查看: 367|回复: 0
LED46K360J 打印问题
发表于: 2022-4-6 19:33:18
LED46K360J更换CPU后不停打印,不开机
2022-4-5, 20:47:55
COM6, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 72), Size=71, Mid=37, Set=37.
Byte 1 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 2 : Gating(2 ~ 77), Size=76, Mid=39, Set=39.
Byte 3 : Gating(2 ~ 72), Size=71, Mid=37, Set=37.
HW Byte 0 : DQS(13 ~ 44), Size 32, Set 28, HW_Set 32.
HW Byte 1 : DQS(10 ~ 41), Size 32, Set 25, HW_Set 29.
HW Byte 2 : DQS(11 ~ 44), Size 34, Set 27, HW_Set 28.
HW Byte 3 : DQS(8 ~ 44), Size 37, Set 26, HW_Set 27.
DRAM A Size = 512 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x2b5e7029
:0x04010064
:0x32473163
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x000a6c10
LZHS checksum:0x00000017
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: Watch dog0 reset (0x1000000)
use code based  EDID.................
Load HDMI internal EDID.................
CEC Physical offset 152
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0xdf
HDMI2 PA 0x10
HDMI2 checksum 0xdf
HDMI3 PA 0x20
HDMI3 checksum 0xcf
HDMI4 PA 0x30
HDMI4 checksum 0xbf
SIF_Master0: new design
IR DATA register : 0x       0
!!T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x  d80fc0, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x59d80 0x80
1st MAC in EEP is valid (90:cf:7d:dc:96:22)
1st : (90:cf:7d:dc:96:22)
2nd : (ff:ff:ff:ff:ff:ff)
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 204 ms, Max =0 ms.
USB-0: insert.
USB-0: ClassCode= 0x8, u4Diff=139 ms.
FIND_CLASS_MASS_STORAGE.
Wait USB medium to be mounted...
USB Medium on Device, Time = 1124 ms.
USB block size = 512 bytes.
[_LdrUsbFileRead].
[_LdrUsbFileRead]..
[_LdrUsbFileRead]Hisense_5505
Error: No upgradexxx.pkg was found
Error: No valid upgrade file found, USB upgrade stop
!!Boot reason: Watch dog0 reset (0x1000000)
!!Org:0x30 Flags:0x30
Flash load lzhs header from 0x80000 to dram(0x15418d0), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x15418d0), size=0x36825
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Oct 15 2013 - 12:51:51)
DRAM:  362 MiB
WARNING: Caches not enabled
MMC:   HOST 1
Dev Num: 0, Timing Position: 0, Sample Edge: 0x00
90014A48:32473163:04010064:2B5E7029
id1:4A483247 id2:31630401
eMMC Name: UNKNOWN
Dev Num: 0, Timing Position: 1, Sample Edge: 0x00
Dev Num: 0, Timing Position: 2, Sample Edge: 0x11
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
PDWNC_REBOOT_CMD_OFFSET contains
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
Initializing cgroup subsys cpuset
Linux version 3.0.13 (buildtv15@brllx038) (gcc version 4.5.1 (GCC) ) #1 SMP PREEMPT Tue Oct 15 12:51:33 EDT 2013
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: MT5880
Memory policy: ECC disabled, Data cache writealloc
====> PMEM BOOTMEM ALLOC <=====
allocating 49283072 bytes at   (null) (40000000 physical) for pmem arena
PERCPU: Embedded 7 pages/cpu @c08ef000 s4960 r8192 d15520 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 91948
Kernel command line: lpj=4571136 console=ttyMT0,115200n1 root=/dev/mmcblk0p5 vmalloc=512M no_console_suspend androidboot.carrier=wifi-only mtdparts=mt53xx-emmc:2M(uboot),2M(uboot_env),1M(misc),16M(recovery),16M(boot),500M(system),500M(userdata),500M(cache),1M(reserved),1M(channelA),1M(channelB),1M(pq),1M(aq),4M(logo),4M(bootlogo) mali_core_num=2 usbportusing=1,1,1,0 usbpwrgpio=-1,-1,-1,-1 usbpwrpolarity=-1,-1,-1,-1 usbocgpio=-1,-1,-1,-1 usbocgpiopolarity=-1,-1,-1,-1
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
allocated 1482752 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 362MB = 362MB total
Memory: 353484k/353484k available, 17204k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd7000000 - 0xff000000   ( 640 MB)
    lowmem  : 0xc0000000 - 0xd6a00000   ( 362 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0029000   ( 132 kB)
      .text : 0xc0029000 - 0xc04a0f44   (4576 kB)
      .data : 0xc04a2000 - 0xc04d91e0   ( 221 kB)
       .bss : 0xc04d9204 - 0xc0611398   (1249 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:256
timekeeping_init done
ckgen Xtal:27000000 Hz
Console: colour dummy device 80x30
console [ttyMT0] enabled
Calibrating delay loop (skipped) preset value.. 1828.45 BogoMIPS (lpj=4571136)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
CPU: Testing write buffer coherency: ok
Calibrating local timer... 444.93MHz.
