查看: 991|回复: 11
求助帮看看海信HZ50E3D打印信息 那里问题
发表于: 2022-4-18 09:09:10
0921103745-008225  ,PCB V1.60,Boot V1.00
003:  >------------------------------------OK---------------------------------------<
004:  C:\Users\Administrator\Desktop\Print.log
005:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
006:  C:\Users\Administrator\Desktop\Print.log
007:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
008:  C:\Users\Administrator\Desktop\Print.log
009:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
010:  C:\Users\Administrator\Desktop\Print.log
011:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
012:  C:\Users\Administrator\Desktop\Print.log
013:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
014:  C:\Users\Administrator\Desktop\Print.log
015:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
Bootrom start
Boot Media: eMMC
Decrypt auxiliary code ...OK
Entry boot auxiliary code
Reg Version:  v1.5.3l
Reg Time:     2018/01/17 21:07:26
Reg Name:     hi3751v551dmoA_2layers_cpu1100Mbps_DDR4_1866_1536M_1024Mch0_512Mch1_emmc.reg
DDRTR Suc
Boot auxiliary code success
Bootrom success
System startup
Fastboot 3.3.0 (gfkfcmo@compile05.56.12045.pzgl.com) (Feb 27 2020 - 18:01:03)
Fastboot:      Version 3.3.0
Build Date:    Feb 27 2020, 18:01:52
CPU:           Hi3751v550
Boot Media:    eMMC
MMC:   Synopsys Mobile storage: 0
MMC/SD Card:
    MID:         0x000015
    OID:         0x0100
    PSN:         0x202df04d
    DATA:        09/2016
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Clk:    50000000Hz
    Host Div:    0
    Bus Width:   8bit
    Chip Size:   7818182656 Bytes (High Capacity)
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Boot Addr:   0
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
       irq stack: 0x0cafff7c - 0x0cbfff7c  1 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10ca14f8  645.2 KiB
            data: 0x10ca14f8 - 0x10d5b980  745.1 KiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
SDK_VERSION: [HiDPTAndroidV500R001C00SPC060_20171109]
eMMC SLC mmc type 10%-20% device life time used
eMMC MLC mmc type 10%-20% device life time used
eMMC pre_eol_info normal
No eeprom.
sizeof(HisDatabase) = 1024!
Set CEC onetouchplay :0
BootMode = POWER OFF
get bootloader message reserved:
BootMode = 1 ACDC = 0
will_enter_recovery = 0
boot_after_reboot = 0
ReadFactroyM: sizeof(HisDatabase)=1024.
ReadFactroyM: FactoryMode is 0
sizeof(HI_BOOT_FRONT_LED_MODE_S) = 16.
System suspend,set HI_BOARD_BLUE_LED_GPIONUM high !
Set red led off !
Go to sleep
System suspend.
nuc: poweroff backlight.
======== [PARAM] ========
SYSID: 0x19060550
DBGMASK: 0x00000001
SUSPENDTYPE: 0x00000000
GPIO POWER KEY: 0x00000000
GPIO LEVEL: 0x00000000
TIMER WAKEUP: 0xFFFFFFFF
IRTYPE: 0x00000004
IR NUM: 0x00000001
IR KEY: 0xF20DBF00
LSADC ZERO: 0x000000FC
LSADC channel A enable
LSADC channel B enable
LSADC GLITCHSAMPLE: 0x00000005
LSADC TIMESCAN: 0x00000258
LSADC POWERKEY0: 0x00000000, 0x000000EC
LSADC POWERKEY1: 0x000000FF, 0x000000FF
LSADC POWERKEY2: 0x000000FF, 0x000000FF
LSADC POWERKEY3: 0x000000FF, 0x000000FF
UART Wakeup Key: 0x000000FF
Auto wakeup flag: 0x00000000
Wakeup Condition: 0x00000041
Light off
CEC ONE Play:0x00000000
HDMIRX_CLK_WKUP:0x00000000
HDMIRX HPD invert:0x00000006
HDMIRX HPD function:0x00000000
HDMIRX bCecWkup:0x00000000
HDMIRX enSuspendPort:0x00000005
HDMIRX HI3751V550:lsadc:6bit,data_delta=8,enable deglitch,power down,continue scan
====== [MCU Init Ready] ======
Power down ARM ===>
Set MCU to 24MHz ===>
Config bus core idle state ===>
Test bus core state ===>
DDR_PowerCtrl:20101
====== [ARM Power Down] ======
 楼主| 发表于: 2022-4-18 09:48:09
===== [Waiting for Powerkey] =====
IR key: 0xF20DBF00
Power On!
