查看: 686|回复: 2
MT01C 809H打印信息
发表于: 2022-5-15 20:04:03
809H打印信息大师们帮忙看一下不知是什么地方出故障?
05:  COM5, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4,
Boot-
DRAM Channel A Calibration.
Byte 0 : DQS(3 ~ 33), Size 31, Set 16.
Byte 1 : DQS(0 ~ 31), Size 32, Set 13.
DRAM A Size = 128 Mbytes.
Boot
Start Pmain
0x000032a0
NID=0x9580f12c
LZHS addr:0x00100040
LZHS size:0x00067220
LZHS checksum:0x000000ff
Boot
Start Lmain
MT5365 Boot Loader v0.9
MUSB none SoftReset 0x29424 = 0x01030000.
MUSB pBase = 0xF0029000 init ok.
MUSB pBase = 0xF002E000 init ok.
Boot reason: A/C power on!!
DUMMY READ EDID DATA FROM EEPROM
Load HDMI internal EDID.................
SIF_Master0: new design
SIF_Master1: old design
Load T8032 FW (addr: 0x  d54d60, size: 24576)success!!
LDR_FlashCopy 0xf010 0x30b80 0x80
Switch NAND pinmux
Detect NAND flash ID: 0x9580F12C
Detect MT29F1G08AAC/ABADA NAND flash(SLC): 128MB
NAND_BDM_Mount: Partid=0, offset=0x0, size=0x100000
[BDM] Partition: 0, Bad Block Count: 0
Do USB upgrade
USB: Vbus turn up time = 253 ms.
No USB device.
USB upgrade stop
---------test LYQ check eeprom boot-----------
Boot reason: A/C power on!!Org:0x30 Flags:0x30
Disable VGA wakeup
Standby          !
Boot
Start Pmain
0x000032a0
NID=0x9580f12c
Boot
Start Lmain
Switch NAND pinmux
Do USB upgrade
USB: Vbus turn up time = 235 ms.
No USB device.
USB upgrade stop
Org:0x30 Flags:0x30
------[_LdrCheckEepromBoot] power mode = standby,ir or button wakeup---------
A_Mute GPIO=326 release
AMP mute GPIO=ca release
Reset Demod GPIO=320, 0->1
NAND load lzhs header from 0x40000 to dram(0xfe0030), size=2048
Decompression uboot to 0x00f00000...
NAND load image from 0x40000 to dram(0xfe0030), size=0x35cbb
LZHS hardware decode start
LZHS hardware decode done
Starting image...
U-Boot starts...
NAND Flash:  Detect NAND flash ID: 0x9580F12C
Detect MT29F1G08AAC/ABADA NAND flash: 128MB
128 MiB
Booting sequence is from NAND Flash
In:    serial
Out:   serial
Err:   serial
eeprom para:140(6ffc90) u4MemLen:0x00000009
eeprom para:149(6ffc84) u4MemLen:0x00000009
eeprom para:152(6ffc78) u4MemLen:0x00000009
eeprom para:140(6ffc4c) u4MemLen:0x00000009
eeprom para:149(6ffc4c) u4MemLen:0x00000009
eeprom para:152(6ffc4c) u4MemLen:0x00000009
eeprom para:140(6ffec0) u4MemLen:0x00000009
Partition rootfsA defined at mtdparts:
ID:6, Offset:0x00800000, Size:0x00500000
Loading from nand0, offset 0x400000
Automatic boot of image at addr 0x00008000 ...
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux....................................................................................... done, booting the kernel.
Linux version 2.6.27 (w.y@mtkvm) (gcc version 4.4.2 (GCC for MediaTek 4.4.2-20100324)) #1 PREEMPT Sun Jan 1 06:43:14 WET 2012
CPU: ARMv6-compatible processor [410fb764] revision 4 (ARMv7), cr=00c5387d
Machine: MT5365
Memory policy: ECC disabled, Data cache writeback
CPU0: D VIPT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 15494
Kernel command line: root=/dev/mtdblock6 lpj=3506176 console=ttyMT0,115200n1 mtdparts=mt53xx-nand:1M(uboot),1M(uboot_env),1M(sigA),1M(sigB),2M(kernelA),2M(kernelB),5M(rootfsA),5M(rootfsB),28M(basic),70M(rw_area),128k(perm),128k(reserved),2M(channelsA),2M(channelsB),1M(pq),1M(aq),2M(logo)
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttyMT0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 61MB = 61MB total
Memory: 59060KB available (2492K code, 147K data, 92K init)
Calibrating delay loop (skipped) preset value.. 1402.47 BogoMIPS (lpj=3506176)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 288 bytes
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
squashfs: version 3.4 (2008/08/26) Phillip Lougher
msgmni has been set to 115
io scheduler noop registered (default)
Serial: MT5365 driver $Revision: #2 $
ttyMT0 at MMIO 0xf000c000 (irq = 17) is a MT5365 Serial
ttyMT1 at MMIO 0xf000c000 (irq = 17) is a MT5365 Serial
ttyMT2 at MMIO 0xf0028800 (irq = 0) is a MT5365 Serial
ttyMT3 at MMIO 0xf000c000 (irq = 17) is a MT5365 Serial
brd: module loaded
compcache: compcache size not provided. Using default: (25% of Total RAM).