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x73440001, Cache size: 262144 B
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3656.90 BogoMIPS).
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource timer2
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 6140K
PMU: registered new PMU device of type 0
Power Management for MTK DTV.
ashmem: initialized
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 702
io scheduler noop registered
io scheduler deadline registered
io scheduleSerial: MT53xxttyMT0 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT1 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT2 at MMIO 0xf0028800 (irq = 32) is a MT53xx Serial
ttyMT3 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
brd: module loaded
loop: module loaded
pmem: 1 init
android_pmem: probe of android_pmem.0 failed with error -1
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
star: desc addr: 0xffdff000(virtual)/0x04037000(physical)
Star Ethernet: Internal Vitesse PHY
star: PHY addr = 0x0000
star: EthTool installed
star: Star MAC init done
MUC_init 5038: [USB]Controller in DMA mode
MGC_VBusControl 725: [USB0]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.0: USB Host Controller
MtkUsbHcd MtkUsbHcd.0: new USB bus registered, assigned bus number 1
MUC_Irq 4222: [USB]Connect interrupt  = 0x10.
MtkUsbHcd MtkUsbHcd.0: irq 47, io mem 0xf0050000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
MGC_VBusControl 725: [USB1]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.1: USB Host Controller
MtkUsbHcd MtkUsbHcd.1: new USB bus registered, assigned bus number 2
MtkUsbHcd MtkUsbHcd.1: irq 43, io mem 0xf0051000
usb_events_timer_func 555: [usb]USB_EVENTS_CHECK_CONNECT
MGC_VBusControl 725: [USB0]Vbus On gpio[-1].
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
MGC_VBusControl 725: [USB2]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.2: USB Host Controller
MtkUsbHcd MtkUsbHcd.2: new USB bus registered, assigned bus number 3
MtkUsbHcd MtkUsbHcd.2: irq 80, io mem 0xf0052000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
using rtc device, mt53xx_rtc, for alarms
mt53xx_rtc mt53xx_rtc.0: rtc core: registered mt53xx_rtc as rtc0
mt53xx_rtc mt53xx_rtc.0: MT53xx Real Time Clock driver.
adbattery: android dummy battery driver loaded
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
Bluetooth: Atheros AR30xx firmware driver ver 1.0
usbcore: registered new interface driver ath3k
mmc0: 5880
at 0xf006d000 irq 100 data mode 3 Optimization
mmc1: 5880
at 0xf0012000 irq 60 data mode 3
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
zram: num_devices not specified. Using default: 2
special_arg: 00000002
zram: Creating 2 devices ...
test mmc...
usbcore: registered new interface driver snd-usb-audio
ALSA device list:
  No soundcards found.