====== [Wake up by IR] ======
light deinit
Suspend last 8s
====== [ARM Power On] ======
Bootrom start
Boot Media: eMMC
DDRTR Suc
Bootrom success
System startup
CPU:           Hi3751v550
Boot Media:    eMMC
MMC/SD Card:
    MID:         0x000015
    OID:         0x0100
    PSN:         0x202df04d
    DATA:        09/2016
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Div:    0
    Bus Width:   8bit
    Boot Addr:   0
Boot Env on eMMC
No eeprom.
Set red led off !
Go to sleep
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[951] :--Board Name is:HI3751V551_E3D_TCONLESS_BOARD, Power on optimize: TRUE
Read enLedMode=0,enLedType=1,enPowerOnLed=1.
Set HI_BOARD_LED_GPIONUM  low !
Set power on led on !
CUSTOM Func[CustomBtWiFiPowerOn] Line[169] :Custom 5V WIFI Power On
CUSTOM Func[CustomBtWiFiPowerOn] Line[174] :Custom WiFi Reset PULL DOWN
CUSTOM Func[CustomBtWiFiPowerOn] Line[178] :Custom Bt Reset PULL DOWN
CUSTOM Func[CustomBtWiFiPullDown] Line[160] :Custom Bt Reset PULL DOWN
---:HS_VBO_MODE, not in factory mode !
[HI_DRV_PANEL_Init]-[3511]Panel Init
CUSTOM Func[HI_DRV_CUSTOM_GetParseParamMode] Line[1398] arse Tcon.Bin![PANEL_DRV_ParseTconFile]-[421]-----BigSize:25176!!
[PANEL_DRV_ParseInterface]-[224]current Interface is [ISP]
[PANEL_DRV_SetTconCfg]-[610]WRITE TCON BIN REG!!!
DISP_HAL_Get_PanelCfgPara SyncInfo: Hact=3840 Hfb=200 Hbb=360 Vact=2160 Vfb=30 Vbb=60
tcon-less case, pq tcon will work
Tpll u32Clk=297000000, u32IntPart=0x4063, u32MinorPart=0x12000000
TPLL Lock Success u32Tmp=10
tcon hpll u32Clk=891000000, u32IntPart=0x1001023, u32MinorPart=0x13a3d70a
HPLL Lock Success u32Tmp=2
HPLL set new mode
u32PixelClk=594000000, HpllTargetClk=891000000,u32HpllCtrl0=0x13a3d70a, u32HpllCtrl1=0x1001023
Set Disp 1 SyncInfo: V (30, 60, 2160) H (200, 360, 3840)
SrInCscEnable=1 , SrOutCscEnable=1, SrInColor=12, SrOutColor=12
enSrPosition =1 stSrZmePara In wh[1920 1080] Out wh[3840 2160] ZME_FMT =2
Set LOG Level [HI_TRACE_LEVEL_WARN]
nuc: u32LogoDataAddr = 0xcc424c8, &u32LogoDataAddr = 0xcafff00
nuc: HS_LogoSelect Enter, line = 571
nuc: logo_cmd = <NULL>, logo_state = <NULL>
nuc: logo_cmd  = NULL, line = 588
nuc: logo_state = NULL, show default logo, line = 592
nuc: HS_LoadDefaultLogo Enter, line = 272
nuc: HS_GetLogoParam ok, line = 277
nuc: HS_LoadDefaultLogo Out, Ret = 0,  line = 289
nuc: HS_LogoSelect Out, Ret = 0, line = 633
nuc: u32LogoDataAddr = 0xce465e0, stLogoParam.u32LogoLen = 75902
CUSTOM Func[CustomBtWiFiReset] Line[187] :Custom WiFi Reset PULL UP
CUSTOM Func[CustomBtWiFiReset] Line[191] :Custom Bt Reset PULL UP
RCtune Value is 3
[HI_DRV_PANEL_SetPowerOn]-[2889]Set Param [Enable:1]
CUSTOM Func[HI_DRV_CUSTOM_GetParseParamMode] Line[1398] arse Tcon.Bin!---arseMode is TconBin,PmuGammaInit!
