a new eMMC with a „Easy-Jtag plus box“ with an adapter. Now my  Sony TVs
are working perfectly normal! My opinion RT809H  have a problem with the operating program? Operating program RT809H
does not allow correct chip partitioning and RPMB settings! Engineers-programmers at the IFix company who make the
operating program for the RT809H need to compare this operating program with the program of "Easy-Jtag plus box".
I think that the programmer RT809H would get more possibilities!
发表于: 2022-12-13 22:49:07
saud 2022-9-23 16:32
Dear friend !
EMMC chips Sony Android TVs  can not be written with programmer RT809H, Mainboards  ...
Please provide the file format used by your Dataman48pro2 programmer, and the number and capacity of files!
Does the Dataman48pro2 programmer use offline writing?
Do you want to use 809H to write new files to the chip offline? Can you start the computer after using it? Do not use ISP mode!
发表于: 2022-12-13 23:08:50
楼主的意思可能是:
1、将原机坏的数据读出后,再写入新的EMMC上机,机子不开机!这应该是错误的方式!这种方式不管用那个编程器都不会开机,因为数据本身是坏的!
2、楼主从同事那里得到正常的数据,用另外一个编程器写入上机后,机子开机正常了。
    之后,尝试将这个能正常开机的数据,使用809H编译器写入到芯片中去,发现写入超时,查看文件,发现了4X 数据文件,这个文件应该比809H的EXTCSD大,所以809H编程器没有办法写入!这个有可能是新的编程器对数据进行了特殊处理!但不管怎样,能成功就是好猫!
3、楼主,可以将正常开机的机子,使用809H编程器将数据重新读出来,然后重新写入新的芯片,如果上机正常,说明809H编程器也是好猫!
现在网上有读镜像的读卡器板子,能够完整不加密的读写用户区的数据,加密难道还有必要???
发表于: 2022-12-13 23:11:05
Dear friend !
Landlord, you can use the 809H programmer to re read the data from the machine that is normally powered on, and then re write the data to the new chip. If the operation is normal, the 809H programmer is also a good cat!
GMT+8, 2024-12-21 13:39 , Processed in 0.058651 sec., 10 queries .