nf_conntrack version 0.5.0 (5619 buckets, 22476 max)
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
mmc0: new high speed MMC card at address 0001
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
mmcblk0: mmc0:0001 H2G1c 1.76 GiB
mmcblk0boot0: mmc0:0001 H2G1c partition 1 1.00 MiB
mmcblk0boot1: mmc0:0001 H2G1c partition 2 1.00 MiB
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
part 01: startblk 0x00000000, blkcnt 0x00001000, <uboot>
part 02: startblk 0x00001000, blkcnt 0x00001000, <uboot_env>
part 03: startblk 0x00002000, blkcnt 0x00000800, <misc>
part 04: startblk 0x00002800, blkcnt 0x00008000, <recovery>
part 05: startblk 0x0000a800, blkcnt 0x00008000, <boot>
part 06: startblk 0x00012800, blkcnt 0x000fa000, <system>
part 07: startblk 0x0010c800, blkcnt 0x000fa000, <userdata>
part 08: startblk 0x00206800, blkcnt 0x000fa000, <cache>
part 09: startblk 0x00300800, blkcnt 0x00000800, <reserved>
part 10: startblk 0x00301000, blkcnt 0x00000800, <channelA>
part 11: startblk 0x00301800, blkcnt 0x00000800, <channelB>
part 12: startblk 0x00302000, blkcnt 0x00000800, <pq>
part 13: startblk 0x00302800, blkcnt 0x00000800, <aq>
part 14: startblk 0x00303000, blkcnt 0x00002000, <logo>
part 15: startblk 0x00305000, blkcnt 0x00002000, <bootlogo>
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
usb 1-1: new high speed USB device number 2 using MtkUsbHcd
mmcblk0boot1: unknown partition table
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev c
mmcblk0boot0: unknown partition table
mt53xx_rtc mt53xx_rtc.0: setting system clock to 2000-01-Freeing init memory: 132K
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: init: cannot open '/initlogo.rle'
mtk_mod: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: commit=1,noauto_da_alloc
MediaTek MT53XX Driver : MTK_002001_000000 (MTK_2.1.0.0)
Mapped physical address 0x17a5f000 - 0x20000000 to virtual begins 0xd7a5f000
[CJY]Mark for panel_early_inti
[IR]PDWNC_InDTV>it
Preloader T8032 ack !
FBM config =FBM_MEM_CFG_MT5880_3DTV_NOMVC_SHRINK
===========  Linux  ==============
Cache    Mem Addr 0x084120020
NonCache Mem Addr 0x08ffde0020
[SA7] vDDDSInit
H_POS_60HZ=2064
HLEN_TOTAL_TYPI=2200
HSYNCLEN_TYPI=32
u4HPorchF=16,u4HPorchB= 232
wDISPLAY_WIDTH=1920
[NPTV]VPorch (262 0)
init: Unhandled fault: imprecise external abort (7) at 0x01ed7fdc, code 0x1406
BIM timeout address is at 0x1a034720
pgd = c40d0000
[01ed7fdc] *pgd=00000000
Pid: 712, comm:                 init
CPU: 0    Tainted: P             (3.0.13 #1)
PC is at _raw_spin_unlock_irqrestore+0x10/0x40
LR is at vDrvSetLCDTiming_SETDATA+0x88/0xf0 [mtk_mod]
pc : [<c0382a8c>]    lr : [<bf0b9660>]    psr: 60000093
sp : d57cddc0  ip : 60000013  fp : 80000013
r10: 00000898  r9 : bf633000  r8 : 000000e8
r7 : 00000106  r6 : 00000546  r5 : 00000000  r4 : 00000106
r3 : 00000000  r2 : 00000461  r1 : 60000013  r0 : bf699f04
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 040d004a  DAC: 00000015
PC: 0xc0382a0c:
2a0c  e5932004 e2422001 e5832004 e5930000 e7e000d0 e3500000 08bd8008 ebfff880
2a2c  e3a00000 e8bd8008 e1a00001 e8bd8008 f57ff05f e3a03000 e5803000 f57ff04f
2a4c  e320f004 f1080080 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004
2a6c  e5933000 e3130002 012fff1e eafff86c f57ff05f e3a03000 e5803000 f57ff04f
2a8c  e320f004 e121f001 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004
2aac  e5933000 e3130002 012fff1e eafff85c f57ff05f e3a03000 e5803000 f57ff04f
2acc  e320f004 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000