TconLess: PMU HI_DRV_PDM_InitTconPMU
TconLess: Tcon PMU has been initalized, no need to config
TconLess: GAMMA HI_DRV_PDM_InitTconGamma
TconLess: Tcon Gamma has been initalized, no need to config
---:TconLess. HS_TCONLESS_PmuGammaInit success!
LdmSupport:0, Mcu:0
tag is: version=1.0.0.2 panelparam=0x2bbf4000,0xa000 tconparam=0x2bbea000,0x9000 SR_ZME_COEF=0x2bbe7000,0x2000 HIFB_ZmeCoef=0x2bade000,0x3000 HIFB_DispBuf_HD=0x2b2f4000,0x7e9000
mac:64:AE:F1:4B:7C:C3
---boot_select:read misc cmd :
hs>>power-on.
Not in Factory M,need't upgrade.
press the ir!!!
[HI_DRV_PANEL_SetIntfPowerTimer]-[255]---Intf Power---
[HI_DRV_PANEL_SetIntfPower]-[2757]Set Param [PowerOn:1]
[PANEL_DRV_SetPanelBlPowerTimer]-[262]---Set Backlight on---
--------Set Backlight on :1---
PANEL_DRV_SetBlDriverPower[1742]ERROR: get key = 0xe3a0000000000000, status = 281604608, ret = -1
ir failure. status = 281604608, ret= -1
get the ir code 0xffffffffffffffff
keypad value keycode=0x0
get_bootloader_message: HI_Flash_Read partion misc successfully
Reserve Memory
    Start Addr:          0x2BBFF000
    Bound Addr:          0x13D5C000
    Free  Addr:          0x2A80C000
    Alloc Block:  Addr        Size
                  0x2A80C000       3133440
                  0x2AB0A000       8294400
                  0x2B2F4000       8294400
                  0x2BADE000       12288
                  0x2BAE2000       1048576
                  0x2BBE3000       12288
                  0x2BBE7000       8192
                  0x2BBEA000       36864
                  0x2BBF4000       40960
Press Esc to stop autoboot
MMC read: dev # 0, block # 221184, count 128 ... 128 blocks read: OK
MMC read: dev # 0, block # 157696, count 51200 ... 51200 blocks read: OK
MMC read: dev # 0, block # 219136, count 128 ... 128 blocks read: OK
INFO:set pdmparam version=1.0.0.2 panelparam=0x2bbf4000,0xa000 tconparam=0x2bbea000,0x9000 SR_ZME_COEF=0x2bbe7000,0x2000 HIFB_ZmeCoef=0x2bade000,0x3000 HIFB_DispBuf_HD=0x2b2f4000,0x7e9000 .
INFO: fdt_add_mem  base = 2bbf4000,len = a000
INFO: fdt_add_mem  base = 2bbea000,len = 9000
INFO: fdt_add_mem  base = 2bbe7000,len = 2000
INFO: fdt_add_mem  base = 2bade000,len = 3000
INFO: fdt_add_mem  base = 2b2f4000,len = 7e9000
bl33_ep->spsr = 0x3C5
Start Warm reseting
NOTICE:  BL31: v1.2(release):fcfc964
NOTICE:  BL31: Built : 10:38:10, Nov  4 2017
Starting kernel ...
