查看: 498|回复: 2
西门子 SE567 刷路由求救
发表于: 2022-3-23 21:42:17
External watchdog disabled
Starting BOST:
  SDRAM ok
BOST OK
Reset Status Register (RSR) value: 0x0
RAM size is 16777216 (0x1000000).
Interrupt Stack Control @ 0x0.
Userland stack @ 0x94ffffd8.
CPU clock rate is 212 MHz.
System clock rate is 106 MHz.
Bootloader compiled Dec 22 2006 at 13:58:16.
Loader starting...
FLASH: Macronix Mx29LV320 (Top Boot)
autoboot v2.0
LDR: Image @ 0xb0020000 - Valid
LDR: Image @ 0xb0200000 - Valid
LDR: Beginning Uncompress
LDR: Compressed length = 1732288
LDR: Uncompressed to = 4240420
     P R O J E C T
     XXX       XXX
      XXX     XXX
       XXX   XXX
        XXX XXX
         XXXXX
          XXX
         XXXXX
        XXX XXX
       XXX   XXX
      XXX     XXX
     XXX       XXX - MIPS
Copyright (c) 2001-2006, Siemens Subscriber Networks, Inc.
Speedstream E652 is powered by Project X
Version 004-E652-A1S, Build 115-37, Dec 22 2006 13:57:47
Expat - XML Parser Toolkit v1.2
        Copyright (c) 1998-2000, Thai Open Source Software Center Ltd
---System Starting---
XSH:                                                   [  OK  ]
NVRAM: 003-6045-G0I, Full Router GA configuration. NV'G':149680
NVRAM:                                                 [  OK  ]
INT:                                                   [  OK  ]
TMR:                                                   [  OK  ]
WDT: Internal timeout set to 10s
WDT:                                                   [  OK  ]
LED:                                                   [  OK  ]
BUTTON:                                                [  OK  ]
SYSTASK:                                               [  OK  ]
SNTPC:                                                 [  OK  ]
SYSLOG:                                                [  OFF ]
XLOG:                                                  [  OK  ]
DNSRELAY:                                              [  OK  ]
IPFW:                                                  [  OK  ]
ADSL:                                                  [  OK  ]
BRG:                                                   [  OK  ]
L2XP                                                   [  OK  ]
ETH_SWITCH:   DevId = 0x60   RevId = 0x2
ETH1:                                                  [  OK  ]
ETH2:                                                  [  OK  ]
ETH3:                                                  [  OK  ]
ETH4:                                                  [  OK  ]
USB:                                                   [  OK  ]
WLAN1:                                                 [  OK  ]
WLAN2:                                                 [  OK  ]
2684:                                                  [  OK  ]
2364:                                                  [  OK  ]
ATM:                                                   [  OK  ]
IGD:                                                   [  OK  ]
UPNP:                                                  [  OK  ]
LANCLIENT:                                             [  OK  ]
DDNSD:                                                 [  OFF ]
FWUPDATE:                                              [  OK  ]
TFTPD:                                                 [  OFF ]
QOS:                                                   [  OFF ]
ARDD:                                                  [  OFF ]
CWMP:                                                  [  OK  ]
---System Ready---
ADSL: Boost DSP
ADSL: DataPump Version - 07.00.02.00
ADSL: DOWN
ADSL: WAITING
UPNP: Added IF: br0 to UPnP multi-cast group
WLAN: Waiting for user configuration
 楼主| 发表于: 2022-3-23 21:45:06
硬件和dg834v3 配置一样
 楼主| 发表于: 2022-3-24 06:39:31
硬件配置信息
Architecture:        MIPS (little endian)
Vendor:        Texas Instruments
Bootloader:        ADAM2
System-On-Chip:        TI AR7 TNETD7200ZDW
CPU Speed:        150Mhz
Flash-Chip:        Macronix 29LV32
Flash size:        4 MiB
RAM:        16 MiB EtronTech EM63916
Wireless:        TI TNETW1350A On-Board (802.11bg)
Ethernet:        Marvell 88E6060
Serial:        Yes - JP603 as V1
JTAG:        Yes - JP102 as V1
GMT+8, 2024-12-24 01:50 , Processed in 0.052229 sec., 10 queries .