2aec  e3130002 012fff1e eafff84d e92d4008 e1a0200d e3c23d7f e3c3303f e5932004
SP: 0xd57cdd40:
dd40  00000000 c04db760 00000001 c004dd08 00000000 00000000 00000000 ffffffff
dd60  d57cddac 00000546 00000106 000000e8 00000898 c002e64c bf699f04 60000013
dd80  00000461 00000000 00000106 00000000 00000546 00000106 000000e8 bf633000
dda0  00000898 80000013 60000013 d57cddc0 bf0b9660 c0382a8c 60000093 ffffffff
ddc0  00000010 bf0baf90 00000000 bf633000 08d9ee20 00000001 00000032 bf633000
dde0  0000002b 0000001c 00000000 bf0bb5d0 00000001 00000000 bf6067b4 bf722168
de00  00000000 bf0bb6d4 00000000 00000004 bf6323b8 bf08f4a8 00000000 bf5e6330
de20  bf637acc bf100548 00000001 00100001 00000000 00000000 00000001 bf133cd8
Internal error: : 1406 [#1] PREEMPT SMP
Modules linked in: mtk_mod(P+)
PC: 0xc0382a0c:
SP: 0xd57cdd40:
Process init (pid: 712, stack limit = 0xd57cc2f0)
Stack: (0xd57cddc0 to 0xd57ce000)
ddc0: 00000010 bf0baf90 00000000 bf633000 08d9ee20 00000001 00000032 bf633000
dde0: 0000002b 0000001c 00000000 bf0bb5d0 00000001 00000000 bf6067b4 bf722168
de00: 00000000 bf0bb6d4 00000000 00000004 bf6323b8 bf08f4a8 00000000 bf5e6330
de20: bf637acc bf100548 00000001 00100001 00000000 00000000 00000001 bf133cd8
de40: bf72272c bf72272c 00000000 bf722388 00000022 bf3abe71 d57cde6c bf5c78dc
de60: bf72272c 00000000 bf6067b4 bf722168 00000000 bf722218 5f4b544d 2e312e32
de80: 00302e30 c005e774 d578c000 c01b7640 c08db100 c08db120 5f4b544d 30323030
dea0: 305f3130 30303030 00000030 c08db100 d656daa0 c00b0ea4 000000ba bf60676c
dec0: 00000001 bf6067b4 bf722168 00000000 0000002b 0000001c 00000000 c0029800
dee0: c04b44b0 00000001 bf60676c bf60676c 00000001 bf60676c 00000001 bf6067b4
df00: c40b7e00 00000001 0000001c c00799e0 bf606778 c40c4000 c00777c8 c03871b4
df20: bf606898 100ffe48 e0004000 0071a5e4 e0585114 e0584f71 e05c3b2c 00000000
df40: 00000000 00000000 00000000 00000029 0000002a 00000021 00000000 0000001a
df60: 00000000 bf336820 00000033 00000000 00000000 00000000 00000000 c00c1b24
df80: d642c000 100ffe48 00000006 0071a5e4 00000080 c002ec84 d57cc000 00000000
dfa0: 00000001 c002eb00 100ffe48 00000006 4003a000 0071a5e4 100ffe48 00000001
dfc0: 100ffe48 00000006 0071a5e4 00000080 0071b000 4003a000 00031e34 00000001
dfe0: 100ffe28 100ffe38 0000c649 000086cc 00000010 4003a000 00000000 00000000
[<c0382a8c>] (_raw_spin_unlock_irqrestore+0x10/0x40) from [<bf0b9660>] (vDrvSetLCDTiming_SETDATA+0x88/0xf0 [mtk_mod])
[<bf0b9660>] (vDrvSetLCDTiming_SETDATA+0x88/0xf0 [mtk_mod]) from [<bf0baf90>] (vDrvSetLCDTiming+0x2a8/0x2e8 [mtk_mod])
[<bf0baf90>] (vDrvSetLCDTiming+0x2a8/0x2e8 [mtk_mod]) from [<bf0bb5d0>] (vDrvLCDFreqSet+0x260/0x2c4 [mtk_mod])
[<bf0bb5d0>] (vDrvLCDFreqSet+0x260/0x2c4 [mtk_mod]) from [<bf0bb6d4>] (vDrvDisplayInit+0x64/0x178 [mtk_mod])
[<bf0bb6d4>] (vDrvDisplayInit+0x64/0x178 [mtk_mod]) from [<bf08f4a8>] (vApiHwInit+0x20/0x104 [mtk_mod])
[<bf08f4a8>] (vApiHwInit+0x20/0x104 [mtk_mod]) from [<bf100548>] (VdoMLInit+0x94/0x108 [mtk_mod])
[<bf100548>] (VdoMLInit+0x94/0x108 [mtk_mod]) from [<bf722388>] (_mt53fb_init+0x28/0x21c [mtk_mod])
[<bf722388>] (_mt53fb_init+0x28/0x21c [mtk_mod]) from [<bf722218>] (init_module+0xb0/0x18c [mtk_mod])
[<bf722218>] (init_module+0xb0/0x18c [mtk_mod]) from [<c0029800>] (do_one_initcall+0x9c/0x16c)
[<c0029800>] (do_one_initcall+0x9c/0x16c) from [<c00799e0>] (sys_init_module+0x13fc/0x15b0)
[<c00799e0>] (sys_init_module+0x13fc/0x15b0) from [<c002eb00>] (ret_fast_syscall+0x0/0x30)
Code: f57ff05f e3a03000 e5803000 f57ff04f (e320f004)
Disable IRQ, CPU loops forever.
