查看: 955|回复: 1
海信RSAG7.820.5060檫除引导后的字符,请老师指点
发表于: 2022-3-21 21:24:16
CSD: 92400045 FFFFFFEF 0F5903FF D00E0032
CSD_STRUCTURE: Version is coded in the CSD_STRUCTURE of EXT_CSD
SPEC_VERS: Version 4.1-4.2-4.3
TRAN_SPEED: 26MHz(Default Mode)
READ_BL_LEN: 512 Bytes
WRITE_BL_LEN: 512 Bytes
C_SIZE: UNKNOWN(Refer to SEC_COUNT in EXT_CSD)
ERASE_GRP_SIZE: 524288(0x00080000) Bytes(1024 Blocks)
WP_GRP_SIZE: 8388608(0x00800000) Bytes(16 Erase Groups)
WP_GRP_ENABLE: YES
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT: NO
FILE_FORMAT: Hard disk-like file system with partition table
ECC: None(default)
File Open Error
 楼主| 发表于: 2022-3-21 21:27:39
Some special setting will be applied to this download board!
Flash Identification Process
MT5860 ES2 MSDC1 Usage
Set Bus Clock as 0(MHz) Success!
CMD0 ARG 0x00000000 RESPONSE_NO.
CMD8 ARG 0x000001CC - CMD Timeout (AccuVect 0x00000200 INTR 0x00000000).
CMD55 ARG 0x00000000 - CMD Timeout (AccuVect 0x00000200 INTR 0x00000000).
CMD1 ARG 0x403C0000 RESPONSE_R3 0x00FF8080.
CMD1 ARG 0x403C0000 RESPONSE_R3 0xC0FF8080.
CMD2 ARG 0x00000000 RESPONSE_R2 0x6D83401D 0x32005CD0 0x30384739 0x11010030.
CMD3 ARG 0x00010000 RESPONSE_R1/R1B 0x00000500.
CMD9 ARG 0x00010000 RESPONSE_R2 0x92400045 0xFFFFFFEF 0x0F5903FF 0xD00E0032.
CMD7 ARG 0x00010000 RESPONSE_R1/R1B 0x00000700.
CMD6 ARG 0x03B70100 RESPONSE_R1/R1B 0x00000800.
CMD13 ARG 0x00010000 RESPONSE_R1/R1B 0x00000900.
card status: 00000900
CMD6 ARG 0x03B37800 RESPONSE_R1/R1B 0x00000800.
============Memory Card Information=============
[OCR]
Support Voltage: 1.70~1.95V 2.7~3.6V
[CID]
CID: 6D83401D 32005CD0 30384739 11010030
MID: 11
CBX: BGA(Discret embedded)
OID: 110100
PNM: 008G92
PRV: 0.0
PSN: 5CD06D83
MDT: April 1997
Access Type: Block
[CSD]
WP_GRP_ENABLE: YES
ECC: None(default)
File Open Error
GMT+8, 2024-12-19 21:11 , Processed in 0.050451 sec., 9 queries .
