原机故障为灰屏,经检查为VAA电路的一个贴片电容短路,更换后有15电压但还是灰屏,后购买一张逻辑板还是灰屏,断开右边屏排线左面白屏,断开左边排线整个屏都是灰屏,因我是新手,手头维修工具简陋没有修机王,希望大家帮帮忙看看打印信息有问题没有TXL:BL1:1ef924:56431c;FEAT:ADFC318COC:1;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 111013
BL2 Built : 16:15:30, Sep 20 2018.
txl g11fcc28 - xiaobo.gu@droid12
set vcck to 1100 mv
set vddee to 1000 mv
DRAM reset...
init panel power
--------------bt gpio set low---------------
--------------bt gpio set high---------------
Board ID = 2
CPU clk: 1200MHz
DDR enable rdbi
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0 @ 792MHzddr_training_inf: rank: 0 org_wr0 w0_l w0_r org_r0 r0_l r0_r
org_wr1 w1_l w1_r org_r1 r1_l r1_r org_wr2 w2_l w2_r org_r2 r2_l r2_r org_wr3
w3_l w3_r org_r3 r3_l r3_r
af_vrefddr_training_win: rank: 0 26 00 4d 3c 0f 69 1f 00 40 3f 11 6d 27 00 4e 3d 10 6a 20
00 43 43 13 73 678 rank: 1 2f 00 4d 08 0f 69 2e 00 40 0c 11 6d 2f 00 4e 08 10 6a 2f 00 43
0d 13 73 678
bist_test rank: 0 1e 00 3c 39 19 59 1c 00 39 39 19 59 21 01 42 34 16 52 18 00 31 3c 1d 5c
678 bist_size0x 000007e0 bist_cost_time 100150 us bist test no threshold setting:
- PASS
ddr_refi_counter78
Rank0: 1024MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00015400
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x0009fe00
NOTICE: BL3-1: v1.0(debug):3fb6b3e
NOTICE: BL3-1: Built : 16:45:24, Sep 21 2016
aml log : bl31 normal boot !
[Image: txl_v1.1.3156-4163483-dirty 2016-10-18 20:57:12 qiufang.dai@droid07]
OPS=0x02
ea e4 96 14 2 25 1a 1c c6 29 a8 49 [1.291498 Inits done]
secure task start!
high task start!
low task start!
INFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-00126-g778286b (Jul 30 2019 - 11:10:16)
DRAM: 1 GiB
Relocation Offset is: 36ed5000
register usb cfg[0][1] = 0000000037f5c038
MMC: aml_priv->desc_buf = 0x0000000033ed5640
aml_priv->desc_buf = 0x0000000033ed7960
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_startup] mmc refix success
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
Amlogic multi-dtb tool
Single dtb detected
start dts,buffer=0000000033eda1b0,dt_addr=0000000033eda1b0
parts: 11
00: logo 0000000002000000 1
01: recovery 0000000002000000 1
02: param 0000000002000000 2
03: tee 0000000000800000 1
04: crypt 0000000002000000 1
05: misc 0000000002000000 1
06: boot 0000000002000000 1
07: system 0000000042400000 1
08: cache 000000002bc00000 2
09: cri_data 0000000001000000 2
10: data ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
name offset size flag
0: bootloader 0 400000 0
1: reserved 2400000 4000000 0
2: cache 6c00000 2bc00000 2
3: env 33000000 800000 0
4: logo 34000000 2000000 1
5: recovery 36800000 2000000 1
6: param 39000000 2000000 2
7: tee 3b800000 800000 1
8: crypt 3c800000 2000000 1
9: misc 3f000000 2000000 1
10: boot 41800000 2000000 1
11: system 44000000 42400000 1
12: cri_data 86c00000 1000000 2
13: data 88400000 314c00000 4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x33000000
In: serial
Out: serial
Err: serial
ddr_spread = 3000
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
Single dtb detected
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
[KM]Msg:key[project_info] is Exist
(Re)start USB...
USB0: USB3.0 XHCI init start
Register 4000140 NbrPorts 4
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
load rtk usb bt
i=0 dev->devnum:1 dev->mf:u-boot dev->prod:XHCI Host Controller
vid is 0, pid is 0
usb dev is null!!!!
usb start ..........