CPU1: stopping
[<c0033efc>] (unwind_backtrace+0x0/0xe4) from [<c0029368>] (do_IPI+0xc8/0x198)
[<c0029368>] (do_IPI+0xc8/0x198) from [<c002e6ac>] (__irq_svc+0x4c/0xe0)
Exception stack(0xd645ff90 to 0xd645ffd8)
ff80:                                     00000000 00000000 d645ffd8 00000000
ffa0: d645e000 c04b148c c04d92e4 c0384a54 0000406a 41cfc09f 00000000 00000000
ffc0: c4148044 d645ffd8 c002f548 c002f54c 60000013 ffffffff
[<c002e6ac>] (__irq_svc+0x4c/0xe0) from [<c002f54c>] (default_idle+0x24/0x28)
[<c002f54c>] (default_idle+0x24/0x28) from [<c002f824>] (cpu_idle+0x7c/0xdc)
[<c002f824>] (cpu_idle+0x7c/0xdc) from [<0037d260>] (0x37d26Boot-
Byte 3 : Gating(2 ~ 77), Size=76, Mid=39, Set=39.
HW Byte 0 : DQS(12 ~ 44), Size 33, Set 28, HW_Set 31.
HW Byte 1 : DQS(9 ~ 41), Size 33, Set 25, HW_Set 29.
HW Byte 2 : DQS(11 ~ 44), Size 34, Set 27, HW_Set 29.
HW Byte 3 : DQS(9 ~ 43), Size 35, Set 26, HW_Set 27.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x2b5e7029
:0x04010064
:0x32473163
:0x90014a48
Boot
Start Lmain
HDMI1 PA 0x10
HDMI1 checksum 0xdf
HDMI2 PA 0x10
HDMI2 checksum 0xdf
HDMI3 PA 0x20
HDMI3 checksum 0xcf
HDMI4 PA 0x30
HDMI4 checksum 0xbf
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 205 ms, Max =0 ms.
USB-0: insert.
[_LdrUsbFileRead].
[_LdrUsbFileRead]..
secure boot ok
LZHS start
LZHS done
Starting image...
DRAM:  362 MiB
MMC:   HOST 1
eMMC Name: UNKNOWN
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
No ethernet found.
OK
Starting kernel ...
Machine: MT5880
NR_IRQS:256
Calibrating local timer... 444.96MHz.
Brought up 2 CPUs
TCP reno registered
ashmem: initialized
io scheduler cfSerial: MT53xxttyMT0 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
brd: module loaded
loop: module loaded
pmem: 1 init
mmc0: 5880
mmc1: 5880
test mmc...
ALSA device list:
VFP support v0.3:
mt53xx_rtc mt53xx_rtc.0: setting system clock to 2000-01-01 16:09:56 UTC (946742996)
mmcblk0boot1: mmc0:0001 HFreeing init memory: 132K
mmcblk0: p11 p12 p13 p14 p15
[IR]PDWNC_Init
DTV>SIF_Master0: new design
Cache    Mem Addr 0x084140020
[SA7] vDDDSInit
H_POS_60HZ=2064
HSYNCLEN_TYPI=32
wDISPLAY_WIDTH=1920
init: Unhandled fault: imprecise external abort (7) at 0xbf600000, code 0x1406
pgd = c40a8000
[bf600000] *pgd=14b19811, *pte=149f545f, *ppte=149f545e
sp : c40f1dc0  ip : 60000013  fp : 80000013
Control: 10c53c7d  Table: 040a804a  DAC: 00000015
PC: 0xc0382a0c:
SP: 0xc40f1d40:
1d40  c004dd08 c004dd10 60000013 ffffffff 00000000 00000000 00000000 ffffffff
1d60  c40f1dac 00000546 00000106 000000e8 00000898 c002e64c bf699f04 60000013
1d80  00000461 00000000 00000106 00000000 00000546 00000106 000000e8 bf633000
1da0  00000898 80000013 60000013 c40f1dc0 bf0b9660 c0382a8c 60000093 ffffffff
1dc0  00000010 bf0baf90 00000000 bf633000 08d9ee20 00000001 00000032 bf633000
1de0  0000002b 0000001c 00000000 bf0bb5d0 00000001 00000000 bf6067b4 bf722168
1e00  00000000 bf0bb6d4 00000000 00000004 bf6323b8 bf08f4a8 00000000 bf5e6330