Use compcache_size_kbytes module param to specify custom size
compcache: Compressed swap size set to: 14780 KB
TLSF: pool: c4009000, init_size=16384, max_size=0, grow_size=16384
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
17 cmdlinepart partitions found on MTD device mt53xx-nand
Creating 17 MTD partitions on "mt53xx-nand":
0x00000000-0x00100000 : "uboot"
0x00100000-0x00200000 : "uboot_env"
0x00200000-0x00300000 : "sigA"
0x00300000-0x00400000 : "sigB"
0x00400000-0x00600000 : "kernelA"
0x00600000-0x00800000 : "kernelB"
0x00800000-0x00d00000 : "rootfsA"
0x00d00000-0x01200000 : "rootfsB"
0x01200000-0x02e00000 : "basic"
0x02e00000-0x07400000 : "rw_area"
0x07400000-0x07420000 : "perm"
0x07420000-0x07440000 : "reserved"
0x07440000-0x07640000 : "channelsA"
0x07640000-0x07840000 : "channelsB"
0x07840000-0x07940000 : "pq"
0x07940000-0x07a40000 : "aq"
0x07a40000-0x07c40000 : "logo"
TCP cubic registered
NET: Registered protocol family 17
VFS: Mounted root (squashfs filesystem) readonly.
Freeing init memory: 92K
INIT: version 2.86 booting
Mounting local filesystems: mount mount: according to /proc/mounts, /dev/root is already mounted on /
Loading /etc/profile...
Running rc.local...
net.ipv4.tcp_window_scaling = 6
# mount basic
UBI device number 0, total 224 LEBs (28442624 bytes, 27.1 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
real        0m 0.09s
user        0m 0.00s
sys        0m 0.06s
UBIFS: recovery needed
UBIFS: recovery completed
real        0m 0.17s
user        0m 0.00s
sys        0m 0.09s
DTV>[_read_project_id_from_eep]Three project id same
Load Project ID Number: 0 !!
Find panel index 140 from EEPROM
OSD_SetTVEOut: 1
[Drv_display] flip_mirror_true
osd flip en
osd mirror en
Mapped physical address 0x3d00000 - 0x8000000 to virtual begins 0xc5000000
GFX flip en
GFX mirror en
OSD_SetTVEOut: 1
DFB JPEG OSD: ca000000, PHY:64cf000, SIZE: 17eb000
DFB screen_base cc000000, PHY:3ffc000
L:::::} -1, -1
Create Region List
{XXXXX} 0, -1
End init hw for FB
star: eth_base=0xc413e000
star: pinmux_base=0xc4140400
star: ipll_base1=0xc4142000
star: desc addr: 0xffc00000(virtual)/0x01bf1000(physical)
star: Cannot detect PHY addr, default to 1
star: Star MAC init done
ramzswap: disk size set to 25600 kB
------------[ cut here ]------------
WARNING: at /share/w.y/TCL_CODE_MT5301E_20110302_1534/release/vm_linux/chiling/kernel/linux-2.6.27/fs/sysfs/dir.c:463 sysfs_add_one+0x34/0x48()
sysfs: duplicate filename 'ramzswap0' can not be created
Modules linked in: ramzswap(+) xvmalloc star_mac ioctl_reg_func fusion
[<c02002b8>] (dump_stack+0x0/0x14) from [<c0035b2c>] (warn_slowpath+0x64/0x9c)
[<c0035ac8>] (warn_slowpath+0x0/0x9c) from [<c00c9e70>] (sysfs_add_one+0x34/0x48)
r3:c3a18ce0 r2:c0258c3e
r6:c20b5dcc r5:c20bb7e8 r4:ffffffef
[<c00c9e3c>] (sysfs_add_one+0x0/0x48) from [<c00ca588>] (create_dir+0x58/0xa4)
r5:c1bf06b0 r4:c380f4e8
[<c00ca530>] (create_dir+0x0/0xa4) from [<c00ca618>] (sysfs_create_dir+0x44/0x64)
r8:c001fea4 r7:00000000 r6:c382d4e8 r5:c1bf06b0 r4:c1bf06b0
