查看: 725|回复: 3
康佳55S8000U 2991 1201YT 809H备份数据
发表于: 2022-3-25 20:59:32
康佳55S8000U  2991 1201YT 809H备份数据  有点位图
发表于: 2022-4-7 22:46:04
U-Boot 2012.07 (Apr 27 2017 - 17:14:20) r-109afac
SCPU2: BISR testing
SCPU2: BISR hold remap
SCPU2: BISR ok
CPU: Cortex-A53x4
DRAM:  1.5 GiB
Watchdog: Disabled
ok will set core scpu default
### iddq_v X 10 = 80 ###
PIN_A7: 0xB800085C[23:20]; GPIO121       0xB800085C=((xxf0xxxx))
PIN_A5: 0xB8000860[7:4]; GPIO127         0xB8000860=((f0xxxxf0))
PIN_D7: 0xB8000860[31:28]; GPIO124
MIS_GP3DIR      ((volatile int)0xb801bc0c)
MIS_GP3DATO     ((volatile int)0xb801bc24)
MIS_GP3DATI     ((volatile int)0xb801bc3c)
0xB800085C=((0x70700000))
0xB8000860=((0x00000000))
0xb801bc0c=((0x00000000))
0xb801bc24=((0x00000000))
0xb801bc3c=((0x00000000))
0xB800086C=((0xcc000000))
0xb8000814 bit[23:20] & [15:12]set 1     0xb8000814=((xx1010xx))
0xb8000814=((0x10101010))
name=AMP_I2C ppcb_enum.Name=AMP_I2C, ppcb_enum.info=300000000
name=AMP_DEVICE_ADDR ppcb_enum.Name=AMP_DEVICE_ADDR, ppcb_enum.info=1a00000000
name=PIN_AMP_MUTE ppcb_enum.Name=PIN_AMP_MUTE, ppcb_enum.info=101070400000000
name=PIN_AMP_RESET ppcb_enum.Name=PIN_AMP_RESET, ppcb_enum.info=101070400000000
Board: RTD2997D TV035 Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:   rtkemmc_dw: clk change to 200Khz(0)
pllemmc_ncode_t=0x29
rtkemmc_dw: clk change to 10Mhz(1)
pllemmc_ncode_t=0x17
rtkemmc_dw: 8 bits mode
rtkemmc_dw: clk change to 50Mhz(7)
pllemmc_ncode_t=0x13
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
eMMC(Toshiba) MMC_HS50 (50000000Mhz)[8bit]
factory_buffer:0a900000, factory_buffer2:0ad00000!
MMC
[FAC] factory_buffer  = 0xa900000
[FAC] factory_buffer2 = 0xad00000
[FAC] Get factory header [0] from eMMC
[FAC] ******** CHECK FACTORY HEADER [0] ********
[FAC] -- PASS: read emmc
[FAC] -- PASS: factory header
[FAC] -- PASS: tar header
[FAC] -- PASS: tar size >= 256
[FAC] -- PASS: rtk signature
[FAC] -- PASS: tar size 0x00195800
[FAC] ******** CHECK FACTORY HEADER [0] ALL PASS
[FAC] Need to check the end header
[FAC] pp 0 ok
[FAC] Get factory header [1] from eMMC
[FAC] ******** CHECK FACTORY HEADER [1] ********
[FAC] -- PASS: tar size 0x00195400
[FAC] ******** CHECK FACTORY HEADER [1] ALL PASS
[FAC] pp 1 ok
[FAC] result: pp_ok = 0x3
Factory: seq:0xab2, blk:0xe000(pp:1), size:0x195400 (to 0xa900000)
[FAC] factory_tarsize = 0x195400
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_RESET_DEFAULT_LEVEL=0
IMGFILE_PATTERN=R2991MUpgrade.img
--debug-123-BOOT_BACKLIGHT_VALUE=253
BOOT_KONKA_BOOT_VOL=43
BOOT_KONKA_SLEEPLED_MODE=0
BOOT_KONKA_UART_ENABLE=0
BOOT_WAKEUP_KEYPAD_NO=0
bootparam.konka_uart_enable = 0这机器不接屏线就是这样,按任何键无反应,
发表于: 2022-4-7 22:55:16
出现上述打印,一定要接双屏线!
GMT+8, 2024-11-18 12:24 , Processed in 0.053395 sec., 9 queries .