[    0.164251] of_dma_request_slave_channel: dma-names property of node '/amba/uart@f8b00000' missing or empty
[    0.214700] FEPHY:addr=1, la_am=0xd, ldo_am=0x3, r_tuning=0x19
[    0.290892]  (null): PHY already attached
[    0.294884] hieth:hieth_platdev_probe_port:511: connect to phy_device himii:01 failed!
[    0.398945] clk: failed to reparent sdio0_mux_clk to sdio0_sclk50m: -22
[    0.567051] ehci-platform f9890000.ehci: port 1 reset complete, port enabled
[    0.676049] ehci-platform f9890000.ehci: port 1 reset complete, port enabled
[    0.835980] Warning: unable to open an initial console.
[    0.873220] init: property_set("ro.hardware", "unknown") failed
[    0.881738] init: SELinux: Could not set context for /sys/fs/selinux:  Operation not supported on transport endpoint
[    0.911529] init: waitpid failed: No child processes
[    0.917512] init: /init.rc: 25: invalid keyword 'setcon'
[    0.924856] init: ignored duplicate definition of service 'bootvideo'init: ignored duplicate definition of service 'adbd'init: (Parsing /init.hisense.service.rc took 0.01s.)
[    0.940836] init: ignored duplicate definition of service 'btmonitor'init: (Parsing /init.hisense.on_property.rc took 0.01s.)
[    0.952449] init: ignored duplicate definition of service 'adbd'init: (Parsing /init.usb.rc took 0.01s.)
[    0.962566] init: could not import file '/init.trace.rc' from '/init.rc': No such file or directory
[    0.971635] init: ignored duplicate definition of service 'dtvserver'init: (Parsing /init.hidolphin.rc took 0.01s.)
[    0.982071] init: could not import file '/init.bluetooth.rc' from '/init.rc': No such file or directory
[    0.992077] init: /initrc/mediaserver.rc: 5: invalid keyword 'setprop'
[    0.999199] init: /initrc/mediadrmserver.rc: 5: invalid keyword 'setprop'
[    1.178480] init: /dev/hw_random not found
[    1.188961] init: /dev/hw_random not found
[    1.441388] EXT4-fs (mmcblk0p12): VFS: Can't find ext4 filesystem
[    1.447908] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/platform/soc/f9830000.emmc/by-name/securestore at /securestore options: block_validity,nodiscard,data=ordered,errors=remount-ro,barrier=1 error: Invalid argument
[    1.478577] init: fs_mgr_mount_all returned an error
[    1.484376] init: fs_mgr_mount_all returned unexpected error 255
[    1.493536] init: couldn't write 1548 to /dev/cpuset/system-background/tasks: No such file or directory
[    1.494358] init: couldn't write 1549 to /dev/cpuset/system-background/tasks: No such file or directory
[    1.513728] init: couldn't write 1550 to /dev/cpuset/foreground/tasks: No such file or directory
[    1.965069] init: property_set("ro.adb.secure", "1") failed
[    1.971115] init: property_set("ro.build.version.incremental", "01.02.40.02") failed
[    1.979734] init: /recovery not specified in fstab
[    1.985336] init: property_set("ro.vendor", "hisi") failed
[    1.990846] init: property_set("ro.tv.chip.vendor", "hisi") failed
[    1.997058] init: property_set("ro.product.series", "HISIV551") failed
[    2.003622] init: property_set("ro.product.name", "VIDAA_TV") failed
[    2.009959] init: property_set("ro.product.model", "VIDAA_TV") failed
[    2.016501] init: property_set("ro.tv.arc.hdmi.port", "2") failed
[    2.022636] init: property_set("ro.tv.wb_pattern_supported", "true") failed
[    2.029681] init: property_set("ro.tv.mhl.hdmi.port", "255") failed
[    2.036043] init: property_set("ro.data.build.date.utc", "1472124315") failed
[    2.043163] init: property_set("ro.hisense.usb_dongle_enable", "0") failed
[    2.154139] init: couldn't write 1618 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.157347] init: cannot find '/system/bin/jamdeod' (No such file or directory), disabling 'jamdeod'
[    2.161136] init: couldn't write 1621 to /dev/cpuset/system-background/tasks: No such file or directory
[    2.161542] init: couldn't write 1624 to /sys/fs/cgroup/stune/foreground/tasks: No such file or directory
[    2.161809] init: couldn't write 1623 to /dev/cpuset/system-background/tasks: No such file or directory
[    2.162374] init: cannot find '/system/bin/browserserver' (No such file or directory), disabling 'browserserver'
[    2.162541] init: Service toltech does not have a SELinux domain defined.