1e20  bf637acc bf100548 00000001 00100001 00000000 00000000 00000001 bf133cd8
PC: 0xc0382a0c:
SP: 0xc40f1d40:
Process init (pid: 712, stack limit = 0xc40f02f0)
Stack: (0xc40f1dc0 to 0xc40f2000)
1dc0: 00000010 bf0baf90 00000000 bf633000 08d9ee20 00000001 00000032 bf633000
1de0: 0000002b 0000001c 00000000 bf0bb5d0 00000001 00000000 bf6067b4 bf722168
1e00: 00000000 bf0bb6d4 00000000 00000004 bf6323b8 bf08f4a8 00000000 bf5e6330
1e20: bf637acc bf100548 00000001 00100001 00000000 00000000 00000001 bf133cd8
1e40: bf72272c bf72272c 00000000 bf722388 00000022 bf3abe71 c40f1e6c bf5c78dc
1e60: bf72272c 00000000 bf6067b4 bf722168 00000000 bf722218 5f4b544d 2e312e32
1e80: 00302e30 e0722fff 0000001c 00000000 c0694680 c06946a0 5f4b544d 30323030
1ea0: 305f3130 30303030 00000030 c0694680 d57cc9c0 c00b0ea4 000000ba bf60676c
1ec0: 00000001 bf6067b4 bf722168 00000000 0000002b 0000001c 00000000 c0029800
1ee0: c04b44b0 00000001 bf60676c bf60676c 00000001 bf60676c 00000001 bf6067b4
1f00: d5795b80 00000001 0000001c c00799e0 bf606778 d578a000 c00777c8 c03871b4
1f20: bf606898 100ffe48 e0004000 0071a5e4 e0585114 e0584f71 e05c3b2c 00000000
1f40: 00000000 00000000 00000000 00000029 0000002a 00000021 00000000 0000001a
1f60: 00000000 bf336820 00000033 00000000 00000000 00000000 00000000 c00c1b24
1f80: d642c000 100ffe48 00000006 0071a5e4 00000080 c002ec84 c40f0000 00000000
1fa0: 00000001 c002eb00 100ffe48 00000006 40138000 0071a5e4 100ffe48 00000001
1fc0: 100ffe48 00000006 0071a5e4 00000080 0071b000 40138000 00031e34 00000001
1fe0: 100ffe28 100ffe38 0000c649 000086cc 00000010 40138000 52b921d0 e8b76a46
Boot-
Byte 1 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
HW Byte 0 : DQS(13 ~ 42), Size 30, Set 27, HW_Set 30.
HW Byte 1 : DQS(10 ~ 40), Size 31, Set 25, HW_Set 28.
HW Byte 2 : DQS(10 ~ 43), Size 34, Set 26, HW_Set 29.
HW Byte 3 : DQS(8 ~ 43), Size 36, Set 25, HW_Set 27.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x2b5e7029
:0x04010064
:0x32473163
:0x90014a48
Boot
Start Lmain
Boot reason: A/C power on!!
HDMI1 PA 0x10
HDMI1 checksum 0xdf
HDMI2 PA 0x10
HDMI2 checksum 0xdf
HDMI3 PA 0x20
HDMI3 checksum 0xcf
HDMI4 PA 0x30
HDMI4 checksum 0xbf
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 200 ms, Max =0 ms.
USB-0: insert.
USB-0: ClassCode= 0x8, u4Diff=196 ms.
USB Medium on Device, Time = 1125 ms.
[_LdrUsbFileRead].
[_LdrUsbFileRead]..
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x30 Flags:0x30
secure boot ok
LZHS start
LZHS done
Starting image...
DRAM:  362 MiB
MMC:   HOST 1
eMMC Name: UNKNOWN
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
No ethernet found.
OK
Starting kernel ...
Machine: MT5880
NR_IRQS:256
Calibrating local timer... 444.99MHz.
Brought up 2 CPUs
TCP reno registered
ashmem: initialized
brd: module loaded
loop: module loaded
pmem: 1 init
star: desc addr: 0xffdff000(virtual)/0x04036000(physical)
mmc0: 5880
mmc1: 5880
test mmc...