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
lcd: detect mode: tv, key_valid: 0
lcd: load config from dts
lcd: use panel_type=lvds_209
lcd: bl: name: backlight_pwm, method: 1
lcd: bl: aml_bl_power_ctrl: 0
no need to burn panel
adckey num = 1
into process_low_task
into LOW_TASK_USR_DATA
test_usr_key_nustate_cmd===0
light_state=000bt_mode_cmd = 1
setlow_8723du=0Net: dwmac.c9410000
get_cpu_id flag_12bit=1
saradc - saradc sub-system
Usage:
saradc saradc open <channel> - open a SARADC channel
saradc close - close the SARADC
saradc getval - get the value in current channel
saradc get_in_range <min> <max> - return 0 if current value in the range of current channel
Usage:
wipe_data=successful
wipe_param=successful
wipe_cache=successful
upgrade_step=2
InUsbBurn
noSof
INFO: PSCI Affinity Map:
INFO: AffInst: Level 0, MPID 0x0, State ON
INFO: AffInst: Level 0, MPID 0x1, State OFF
INFO: AffInst: Level 0, MPID 0x2, State OFF
INFO: AffInst: Level 0, MPID 0x3, State OFF
bl31 reboot reason: 0x108
system cmd 0.
bl30 get wakeup sources!
process command 00000006
bl30 enter suspend!
cpu clk suspend rate 1200000000
store restore gp0 pll
process command 00000001
CEC cfg:0x0000
c72db2dcpoweroff 5v - hwid 2
08915c0timerao..
timerao..
timerao..
timerao..
timerao..
timerao..
timerao..
timerao..
timerao..
timerao..
adc key resume
poweron 5v - hwid 2
set vcck to 0x0001mv
exit_reason:0x06
cfg15 3b00000
cfg15 63b00000
BL1:1ef924:56431c;FEATXL:BL1:1ef924:56431c;FEAT:ADFC318COC:1;RCY:0;EMMC:0;READ:0;0.0;CHK:
0;
TE: 126272
set vcck to 1100 mv
DRAM reset...
init panel power
Board ID = 2
CPU clk: 1200MHz
DDR enable rdbi
DQS-corr enabled
af_vrefddr_training_win: rank: 0 27 00 4f 3a 0f 66 1f 00 40 3e 11 6c 27 00 4e 3c 0f 69 20
00 44 40 12 6f 678 rank: 1 2f 00 4f 08 0f 66 2e 00 40 0c 11 6c 2e 00 4e 08 0f 69 2f 00 44
0d 12 6f 678
bist_test rank: 0 1e 00 3d 39 19 5a 1c 00 38 3a 1b 59 22 02 43 33 15 52 19 00 32 3d 1e 5c
678 bist_size0x 000007e0 bist_cost_time 101820 us bist test no threshold setting:
- PASS
ddr_refi_counter78
DataBus test pass!
AddrBus test pass!
-s
OPS=0x02
ea e4 96 14 2 25 1a 1c c6 29 a8 49 [1.308447 Inits done]
secure task start!
high task start!
low task start!
DRAM: 1 GiB
Single dtb detected
parts: 11
In: serial
Out: serial
Err: serial
ddr_spread = 3000
reboot_mode=charging
read emmc dtb
Single dtb detected
[BL31]: tee size: 0
(Re)start USB...
USB XHCI 1.00
load rtk usb bt
vid is 0, pid is 0
usb dev is null!!!!
vpp: vpp_init
adckey num = 1
Usage:
Usage:
upgrade_step=2
[OSD]load fb addr from dts
[OSD]failed to get fb addr for logo
[OSD]use default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=5760, height=2160
lcd: enable: 1080p-vfreq, lvds, 1920x1080@60.0Hz
lcd: tv driver init(ver 20161122): lvds
lcd: lcd_pll_wait_lock: pll_lock=1, wait_loop=1
lcd: bl: set level: 150, last level: 0
lcd: bl: aml_bl_power_ctrl: 1
amlkey_init() 71: already init!
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
Usage:
Usage:
Usage:
Hit Enter or space or Ctrl+C key to stop autoboot -- : 0
Unknown command 'hdmitx' - try 'help'
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =33f5a380
copy done
Single dtb detected
load dtb from 0x1000000 ......
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x02166270
Loading Ramdisk to 33c1e000, end 33ec250d ... OK
Loading Device Tree to 000000001ffd3000, end 000000001ffff8ce ... OK
Starting kernel ...
uboot time: 5465927 us
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Initializing cgroup subsys cpuacct
[ 0.000000@0] Linux version 3.14.29-00333-g4c8334a (HaierAmlogicT968@haier-hp001) (gcc
version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC
4.9-2014.09) ) #1 SMP PREEMPT Tue Aug 6 16:51:13 CST 2019
[ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000@0] no prop version_code
[ 0.000000@0] bootconsole [earlycon0] enabled
domain-0 init dvfs: 4
INFO: HDCP22 rx key read fail!
INFO: pkf 0
INFO: duk 0
INFO: end set
efuse_pw_en: 0x3
WARNING! efuse bits is disabled
Enable A53 JTAG to EE
root@HRA962_1G_WF_R1310:/ # |