[<c00ca5d4>] (sysfs_create_dir+0x0/0x64) from [<c013c0c4>] (kobject_add_internal+0xf4/0x1d0)
r4:c382d4e8
[<c013bfd0>] (kobject_add_internal+0x0/0x1d0) from [<c013c284>] (kobject_add_varg+0x40/0x50)
r9:c20b4000 r8:c001fea4 r7:00000000 r6:00000000 r5:c1bf06b0
r4:c382d4e8
[<c013c244>] (kobject_add_varg+0x0/0x50) from [<c013c330>] (kobject_add+0x58/0x64)
r7:00000000 r6:c1bf0600 r5:c1bf06b0 r4:c1bf0648
[<c013c2d8>] (kobject_add+0x0/0x64) from [<c016ea48>] (device_add+0xa4/0x574)
r3:c1bf06d4 r2:c024f328
[<c016e9a4>] (device_add+0x0/0x574) from [<c00c7a14>] (register_disk+0x64/0x15c)
[<c00c79b0>] (register_disk+0x0/0x15c) from [<c0136b3c>] (add_disk+0x50/0xb0)
r7:00000000 r6:c1bf0600 r5:00000000 r4:c1bf0600
[<c0136aec>] (add_disk+0x0/0xb0) from [<bf5c751c>] (ramzswap_init+0x51c/0x6dc [ramzswap])
r5:00000000 r4:bf5c5660
[<bf5c7000>] (ramzswap_init+0x0/0x6dc [ramzswap]) from [<c001f31c>] (__exception_text_end+0x54/0x188)
r9:c20b4000 r8:c001fea4 r7:00000000 r6:00000000 r5:bf5c7000
r4:bf5c5520
[<c001f2c8>] (__exception_text_end+0x0/0x188) from [<c0059a88>] (sys_init_module+0x98/0x184)
r8:c001fea4 r7:00022d5f r6:00000000 r5:000af0a0 r4:bf5c5520
[<c00599f0>] (sys_init_module+0x0/0x184) from [<c001fd00>] (ret_fast_syscall+0x0/0x2c)
r7:00000080 r6:beaf7b94 r5:00000069 r4:00000000
---[ end trace 8940925e2cac9cad ]---
kobject_add_internal failed for ramzswap0 with -EEXIST, don't try to register things with the same name in the same directory.
[<c02002b8>] (dump_stack+0x0/0x14) from [<c013c160>] (kobject_add_internal+0x190/0x1d0)
r4:c382d4e8
r4:bf5c5520
WARNING: at /share/w.y/TCL_CODE_MT5301E_20110302_1534/release/vm_linux/chiling/kernel/linux-2.6.27/block/genhd.c:197 add_disk+0x98/0xb0()
[<c02002b8>] (dump_stack+0x0/0x14) from [<c0035bb0>] (warn_on_slowpath+0x4c/0x84)
[<c0035b64>] (warn_on_slowpath+0x0/0x84) from [<c0136b84>] (add_disk+0x98/0xb0)
r6:c1bf0600 r5:c387ace0 r4:c1bf0600
r4:bf5c5520
Adding 25592k swap on /dev/ramzswap0.  Priority:-1 extents:1 across:25592k
[AppManager]init
[AppManager]init dfb start
L:::::} 0, 0
Remove old Region
{XXXXX} 0, 0
End init hw for FB
input thread's parent pid is 313 tid is 313
[DirectFB]: Wait to Init IR...!
[ProcessManager]init
[AM] init succeed
[AM] default process state '4' 'dtv_app_mtk'
drv_init as EU model
Preloader T8032 ack !
Watchdog enable:800023330
[CEC]_Cec_Process8032Data msg num = 0.
TunerInit.....................[LVDS] DVOPLL init control word only
[LVDS] VOPLL Initialize successful !
[_APOGEE_DacFmtCfg] : TAS5707 DAC Format Config!
[NPTV]Display Init[NPTV]Video SW Init[_APOGEE_Init] : TAS5707 Reset!
Zero TDC memory address
Scene ID, APL, Noise Value,Bin0,Bin1,Bin2,Bin3,Bin4,Bin5,Bin6,Bin7,Bin8,Bin9,Bin10,Bin11,Bin12,Bin13,Bin14,Bin15,DS0,DS1,DS2,DS3,DS4,DS5,DS6,DS7,DS8,DS9,DS10,DS11,DS12,DS13,DS14,DS15,MoPxlRatio,MinDS,MaxDS,DSRatio,AvgDS,Noise Level,Final Confidence,MoPxl ?
 楼主| 发表于: 2022-5-15 20:30:16
望技术工程师帮助一下?
 楼主| 发表于: 2022-5-16 09:34:07
xiexinchong 2022-5-15 20:30
望技术工程师帮助一下?
能遥控开机,就是没有背光开启电压和屏12V电压
GMT+8, 2024-12-20 20:41 , Processed in 0.060566 sec., 9 queries .