ALSA device list:
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 3
mt53xx_rtc mt53xx_rtc.0: setting system clock to 2000-01-01 16:00:00 UTC (946742400)
mmcblk0boot1: mmc0:0001Freeing init memory: 132K
part 15: startblk  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[IR]PDWNC_Init
Cache    Mem Addr 0x0814b60020
[SA7] vDDDSInit
H_POS_60HZ=2064
HSYNCLEN_TYPI=32
scsi0 : usb-storage 1-1:1.0
wDISPLAY_WIDTH=1920
init: Unhandled fault: imprecise external abort (7) at 0x0002b08c, code 0x1406
pgd = d57cc000
[0002b08c] *pgd=157d0831, *pte=0001d7df, *ppte=0001de7f
sp : c40c9dc0  ip : 60000013  fp : 80000013
Control: 10c53c7d  Table: 157cc04a  DAC: 00000015
PC: 0xc0382a0c:
SP: 0xc40c9d40:
9d40  c0027cc0 c0027cc0 c00270a0 c0027cc0 d57ca000 00000001 d64b1540 ffffffff
9d60  c40c9dac 00000546 00000106 000000e8 00000898 c002e64c bf699f04 60000013
9d80  00000461 00000000 00000106 00000000 00000546 00000106 000000e8 bf633000
9da0  00000898 80000013 60000013 c40c9dc0 bf0b9660 c0382a8c 60000093 ffffffff
9dc0  00000010 bf0baf90 00000000 bf633000 08d9ee20 00000001 00000032 bf633000
9de0  0000002b 0000001c 00000000 bf0bb5d0 00000001 00000000 bf6067b4 bf722168
9e00  00000000 bf0bb6d4 00000000 00000004 bf6323b8 bf08f4a8 00000000 bf5e6330
9e20  bf637acc bf100548 00000001 00100001 00000000 00000000 00000001 bf133cd8
PC: 0xc0382a0c:
SP: 0xc40c9d40:
Process init (pid: 712, stack limit = 0xc40c82f0)
Stack: (0xc40c9dc0 to 0xc40ca000)
9dc0: 00000010 bf0baf90 00000000 bf633000 08d9ee20 00000001 00000032 bf633000
9de0: 0000002b 0000001c 00000000 bf0bb5d0 00000001 00000000 bf6067b4 bf722168
9e00: 00000000 bf0bb6d4 00000000 00000004 bf6323b8 bf08f4a8 00000000 bf5e6330
9e20: bf637acc bf100548 00000001 00100001 00000000 00000000 00000001 bf133cd8
9e40: bf72272c bf72272c 00000000 bf722388 00000022 bf3abe71 c40c9e6c bf5c78dc
9e60: bf72272c 00000000 bf6067b4 bf722168 00000000 bf722218 5f4b544d 2e312e32
9e80: 00302e30 c005e774 d5789000 c01b7640 c08db040 c08db060 5f4b544d 30323030
9ea0: 305f3130 30303030 00000030 c08db040 d64eaa60 c00b0ea4 000000ba bf60676c
9ec0: 00000001 bf6067b4 bf722168 00000000 0000002b 0000001c 00000000 c0029800
9ee0: c04b44b0 00000001 bf60676c bf60676c 00000001 bf60676c 00000001 bf6067b4
9f00: d64e4500 00000001 0000001c c00799e0 bf606778 d57ca000 c00777c8 c03871b4
9f20: bf606898 100ffe48 e0004000 0071a5e4 e0585114 e0584f71 e05c3b2c 00000000
9f40: 00000000 00000000 00000000 00000029 0000002a 00000021 00000000 0000001a
9f60: 00000000 bf336820 00000033 00000000 00000000 00000000 00000000 c00c1b24
9f80: d642c000 100ffe48 00000006 0071a5e4 00000080 c002ec84 c40c8000 00000000
9fa0: 00000001 c002eb00 100ffe48 00000006 40209000 0071a5e4 100ffe48 00000001
9fc0: 100ffe48 00000006 0071a5e4 00000080 0071b000 40209000 00031e34 00000001
9fe0: 100ffe28 100ffe38 0000c649 000086cc 00000010 40209000 e08d3ba6 a1d3a303
CPU1: stopping
ffa0: d645e000 c04b148c c04d92e4 c0384a54 0000406a 413fc090 00000000 00000000
ffc0: c40ca044 d645ffd8 c002f548 c002f54c 60000013 ffffffff
GMT+8, 2024-11-19 05:49 , Processed in 0.059586 sec., 9 queries .