[    2.164587] init: couldn't write 1619 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.164599] init: couldn't write 1619 to /dev/stune/foreground/tasks: No such file or directory
[    2.166386] init: cannot find '/system/bin/hikaraokeservice' (No such file or directory), disabling 'hikaraokeservice'
[    2.166809] init: cannot find '/system/bin/displaysetting' (No such file or directory), disabling 'display'
[    2.166827] init: cannot find '/system/bin/hiquickplay' (No such file or directory), disabling 'hiquickplay'
[    2.166845] init: cannot find '/system/bin/dtvserver' (No such file or directory), disabling 'dtvserver'
[    2.166860] init: cannot find '/system/bin/tvserver' (No such file or directory), disabling 'tvserver'
[    2.168555] init: cannot find '/system/etc/audiostate_changed.sh' (No such file or directory), disabling 'audiostate'
[    2.168585] init: cannot find '/system/bin/skyplayserver' (No such file or directory), disabling 'skyplayserver'
[    2.168610] init: cannot find '/system/bin/dlnaserver' (No such file or directory), disabling 'dlnaserver'
[    2.178075] init: couldn't write 1640 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.178477] init: couldn't write 1641 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.178730] init: couldn't write 1643 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.179035] init: couldn't write 1642 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.179278] init: couldn't write 1646 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.179514] init: couldn't write 1647 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.179740] init: couldn't write 1645 to /dev/cpuset/foreground/tasks: No such file or directory
[    2.374890] init: couldn't write 1618 to /sys/fs/cgroup/stune/foreground/tasks: No such file or directory
[    2.655838] init: Service toltech does not have a SELinux domain defined.
[    2.819059] init: cannot find '/system/bin/teecd' (No such file or directory), disabling 'teecd'
<IAMREADY>
 楼主| 发表于: 2022-4-18 11:38:09
难道大家一点都看不懂,我是一点没不懂的
发表于: 2022-4-18 11:48:20
海信近年生产的电视机用的海力士的EMMC,在1-2年损坏的很多,这种一般是EMMC 不良,可能升级也不行,就果断更换吧。
发表于: 2022-4-18 11:55:28
我感觉还是固件的问题
 楼主| 发表于: 2022-4-18 12:34:42
已经换了三星8G EMMC和没换一样子 摇控器和电视键都能开关机 没开机音乐 U盘程序和备份爱修论谈下的,板上电压基本正常 2021年12月份出厂的  不知海力士和三星是不能代换?
 楼主| 发表于: 2022-4-18 12:40:57
有背光 黑屏海信HZ50E3D 主板 RSAG7.820.9399/ROH图纸我已传论谈
 楼主| 发表于: 2022-4-18 13:14:08
继续汇报:VGHD1,VG1,VG2,TER1,都无电压。VGL1是负10.5V  .PMU1是1.8V 正常 看来是屏无开启信号   主芯片坏了? 程序不对?EMMC代换问题?
发表于: 2022-4-18 21:00:40
先升级程序,不行就换EMMC,最好换原型号的,不要代用,除非你修复了,确定是EMMC的问题了,再研究代换,
 楼主| 发表于: 2022-4-23 14:35:20
N19  型号AO4459 4脚有屏开启电压12V   5,6,7,8脚无电压,V11 3904NPN管 B极0V  E极0V  C极12V
GMT+8, 2024-11-19 04:29 , Processed in 0.060535 sec., 9 queries .
